Reply 29320 of 30564, by CharlieFoxtrot
I had Diamond Voodoo 2 8MB card. Now I have Diamond Voodoo 2 12MB card.
Although I generally find 8MB V2s underrated compared to full 12MB cards, I today added eight 25ns chips on the empty spots on the back of the PCB. Not a complicated job, although these SOJ40 chips take some time to solder. Everything worked on the first try, so no poor joints or bridges and every chip was functional.
Reply 29321 of 30564, by Nexxen
Tested the SLI on 2x Voodoo2 12Mb (mismatched pair, thanks for the drivers!)
Unreal test looks a bit underperforming: https://youtube.com/shorts/4Zmc46ln5Lg?feature=share
After following the Vogons' guide to create a SLI cable from a floppy cable, it all worked perfectly with no issues.
Scanline Interleave was detected.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 29322 of 30564, by OVERK|LL
Cleaned up a customer's server room and got some KVM and Console stuff that might help with the retro rigs (probably just the KVM):
DD: Mac Pro 5,1 - X5690, 64GB, RX 580 - OCLP w/Sequoia
Projects:
- Hewitt-Rand 8088 - 640KB, 20MB, Hercules mono
- IBM PS/1 2133 w/Thermalwrong solder mod - ODP 486DX4-100, 32MB
- PCPartner VIB806DS w/233MMX, 128MB, G450
- Jetway J-TX98B w/P75, 256MB
Reply 29323 of 30564, by cyclone3d
Sooooo, I saved a bunch of cool stuff from being thrown out / recycled. Some retro and some not so retro.
So far, there are a couple laptops that could be considered at least somewhat retro that have tested good.
1. Dell Inspiron 9100 - ATI 9700m with P4 3.2Ghz. Needs a battery and will probably get a Northwood to cut down on heat. Will aslo get an SSD. Hoping to find an ATI 9800m to put in it but those seem to be super scarce.
2. Lenovo Ideabook Y500 with dual Nvidia GT750M GPUs. Probably going to put Windows 7 on this and maybe dual boot with XP even though SLI will not work in XP as far as I am aware.
Other stuff but not tested so far.
Denon receiver
Yamaha receiver
VHS/DVD/HDD player / recorder. This is going to be fun to check out.
Dell XPS Studio tower... No power supply. Core2 based. Standard ATX motherboard so if the one in there is dead, or maybe even if it works, something else may get put in there.
Dell Inspiron 5100.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 29324 of 30564, by pan069
CharlieFoxtrot wrote on 2025-02-28, 23:06:
Oh, cool. I just received yesterday 10 memory chips for the same project (2 spares). These were the ones I bought:
EtronTech Em614163A-25 EDO Video RAM for Retro Graphics Cards, 3dfx Voodoo 2
Reply 29325 of 30564, by Ozzuneoj
cyclone3d wrote on 2025-03-01, 01:22:
Sooooo, I saved a bunch of cool stuff from being thrown out / recycled. Some retro and some not so retro. […]
Denon receiver
Yamaha receiver
Dell Inspiron 5100.
Nice! I will say, gaming laptops with high end (mobile) GPUs from the early 2000s are pretty much unheard of where I'm from. I think the closest I have even seen is my wife's old HP HDX18 from ~2009 with a Core 2 Duo and a Geforce 9600M GT. Having a functional laptop with a P4 3.2Ghz and a Mobility Radeon 9700 is really cool. Looks like it might be around 9600 Pro - 9600 XT levels of performance if the specs online are accurate.
Regarding the dual GPUs in the Lenovo... even if XP can only use one, at least you'll always have a spare if one dies, eh? 🤭
Reply 29326 of 30564, by CharlieFoxtrot
pan069 wrote on 2025-03-01, 02:30:
I used ESMT’s (EliteMT) M11B416256A-25J EDO chips. Any equivalent 25ns 256k x 14 EDO chips these cards have should work just fine.
Reply 29327 of 30564, by zuldan
Recapped this Gigabyte GA-7VT600 (https://theretroweb.com/motherboards/s/gigabyte-ga-7vt600) I got for $20. Had to replace almost every capacitor. This board got hit by the capacitor plague really bad. A lot of the caps were leaking from the top. No damage to the board luckily. The board is now back and running. Rock solid stable.
The attachment 4F361F44-DBFB-464A-8E02-5684BA4728AC.jpeg is no longer available
The caps were really not happy. This a is 1000uf.
The attachment 640BF8D6-4EBB-4C79-B01C-C10258256474.jpeg is no longer available
Reply 29328 of 30564, by PcBytes
Prepping a K6-2 to test out my Kyro 2 card. Not sure what would be the best platform to test it on, but I sure as heck can say that it HATES my DFI AK70/Athlon 700 build.
Reply 29329 of 30564, by bjwil1991
Starting the recap process for the Zenith Data Systems Z-Note 325Lc I got recently that's in far better shape than the other one I had for a year.
I recapped the Sharp display with SMD tantalums from Console5 (sold for the PowerBook 180C that uses the same display) and took off the cap for the inverter board (ordered some on eBay since I didn't think about the inverter board needing a new cap). The system will get a full recap once I receive the new caps from Digi-Key (logic boards) and eBay (inverter board).
I cannot wait to see how it performs after doing a full recap. The logic boards are getting the SMD tantalum treatment and all of the radials will be replaced as well. The cap on the inverter board leaked and it's fortunate that I ordered those caps just to be on the safe side.
