Reply 27620 of 31807, by Minutemanqvs
- Member
PD2JK wrote on 2024-05-22, 16:42:Unfortunately that is unknown. The machine the disk was in was from some shed/storage, so I guess it wasn't powered on for ages. […]
ChrisK wrote on 2024-05-22, 14:26:PD2JK wrote on 2024-05-21, 13:03:Alright, so I simply bridged the soldering pads, but the drive won't spin. Then I soldered a 4.7uF cap in its place and the driv […]
Alright, so I simply bridged the soldering pads, but the drive won't spin. Then I soldered a 4.7uF cap in its place and the drive slowly spins up.
After a few seconds you'd expect a moving actuator for initialization of the heads and so on, but the drive spins down a bit and tries two more times. Maybe the heads/actuator is stuck in its position.
Not sure if the drive motor reaches full speed either.
I looked up some YouTube videos of the WDAC280 drive, and those are spinning up a quite faster.And a picture of the burned component: (now replaced with a 4.7uF capacitor)
DSC_9143.JPGOK, had a more detailed look into the datasheet and it seems you are right. The damaged part really could've been a cap (cap C3 in the datasheet p.7 Fig. 3, to be exact). The remains of the part in your newer picture also seems to confirm that. I previously identified the big yellow one as the bulk cap of the charge pump (Cp as shown in the datasheet's block diagramm).
So it seems there's more than just that blown cap. Did the drive work properly just before?Unfortunately that is unknown. The machine the disk was in was from some shed/storage, so I guess it wasn't powered on for ages.
Guess I'll have to power it on and off quite a few times and maybe then I'm lucky and gets unstuck.
Would the freezer help or is that an urban legend.
The freezer thing was always a last resort thing, to get a drive going one last time and hope you can get some data back. But remember that you can have all sorts of issues with condensation if it spins up, and it will probably rust after that.
Maybe tap it lightly in the center with a rubber mallet?
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
