Reply 28260 of 31628, by Kahenraz
zwrr wrote on 2024-09-01, 22:12:
Kahenraz wrote on 2024-09-01, 13:47:
zwrr wrote on 2024-09-01, 08:33:
Add channel status lights to the ST-55ST panel to achieve an effect similar to the ST-88ST, by installing the BulkyMIDI-32 Chann […]
Add channel status lights to the ST-55ST panel to achieve an effect similar to the ST-88ST, by installing the BulkyMIDI-32 Channel board inside the ST-55ST.
https://github.com/tebl/BulkyMIDI-32/tree/mai … 2%20Channel%202
The attachment 111_mini.jpg is no longer available
The attachment 222_mini.jpg is no longer available
I don't understand this mod. Don't the lights already show which channel is active? What does it cause the synthesizer tondo differently?
The original SC-55ST front panel only has one MIDI signal LED, I installed an additional 16 LEDs to display the status of each MIDI channel.
Oh! It looks so good that I didn't realize those were all custom LEDs! Good job.
Reply 28261 of 31628, by PD2JK
Postman5 wrote on 2024-08-31, 05:02:
PD2JK wrote on 2024-08-30, 14:16:
Yeah... and a resistor and capacitor (?) array.
Edit; R27 is also missing
Likely C100=10pF
Thanks for the picture, that was quite helpful!
However no boot/POST yet. Half of the legs of an IC at the upper right corner, above the dipswitches, were loose. I resoldered them. But still no cigar. We'll continue our research.
has all kinds of stuff
Reply 28262 of 31628, by dominusprog
dominusprog wrote on 2024-09-01, 19:50:
Clean and retrobright this LG Studioworks 1505s monitor, also changed the VGA cable and done some adjustments to the Focus, Screen and Subcon potentiometers.
The attachment IMG_20240901_205700.jpg is no longer available
The attachment IMG_20240901_205737.jpg is no longer available
Put it back together.
The attachment IMG_20240902_162606.jpg is no longer available
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 28263 of 31628, by Turbo ->
Salvaged these 72 pin rams from a system of some sort. Rams look quite nice. I could use them in a 486 or a Pentium 1 build I guess.
Reply 28264 of 31628, by 80386SX
Turbo -> wrote on 2024-09-02, 17:24:
Ho, lovely double face radiator.
Very nice and rare.
Reply 28265 of 31628, by DarthSun
Voodoo 2 SLI for XP. I will continue Today. SLI/D3D is not going, waiting for a solution.
Single V2/3DM2000 :
The attachment 225621_g5w8zipelca7wdbq_p4xp3dm2000.jpg is no longer available
OGL/Glide works in SLI.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 28266 of 31628, by Veeb0rg
PIcked up a 2007 imac over the weekend. Swapped in a 1tb drive and installed Ubuntu on it. Nice little machine.
Reply 28267 of 31628, by mmx_91
DarthSun wrote on 2024-09-03, 04:40:
Voodoo 2 SLI for XP. I will continue Today. SLI/D3D is not going, waiting for a solution. Single V2/3DM2000 : […]
Single V2/3DM2000 :
Amazing! Aren't the drivers going around for 2k/XP only for Glide?
I'm not an expert on this, as I've always used main card such as Geforce for D3D.
Reply 28268 of 31628, by Thermalwrong
Somehow I now have 3x Toshiba Portege 610CT laptops and only one good screen, which until earlier this evening I thought the one with the good screen had a bad floppy controller since it wouldn't read discs.
Took the good screen one apart and got into its motherboard and made this little adapter PCB so I can check continuity of the floppy connector, but the connector is making a 'ting' sound and it can move back and forth. So I thought the mainboard was broken but it's just a connector came unsoldered? Fantastic! I have had absolutely ENOUGH of complex repairs right now.
The attachment portege-floppy-testing1.JPG is no longer available
The attachment portege-floppy-testing.JPG is no longer available
Now I've got my perfect Portege 610CT with CF/SSD, one with a crack slowly spreading in the middle of the screen and the last one is tatty and the screen's polariser had got 'vinegar syndrome' 😐 But all 3 are 100% good mainboards at least.
Tempted to put some wires on that adapter PCB and make it a gotek adapter, that'd be neat.
(I don't intend to keep 3 of them, but they're not much use to people right now with a bad screen and the laptop doesn't have VGA output)
Reply 28269 of 31628, by DarthSun
mmx_91 wrote on 2024-09-03, 13:25:
Single V2/3DM2000 :
There is a special driver to go under V2SLI XP with Glide/OGL. D3D too, but only without SLI with 1 card setup.
