Reply 28924 of 60068, by dionb
Nprod wrote:
Vegge wrote:
And open sesame 😁
I genuinely laughed out loud, what a marvellous troll... Perhaps Beckman just made cases for people looking to replace the spongy keyboard on their original units?
Er yes, there was a whole industry around that because the original ones were *so* bad. This one is interesting because you apparently don't even unscrew the top part of the case, but there were lots out there, including the highly regarded Saga Emperor series where you kept the bottom part of the case and just screwed that - with motherboard and all - into the new case.
I had an LO-Profile case that was more advanced in that you transplanted the motherboard without keeping any of the original case. Sounds good, but gave no end of problems with peripherals like the Interface 1 that were supposed to fit snugly under the (original) case.
But it's a long time since I had any Speccy stuff. I sort of keep an eye open for a 128k 'toast rack', but don't want it enough to pay the very high going rates for it - not many were made and most agree it's the best looking and most functional of the Spectrums, so it's highly sought-after.
What I did receive today:
The original clickety-clack Orchid Voodoo 1. A very late example (1998...) of the very first Voodoo 1 retail design.
Reply 28925 of 60068, by Predator99
creepingnet wrote:
Going off the number of slots I'd say Zenith Data Systems Z-386. I found the carcass of one in a junk pile 15 years ago and I quite firmly recall it had 10 slots and an AT Jack in the back, one of the reason I did not pick it up (already had too many projects at that time with missing proprietary parts). Here's a picture, can't find one of the backplane anywhere though.
Thanks! I have found a picture of the inside:
https://hiveminer.com/Tags/crrc,z386
This board seems to be different, but the case layout is prepared for 10 ISA slots. So maybe its indeed a Zenith. I noticed there is another label on the ROM "VT386VT".
Reply 28926 of 60068, by rasz_pl
Predator99 wrote:
Not enough ISA-Slots...this one has..1..2..3....10!!! Not enough RAM for your 386...this one has...1...2..3...16 SIMM Sockets! h […]
file.php?id=63998&t=1
Absolutely fabulous!
And its not even the full version 😮! Look at all the unpopulated stuff in the corner, seems its missing optional I/O at J11/12/13 and 32 capacitor/inductor pairs, another battery/clock/decoder logic and some controller chip. Fascinating, would love to know what was its intended application.
Is it running that 386 at 33 or 25MHz (clock chip is 50)?
Reply 28927 of 60068, by luckybob
that 386 board is an absolute unit.
kinda late though, date codes are early 1991. So the last of the 386 era.
Reply 28928 of 60068, by PC Hoarder Patrol
Crucial 9800 Pro & HIS 9800 SE AIW (not sure the added ram sinks were totally necessary in either case, so may remove)
The attachment ati9800a.jpg is no longer available
The attachment ati9800b.jpg is no longer available
Reply 28929 of 60068, by respect2759
News in collection, not tested, got them for a notebook display. I got some socket 754 Semprons too.
update: Geforce is OK, the Sapphire shows only artifacts in 3 motherboards tested, DVI and VGA too 😒
From Sempron CPUs only one is working
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 28930 of 60068, by Predator99
rasz_pl wrote:
Absolutely fabulous! And its not even the full version :o! Look at all the unpopulated stuff in the corner, seems its missing op […]
I think its hardwired to 25 MHz (crystal 50 MHz). I got it without CPU, so the 33 MHz one was added by me. Therefore I dont think its a very late board. But it seems to be really fast for a 25 MHz.
Do you know what kind of FPU I can add? Think a 387 doesnt fit?
The attachment DSC_8619.JPG is no longer available
Reply 28931 of 60068, by Caluser2000
Just got offered $5 off a XT-IDE from a local outfit so ordered one. Now my XT Turbo with EGA will be rocking. Just need to find a suitable NIC.
Reply 28932 of 60068, by Bige4u
Leave the memory heatsinks on... i've read quite a few horror stories from 9800pro cards failing because the memory running hot, or maybe it was from OCing them w/o proper cooling, cant hurt to leave them on for longevity purposes if you are going to be using it on a daily basis.
