End of 10
Reply 300 of 335, by Ozzuneoj
Still on Windows 10 here.
I'm glad to hear they are extending the ESU officially. I'm sure they are aware of people using various methods to manually activate the 3-year ESU program (October 2028) that is normally exclusive to enterprise customers. Microsoft is already doing the work of updating Windows 10 until at least that date, all they have to do is flip a switch so that non-enterprise users get the updates too. That is what they have done here for one extra year.
I have used Windows 11 on several computers and I have yet to find anything I prefer about it. I have heard that it has slightly better handling of multi-monitor configs... basically allowing the cursor to blend smoothly from one screen to the other, but I haven't tested this myself.
I have said it before, but, the last four years since Windows 10 had its last feature update to 22H2 has been the SMOOTHEST and least problematic period of computing for me for as long as I can remember. Everything just works. I never get garbage installed automatically on my system. I have never had anything related to Copilot or AI installed automatically on my system. Drivers do not auto-update. It just does things when I tell it to, and I get security updates as they come out. I haven't had an issue with any updates on my machine aside from the Defender update that finally put an end to programs freely using WinRing0 (which has been a good thing, since it is a security risk and most programs seem to have moved on to alternatives- FINALLY).
I'm sure Windows 11 is slowly improving, but I just have no reason to switch at this point. I remember reading about some kind of responsiveness-focused update they were planning to do recently... did that actually fix the sluggish context menus finally? On the one Windows 11 system I have in the house (a game server that doesn't get used much - i7 8700, 16GB DDR4, NVMe) I did all of the tweaks I could find and the context menu still has this weird short delay when opening which just makes the whole system feel slightly sluggish. In Windows 10 I can drag my mouse across the desktop and right click as fast as humanly possible and it will open the context menu every time. On Windows 11 there was always a slightly delay so this isn't possible. If they fix that at least it would be a step in the right direction.
The start menu is also horrible. It has so much wasted space once you turn off all of the garbage, and the shut down menu being toward the middle rather than the left side is strange. I also dislike the new layout of task manager. The icons they recycled from other parts of the OS don't really make any sense so are not very intuitive and I find them distracting (a speedometer\fuel gauge for startup?). There is so much wasted space compared to the task manager in Windows 10, and nothing has changed in the actual functional parts of the window.
So, yeah... I don't see any reason to switch on most of the PCs in my house. I really only see downsides to using 11 since no one in my home really wants or cares about OS feature updates. We just want the OS to shut up and exist, securely, while we run the programs\games we actually want to run without being interrupted or prevented from doing so.
Until things genuinely stop working properly because of a lack of support, I'll be sticking to 10, but that will probably take a while since 10 and 11 are not that much different under the hood. If 11 gets some really amazing new feature that would actually benefit me, I'll wait to see how it impacts everyone to determine whether it is worth the upgrade. No sense being a guinea pig.
Reply 301 of 335, by The Serpent Rider
Realistically, LTSC is the only sane option. Both for Windows 10 and 11.
Reply 302 of 335, by Ozzuneoj
The Serpent Rider wrote on 2026-06-26, 18:37:
I make no claims as to my sanity or that of anyone else I know, but I don't know of anyone personally (not on the internet) using LTSC. It's probably fine, but it is hardly the only option for a stable Windows experience.
Reply 303 of 335, by myne
I'm surprised they haven't yet dropped the TPM requirement.
I'd be betting that's the limiting factor behind the bulk of the laggards.
I guess they're betting on refresh cycles and attrition to make the massive PR problem manageable.
(Yes, I know there are ways, but most people use PCs like they use cars. It's just a tool. No means no.)
I built:
Reply 304 of 335, by Robbbert
Never had windows 11 because of the hardware requirements. If they dropped the TPM thing then I could "upgrade" 2 machines at least. I didn't want to shell out for a new computer just because they said so, and given the costs of desktops these days...
So, I'm happy to see the extension of ESU.
Reply 305 of 335, by lti
When Windows 10 went EOL, 11 didn't feel any less responsive to me, and I thought the increased system requirements were a response to those shitty laptops with 32GB eMMC storage. Today, Windows 11 needs a minimum of 128GB boot drive, and it takes 10 seconds to open a right-click menu (and watch everything draw like an old computer with unaccelerated video) on a high-end workstation.