However, I haven't been able to start the 3DM99Max yet (smooth version runs), now I'm trying main AGP card replacement + new XP setup.
Reply 28270 of 31628, by thp
Recapped the 4 caps in the corner of the Audigy 2 ZS to fix issues with it, but unfortunately even with the new caps the issue persists.
Reply 28271 of 31628, by PcBytes
Fixed my Radeon 9800SE AIW... with a torch lighter.
Surprisingly and ironically enough, it works.
Reply 28272 of 31628, by PD2JK
I gave these speakers a Deoxit treatment, the pot meters and power switch that is.
The attachment speakers.png is no longer available
It turns out it has real tweeters, so that's a plus.
The attachment DSC_1537.JPG is no longer available
And here is the main star:
The attachment DSC_1538.JPG is no longer available
So we have a 120 Watt (PMPO) speaker set, equipped with 15 W woofers + 3 W tweeters, and the amplifier is capable of giving 2.1 Watt. Per channel I hope. 🤣
Reply 28273 of 31628, by ssokolow
I think my mother has a pair of those that need recapping. IIRC, they've developed a hum.
EDIT: Wait, no. I think those are on her PC and doing fine and the Raspberry Pi-based media player I built for her is on a 2.1 set that's developed a hum.
(I'm thinking of trying to rebuild it using a repurposed Android TV box that I got Armbian working on so I can have another Pi GPIO header ready to use for things in the vein of PiSCSI, USB4VC, etc.)
Internet Archive: My Uploads
My Blog: Retrocomputing Resources
My Rose-Coloured-Glasses Builds
I also try to announce retro-relevant stuff on on Mastodon.
Reply 28274 of 31628, by Daniël Oosterhuis
Major Jackyl wrote on 2024-08-17, 14:20:
I started the day with a bit of hybrid retro-ing. I became overjoyed when I picked up a stack of BigFoots (CY, TS, AND TX) and wanted to make a face for them. I've used spare drive adapter faces before and they work, so I threw one into the clone-o-matic and BAM! Faces for everyone! 🤣 It just needs a standoff (fine thread standard hex works) in the face hole and it lines up perfectly. I left a LED hole for asthetics, but *should fit the old-timey square guys. If anyone has other solutions for facing Bigfoots, let me know, too!
The attachment 20240816_231325.jpg is no longer available
The attachment 20240817_091902.jpg is no longer available
Ooh, very nice, I actually was looking for such a bezel for Bigfoots (Bigfeet?), I have a couple and want to install them in some AT/XT PCs, which would be made complete with the era appropriate HDD blanking plate.
This exactly fits the bill, will have to get some printed!
Reply 28275 of 31628, by momaka
Retro activities today:
- Washed an ASUS Radeon x600Pro and Ensoniq AudioPCI 3000 cards. They didn't come out as clean as I'd like, but good enough. The Ensoniq sound card looks as if black dust / sooth has burned onto the PCB and just won't wash off with regular dish detergent and water. But it's cleaner than it was. I might try IPA later on. As for the x600 Pro, it looks OK. I missed a spot between a few of the capacitors and there's a ton of dirt there, but will see if it's worth re-washing the board. Might try it like this first (later tonight or tomorrow when it dries), just to see if it works, and then go from there. Both of these cards were picked up as e-scrap boards at the fleamarket sale last weekend. I paid less than $3 for the two of these (about $2.50, actually), so don't have any real expectations. The x600 Pro also had a zip-tied 50 mm fan on top of its cooler and the original fan removed (likely because it failed.) But whoever did this did a terrible job and warped the heatsink like crazy on the bottom. So not sure if the core was contacting the heatsink surface that well with the mod. There's always a chance it could have burned out. We will see, I suppose.
- Washed some vinyl records and CDs/DVDs that I also picked up off the ground at the fleemarket last weekend. Haven't tested the records yet, but they don't look too scratched, and at least they are not warped (which is rare for that flea market.) As for the CDs/DVDs, there's an Office 2007 Ultimate PE DVD (PE=Pirate Edition 🤣), a bunch of CDs with music, and a few blank DVDs and CDs that I picked up off the ground specifically because they looked like they were blank. Oh, and there was also a CD labeled "pictures : ) ". Decided to snoop in it just for shits and giggles. Apparently it was from a group of high school kids from some years back. Then there was one picture with the ID cards of 4 of the people from that class, which revealed they are all just 1 year younger than me. Looking at the date of the pictures, I suppose that makes sense, with most of them being taken 2005-2006 and the CD burned around 2007 or 2008, IIRC. And for those who are wondering... yes there were a few "saucy" pictures in there 🤣. I was genuinly more interested to see the interiors and/or surrounding of their houses or where the pictures were taken, though. And as a bonus, I found a few "desk setup" pictures, which were quite cool to see IMO, showing the average teenager's computer setup back in those days - yup, good old silver/beige desktops with CRT monitors. COOL Maybe I'll post them in the "show your work area" thread later this week. Just need to inspect the pictures again to make sure there isn't any sensitive info that might leak out.
