Reply 29540 of 31643, by schmatzler
I got a Thinkpad 560X in perfect condition, with the original SCSI CDROM, floppy drive and recovery CDs.
Dumped those on archive.org, since no one had done it already: https://archive.org/details/etukfa-0
Such a great machine. No rubber anywhere, no pain. I only have to fix the hinges, because they are so stiff, they will break the case if not treated.
Reply 29542 of 31643, by gerry
Shponglefan wrote on 2025-04-14, 12:45:
Bought some new shelving to try to organize some of my PC builds / cases.
the first thing i thought was "what kind of KVM can cope with all that!" 😀
Reply 29543 of 31643, by vutt
From "today I found out" series - Second Reality DOS demo will not crash on faster machines if you keep files in drive root or simple X:DEMO/DEMOS directory.
I can run it now on my fast PIII rigs. If I really want to catch my mid 90-ies feel then I setmul l1d CPU. Feels like back in days when I had 486 SX-25...
Reply 29544 of 31643, by BetaC
Today I have finally gotten my third attempt at a 486 machine to seemingly stop fighting against me. I can take better pictures of the case if anyone wants, as I'm unsure of what it actually is.
The attachment IMG_4700.jpg is no longer available
I am using the same old GA486-VT motherboard that I bought about four years ago with an external battery pack. The big change is using a full 32MB of RAM that is admittedly running at 70 instead of 60ns thanks to me not having too many options available and using a WD 90C33 based VLB card for video (instead of my boxed ATi Mach 32VLB) and a Promise EIDEPro ISA card to allow me to access the entire HDD instead of just 503MB. Hell, I even threw in an ethernet card for the sake of it.
TES Arena is running basically perfectly outside of weird times where certain dungeons run slightly fast and others slightly slow, and after disabling the internal cache it seems to be running Wing Commader perfectly. I also now have the option of throwing in a Pentium Overdrive and or an AMD 5x86 133 if I want to speed things up for specific games and such, though the DX2/66 seems to be my sweet spot to cover things that were otherwise annoying to hit the speed of with my Pentium.
Reply 29545 of 31643, by LoK
BetaC wrote on 2025-04-16, 23:33:
No idea, but search in google images give this:
https://www.youtube.com/watch?v=iA0DZf8z5ao
https://www.youtube.com/watch?v=D9U03YbPGN4
Reply 29546 of 31643, by BetaC
LoK wrote on 2025-04-17, 00:59:
No idea, but search in google images give this: […]
Wow, it's the same case as his 🤣. Awesome.
Reply 29547 of 31643, by wierd_w
Moar play with the penplotter, mostly.
I've been doing experiments with modified pens again.
Still keep coming back to refilled pilot v5 pens.
Reply 29548 of 31643, by dominusprog
I've bought another SS7 board and a new hard drive. Installed the Windows ME, all the drivers and updates. Tried a bunch of benchmarks, DirectX games and all works but OpenGL games (to be fair I only tested the Quake II engine games) cause the system to freeze. So, any ideas?
4in1443v VIA Driver and nVidia Detonator Driver v12.41 (Tried different nVidia drivers with no luck).
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 29549 of 31643, by wierd_w
ME is kinda... not a good choice, IMO.
Win2k had much better driver support and reliability, and win98SE had much better DOS support.
I'd do dual booting 98se and 2k on a super-7.
Reply 29550 of 31643, by dominusprog
I don't care about DOS support. Thing is it was working before, same graphics card, same chipset and same CPU. I'm suspicion of the VIA 4in1 driver.
Reply 29551 of 31643, by flupke11
Outfitted my Dual Xeon Dell Precision T7500 with two GT96o 2GB in order to either test SLI or PhysX.
WIN7 on Samsung SSD on seperate SATA3 Controller, dual boot with Linux Mint.
Will be my 2010 gaming rig.
Reply 29552 of 31643, by dominusprog
dominusprog wrote on 2025-04-17, 17:07:
Make a fresh installation of ME and this time installed the VIA 4in1 V435, same thing.
Reply 29553 of 31643, by dominusprog
dominusprog wrote on 2025-04-17, 19:23:
Downgrade the BIOS with the backup I've made before updating, now it doesn't recognize the 60GiB hard drive. I'll try with a smaller drive.
Reply 29554 of 31643, by LoK
It looks like it was manufactured by Fountain Technologies, they made them for Quantex and Pionex.
Re: Classic case designs
https://forum.vcfed.org/index.php?threads/vin … -computer.48081
Reply 29556 of 31643, by Linoleum
I jerry-rigged my own custom Sound Blaster Franken-drive! It's a mash-up of:
The internals from a Sound Blaster X-Fi Drive
The front panel and dial buttons from a Sound Blaster Audigy 2 Drive (de-badged using a magic eraser)
A USB extension cord swapped in for the old FireWire connector
All connected to an Audigy 2 card and a NEC USB 2.0 card
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 29557 of 31643, by clownwolf
I practiced installing a Zalman zm-80 Passive VGA Cooler. It took about 20 minutes, very easy to mount.
The attachment 20250419_210726.jpg is no longer available
The test card for today is a GeForce 2. The small heatsink is what was cooling it before for comparison.
The attachment 20250419_210931.jpg is no longer available
The back heatsink is crooked, but its an easy fix. I overtightened one of the screws onto the rubber washer so I just need to loosen it up a bit.
Since the point of upgrading the heatsink is to improve the card's lifespan, I will not be running them passively and will probably ziptie a fan on.
Reply 29558 of 31643, by dominusprog
Problem solved! Turns out, setting the AGP to turbo mode (2X) in 4in1 version 435 is not a good idea. I'm assuming that version 443 enable the AGP 2x by default, which is such a shame that the chipset can't work correctly in 2x mode.
Reply 29559 of 31643, by Linoleum
Bought some new shelving to try to organize some of my PC builds / cases. […]
The attachment PC Tower Rack.jpg is no longer available
Meanwhile, my workbench is an absolute mess which will be my next priority...
The attachment Workbench mess.jpg is no longer available
Any AT cases collecting dust in there? Asking for a friend... 😉
PS2 30/286, SBP