Pentium3 1400s/ Asus Tusl2-c / Kingston 512mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti-500 64mb / Sound Blaster Live! 5.1 SB0100 / 16x dvdrom / 3.5 Floppy / Enermax 420w / Win98se
Reply 28933 of 60068, by psychz
As an Amigan, I had never ever messed with Ataris, always thought of them as inferior (well, except for MIDI stuff). Recently I got my first Atari 520ST from eBay. The bundle looked right - it included a mouse, a red joystick, ten floppies (games), a power cable and a big fat SCART cable. Only it appeared to be in French; I saw an AZERTY keyboard so it most likely had a French TOS. As soon as I won the auction, I ordered a VGA cable for the monochrome hi-res, and the next day bid on a big red Steinberg SMP II SMPTE-MIDI interface for it 😈 (The last was an impulse bid as a couple of months ago I passed on a MIDEX and regretted it badly, even without owning an ST back then - that's how much of a hoarder I am...)
The attachment smp2.jpg is no longer available
As mentioned above, I was clueless about everything ST. Days were passing by and with more rational thinking before even receiving it, I researched a bit to see the various possibilities, only to get more and more depressed: the ST can't take more RAM easily, Cubase doesn't run with the stock 512kb, lack of blitter etc etc. On second thought, maybe I should have waited to get something better, and certainly not in French...
...but looking closely to the auction images, what I won appeared more like an STe...!
The attachment s-l1600.jpg is no longer available
Long story short, it indeed turned out to be a 520STe with blitter, which had at some point been upgraded to 1mb! (It's also indeed in French, but that's minor 🤣). Today I opened it up to upgrade the RAM with standard 4x1MB 30pin 70ns SIMMs, wrote Cubase 2.01 to a floppy so as to verify that the SMP II works and played some Lemmings on the TV with the SCART cable! It's like entering a new world...
Pics are from the auctions... Hopefully will take some myself as soon as I find more time. It's been sitting in my room for, like, two weeks and only today I managed to fool around with it 😢 Next plans are to fit in a CF-IDE adapter (I also bought an IDE interface for later), might consider a picopsu or something like that too, but the ultimate target is to make an ultra-barebone setup with a keyboard and two modules at most, and try to come up with a small track on it. Time will tell...
Stojke wrote:
Reply 28934 of 60068, by TheAbandonwareGuy
Can confirm, 9800s run hotter than hell itself.
In other news, the search for a reasonably priced GeForce DDR and Radeon DDR 64MB continues. I already have 256 SDR, and a S3 Savage2000. I want to complete the set of inital DX7 TnL hardware.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
Reply 28935 of 60068, by Deksor
@psychz if you want to upgrade TOS or just have it in another tongue, you can simply flash new TOS chips ^^
However how are you going to put an IDE drive in it ? There are Atari to IDE adapters now ? (I haven't checked the "st news" for a while)
Reply 28936 of 60068, by keropi
just received a used boxed but complete MediaVision ThunderBoard 😀
Reply 28937 of 60068, by Caluser2000
keropi wrote:
just received a used boxed but complete MediaVision ThunderBoard :) […]
That was my first ever sound card that I fitted to my old 286/16. Still have it too. The only thing I kept of that system.
Reply 28938 of 60068, by psychz
Yeah I'll have to check if they're socketed and go the UK TOS 2.06 route someday I guess... If they're not, I'd rather not touch them for now 😊
The ST IDE adapter is like a CPU bypass thingie, it's a pcb with an IDE header and a socket in which you place the 68k, and sits in the motherboard's CPU socket... Didn't have the time to check it out yet though, it's still shrinkwrapped 🤣
Stojke wrote:
Reply 28939 of 60068, by keropi
according to the registration card that is filled but never sent out, the previous owner installed it in a XT system for games 🤣
it's a good card , does what it says 😀
Reply 28940 of 60068, by Caluser2000
Got my IDE update kit ready to go into my Redstone Computers XT Turbo. Comprises of a XT-IDE 8-bit card, BigFoot 2.1gig 5.25" IDE hdd with cable.
The attachment 20190603_222840[1].jpg is no longer available
The system it's going in.
The attachment RedstoneXT.JPG is no longer available
Reply 28941 of 60068, by rikukos
That one is rare - Congrats!
Reply 28942 of 60068, by keropi
really? I would think uncommon but rare? 😕
Reply 28943 of 60068, by Grzyb
There's some cache on that board - that's why it's so fast.
386DX-25 systems usually lack cache, which makes them much slower than 33 or 40 MHz ones.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