The system has a 387SL FPU with it and the original Conner drive died, unfortunately. But, it'll get my CF2IDE installed from the busted ZDS laptop and it'll be used once again and with a working display.
Reply 29330 of 30564, by RetroLizard
Installed Windows 2000 Professional, and gave the system a basic performance test. It seems to run well enough, though temps aren't ideal - probably gonna add some fans to the case.
I still want to do a memory test at some point to make sure things aren't faulty and add more hardware.
Reply 29331 of 30564, by cyclone3d
I guess this counts as retro.
Continuing to go through the stuff I saved from being recycled and got a TI-84 Plus Silver Edition graphing calculator working. It was released in 2004.
The batteries had leaked so I cleaned that up and there was really no corrosion to the springs.
It still would not power on so I took it apart and found that the contacts on the circuit board where the battery springs make contact had corroded.
Cleaned it up the best I could but the one pad had a crater in it. Those pads are quite large so I bent the springs so they would make contact in a different area on both pads. Put it back together and it came to life.
YMF7x4 Guide
Reply 29332 of 30564, by dominusprog
Fully upgrade the RAM to 1024KiB for the Trident 8900C. It doesn't make a difference in DOS, but Win 3.11 experience is now much more smoother.
The attachment 20250302_161743.jpg is no longer available
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 29333 of 30564, by PcBytes
Added a (what I presume is NOS?) Revoltec Air Guard fan to my recent Celeron 300A, and moved the old two wire fan to my Pluto based Athlon 600@800MHz (resistor modded).
Reply 29334 of 30564, by Trashbytes
Going to preface this with I dont know if this is retro enough to be retro but 2014 is not exactly modern either as far as PC Tech goes. If people object Ill move this over to the modern activity thread.
Got my hands on a late 2014 Imac with max specs for that time so I guess I will be taking my first foray into the Mac world, its a nice 27" 5k Retina, 4Ghz i7, 32Gb Ram, 1Tb SSD and a Radeon R9 M295X 4Gb so its nicely kitted out.
Not sure what model the i7 is but being 2014 I'm guessing its a 4790 4Ghz with 4.4 Turbo Boost.
This is the exact model https://support.apple.com/en-us/112436
Any suggestions for what software would be good for it ?
Was thinking my Ipad might be able to act as a drawing tablet for it, Ive heard this is possible.
I also want to try Linux on it so any suggestions for an appropriate distro would be awesome.
Reply 29335 of 30564, by DaveDDS
I've been recovering some older DOS versions that I found in a corner
of my workshop --- so I've made a major revision to my tool to boot
real DOS under DosBox - now CPU/SPEED/Drive options, and 9 different
versions of DOS:
MSDOS2.11,3.31,4.00 PCDOS2.10,3.30,7.1 FreeDos CalderaOpenDOS PTSDOS
Re: DosBox BootfloppyDisk
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 29336 of 30564, by CMB75
Been fiddling around with old floppies and drives, to me it's absolutely astounding that those disks from the 80s still work perfectly. Haven't had one bad in 30+ disks I tested.
Working on finding some motivation to continue a project I stalled last year... I guess I'll start with cleaning and re-greasing some of the old drives.
Reply 29337 of 30564, by oldhighgerman
CMB75 wrote on 2025-03-04, 06:39:
O NO. They do not work perfectly. In fact it may be that if you actually accessed them once, it could have been the FINAL TIME. This isn't said often enough. Upon finding an old disk, do NOTHING with it prior to reading it into an image/file. You may live to regret it otherwise. Do not try to determine its contents (if it's unlabeled, mislabeled). Don't do a directory scan. Just hit it with whatever people are using these days. I used to use ImageDisk by Dave Dunfield.
I took have had lots of success with old floppies. But often times I've found they're only good for 1 access. Then it's bye-bye. For the rest of eternity.
Reply 29338 of 30564, by Trashbytes
oldhighgerman wrote on 2025-03-04, 07:40:
It honestly depends on the quality of the disk, later ones fare better than the earlier ones due to higher quality production methods and materials but its also partly due to how the disks were stored, if they were stored in a cool dry place then the chances of them failing is pretty low.
The main thing you should do before using them is to make sure the drive you are using is in top condition with clean heads and that the disk surface itself is not contaminated.
Ive gone through hundreds of disks at this point for my Amiga and C64 backing them up and sure you get failures but the vast majority worked fine and still do. I found that early PC disks tend to be the worst for failures, especially the 360k and 720k ones .. the fabbing quality of them was .. suspect even back in the day and they also tend to suffer from mould more than the 1.2/1.44 ones do.
On the subject of backing up disks I find the Grease Weasel to be a excellent bit of kit to own, it pretty much lets you read/write any disk via the PC which makes backing them up super easy, naturally you may want to use something like Flux Engine in combination with the weasel to increase the disk formats it can read.
IIRC there is also the Applesauce hardware that can read old Apple formats allowing you to back them up to PC.
Forgot to mention the Kryoflux ..its for the crazy ones out there with cash to burn and who require the lowest level of reading available, IIRC this thing can read any disk you throw at it since it doesn't care in the slightest what format it is. Its some truly black magic hardware that I secretly want a reason to buy ...cant justify the cost of it however.
Reply 29339 of 30564, by DaveDDS
Been fiddling around with old floppies and drives, to me it's absolutely astounding that those disks from the 80s still work perfectly. Haven't had one bad in 30+ disks I tested. ...
Re: Floppy identification...
