Reply 280 of 313, by MattRocks
- Oldbie
douglar wrote on 2025-12-08, 12:27:MattRocks wrote on 2025-12-08, 11:05:Useful, but why test the DX6 cards under DX9c conditions? Depending on what the drivers do, I think that might be a handicap for […]
douglar wrote on 2025-12-08, 03:21:It did some tests on the rv100 with a K6-3 400, P3-800 and an Athlon 2500+ recently.
Re: K6-III Socket 7 AGP vs PCI Tester The RV100 cards I had were not thrilling. I wouldn’t recommend them for DOS or Win31. There were some compatibility issues under DOS, didn’t have Win3.1 drivers, and they were all discount boards with at best average video quality. If you are going for the discount boards, I’d say the MX 4000 or an FX 5200 gives better bang for the retro $$ under Windows 95.From my own personal experience, the ATI mach 32 with the fast ramdac was my card of choice from 1992 to 1995. Fast and had 8514/a hardware support for out of the box compatibility. Also had the best picture quality on the market at the time and you could save your refresh rate settings to the card.
Useful, but why test the DX6 cards under DX9c conditions? Depending on what the drivers do, I think that might be a handicap for some cards; FX5200 is notorious for being a DX8 chip sold as DX9 compliant due to driver software emulation.
In terms of capabilities the RV100 VPU aligns closely with TNT2 and Rage128Pro - definitely no T&L/DX7 stuff on any of them. Your test compared 128bit TNT2 and 128bit Rage128Pro against 64bit 7000.
I only did an anecdotal "test" with PC-BSD (an old operating system). I just booted them and shut down - so more a check than a test. The Radeon DDR/9550/9600/9700 all displayed beautifully; while the Rage128Pro/7000 both display the same software glitches around hardware mouse pointer, which I am led to believe is a known Rage128 driver issue (why the Rage128 driver decided it should drive the 7000 is not known - I just assumed the software knows what it's doing). I didn't test further than that as I was just sorting my cards, but it shows something worth further investigation. My 7000 is the 128bit variant, but VRAM behaviours would not be stressed on loading a desktop.
Radeon DDR was still R100 and when I was testing, the R100 family it still had a lot of the issues found in the Rage 128, like some of the 640x480 modes displayed incorrectly, etc.
That is really insightful:
Rage128 gets complaints in DOS.
R100 gets complaints in DOS.
So nobody bothers to test the RV100 in DOS.
That is rational, but inconclusive for one very simple reason: The RV100 is a simple architecture for OEMs that demanded stability, and our little investigation suggests it has no direct ancestor.
I just now checked Linux drivers and RV100 (Q1 2001), according to Linux devs, is the first ATI card to fully support multiple displays - not the R100 (feature disabled) and not the RV200 (came later). Whatever those devs found suggests the RV100 provides an evolutionary beginning, not an evolutionary dead end.
douglar wrote on 2025-12-08, 12:27:I just tested a lot of cards that I got on the cheap, at first to see if PCI vs AGP mattered in the super socket 7 era. The answer was it didn't matter that much on Super 7 motherboards other than a 10-15% drop off in DOS pixel flinging.
That is kind of expected. Most first generation AGP cards were PCI native VPU and VRAM packaged onto an AGP PCB (the only "true AGP" card is the Intel i740). Intel patented AGP when memory was very expensive and Intel imagined using system RAM as VRAM would present big cost savings, but the price of memory dropped and the original AGP dream was redundant.
douglar wrote on 2025-12-08, 12:27:But then I expanded the tests to AGP 4x and AGP 8x and by the time you get to AGP 8x motherboards, not only was there a difference in PCI vs AGP performance, but the PCI performance was actually worse on a 2005 motherboard than it was in the Super 7 motherboards.
Useful to know. PCI degrades even more with PCIe native motherboards and their "stuck on" PCI-to-PCIe adapter chips.
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * lost