- Brought some rocks from the local river bed for a project my father is working in the yard. No modern equipment was used for carrying the rocks 🤣 - just 100% manual labor, carrying the rocks in a century-old wooden wheel barrow. I suppose that qualifies as retro activity too, right? 😁
PD2JK wrote on 2024-09-05, 05:59:
Hehe, typical cheap desktop speakers of the time. 🤣
Though if we have to be honest, these aren't that bad at all. The woofers are quite alright and shielded, which is nice. And you got real tweeters too... so there's that.
Now as for the amp... 2.1 Watts /ch is the nominal value the manufacturer gives with 9V Vcc (with an ugly 10% THD 🤣). If you look a little closer at the AN7148 datasheet, the IC is rated for 24V absolute maximum (well, you probably don't want to go that high, being an absolute max. rating), and rated for 6-18V nominal operation. So depending on the voltage that the transformer/power adapter for these speakers is outputting (and the current it can supply - 1 Amp should be minimum), you may actually be able to get higher power output. For example, with 18V Vcc for the IC and 4-Ohm drivers, I think you should be able to get about 6 Watts of output power per channel... which isn't too shabby for close-range listening. Of course, that power will only do any good if the speaker boxes are up to snuff (which I'm not that sure about, as they look like typical thin ABS plastic that'll resonate like a can.) Also, I'm not sure the heatsink on the IC will be able to handle the P_d for that kind of output output power, at least continuously. With short "thump" bass notes spaced apart, it won't be a problem. But any music content with continuous low-freq. bass notes will likely make the heatsink toasty. Also, I see the speaker ports have quite the rough edge. I doubt the drivers will be moving that much air to cause any port chaffing noises, but still that's something to keep an eye on too. I suppose if you really want to improve these speakers, you could do that by reinforcing the walls + add some damping on the "cabinets" (more like, cans?), and replacing the output coupling caps with bigger ones (along with the feedback and RF rejection cap), that might improve the sound a little. But it will probably be more work than it's worth.
On a related note, I have somewhat similarly-built speakers from the late 90's (similar arrangement with a larger-than-cheapo-speakers woofer and a real tweeter like yours), and I have to say that I think they sound quite decent. With the Bass knob turned all the way up, they actually pump out some decent low-end bass down to 45-50-ish Hz, which is not bad at all considering their size and build quality.
Reply 28276 of 31628, by PcBytes
In process of fixing a rough diamond - MSI MS-6168 VER2 w/ the legendary onboard Voodoo 3 2000 😀
Reply 28277 of 31628, by DarthSun
Install XP SP2. Voodoo2 SLI/Single cramping follows. It turns out how effective the older one is compared to SP3.
The attachment BladeSP2_P4_def.JPG is no longer available
Reply 28278 of 31628, by Major Jackyl
Daniël Oosterhuis wrote on 2024-09-05, 06:49:
The attachment 20240905_121821.jpg is no longer available
I've been enjoying them, had the same problem, trying to install them in cases with missing blanks. I was working on a "full height" one, too, will have that soon. I just got ABS, too. Never printed with it, so that'll be fun. The screw tabs are a little delicate with PLA/PLA+
The attachment 20240905_122621.jpg is no longer available
Today I got the day off due to slowness, so I was (am) at home detailing and formatting my Bigfoot stack and also detailing a few cards.
The attachment 20240905_122559.jpg is no longer available
Also working on these little stands for cards. I have PCI and AGP made so far. The PCI-E just needed an adjustment and will test print again. I basically need to start from scratch for the ISA one. I know they're a bit more rare, but I'm also making a VLB one. Since I don't have a motherboard for it, I would like to gawk at it from time to time, 🤣
The attachment 20240905_123005.jpg is no longer available
Heh, should probably post a picture of card in question.
The attachment 20240405_154035.jpg is no longer available
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 28279 of 31628, by DarthSun
Major Jackyl wrote on 2024-09-05, 17:44:
I've been enjoying them, had the same problem, trying to install them in cases with missing blanks. I was working on a "full hei […]
Bigfoot is one of my favorite retro HDD.
VLB? ... vs PCI: https://logout.hu/bejegyzes/darthsun/486_vlb_vs_pci_2.html