Also, Microslop never fixes anything, and that's a behavior they had back when they were still Microsoft. Windows still replaces my graphics driver with a much older and broken/incompatible one. People were complaining about that when Windows 10 was still beta, and it never got fixed 11 years later. OneDrive still corrupts your local cache so hard that the only way around it is to run Chkdsk to make your files accessible again (for a month), and it still silently fails to sync while claiming to have succeeded. 100% of OneDrive users have lost data, but some of them might not know it yet.
Reply 306 of 335, by zapbuzz
videos on youtube are saying ESU's till 2027 but I use 11 now.
Reply 308 of 335, by The Serpent Rider
myne wrote on 2026-06-27, 00:11:
That was the original bet, most likely, and it would have worked 10 years ago, but now Microsoft is also partially responsible for why people won't upgrade any time soon.
Reply 309 of 335, by aVd
I see nothing bad in "end of 10" in combination with "11 disaster" 😀
I like the quieter planets, this one became pretty noisy 😀
Reply 310 of 335, by myne
The Serpent Rider wrote on 2026-06-27, 07:23:
MS have been ignoring customer requests for a cut down without crippling windows option for 30 years.
It's always been OK eventually.
Reality is, retail sales are a fraction of their revenue. It's mostly new pc oems so who cares?
I built:
Reply 311 of 335, by Munx
I keep having to choose to boot Win10 instead of Manjaro because some of my games still need Windows. And to this day I keep getting these stupid ads that all want my data and card number with no option for "NO, DO NOT ASK EVER AGAIN" - I have to actually ctrl-alt-del and reboot to avoid interacting with it. Having to use W11 at work I know that it will get even worse, so Windows 10 it will stay for as long as it functions.
My builds!
The Underdog - The budget K6
Reply 312 of 335, by dr_st
Robbbert wrote on 2026-06-27, 00:48:
Power users know how to circumvent the requirements and upgrade. The non-power users are exactly those that Microsoft doesn't want to support with "incompatible" hardware on Win11.
Munx wrote on 2026-06-28, 09:31:
I used to get this for some time. I think it was because my PC kept crashing and it didn't process the registry change that tells I've already finished with this process. Isn't there an option to decline everything when you click "Continue" and have it stop asking? Is that Win10 Home?
Reply 313 of 335, by UCyborg
My Win10 20H2 has some strange bugs, from mysterious empty ServerKey registry key under HKCU keep appearing to random power transition failures involving the unused network adapter unless I disable it. And ability to log registry key changes to find out what processes even does this ServerKey thing doesn't work at all.
Then there's the thing with taskbar duplicating pinned items when moving windows between monitors, which was probably never fixed, MS rather replaced the taskbar with even crappier one.
My computer is a mess (as much as I am...), so much crap to sort and clean, which I've been procrastinating for years. I should install another version at some point, but can't due to all the crap in the way and the thing is daunting due to all little things to put back how I like it and me never having them written down somewhere.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 314 of 335, by Robbbert
And to this day I keep getting these stupid ads that all want my data and card number with no option for "NO, DO NOT ASK EVER AGAIN".
I get that screen sometimes, I just click the "Remind me in 3 days". The thing that does work, although a little inconvenient, is to disconnect the network cable before you boot, wait for the desktop to appear, then plug it back in. With the cable out it never asks.
dr_st wrote on 2026-06-28, 11:29:
I could be a "power user" if I wanted to, but I have no real need to use Windows 11, therefore if they want me to use it they need to make the first move. I'm perfectly happy with Windows 7 and 10 and will use them for as long as possible.
Reply 315 of 335, by Munx
Win10 Pro. I forget now, but I do recall that "coninue" just leads to a window to accept terms and whatever.
Robbbert wrote on 2026-06-28, 12:28:
Things is, I should not be reaching behind my PC every time I need to boot and avoid intrusive ads.
My builds!
Reply 316 of 335, by Ozzuneoj
Have you ever just hit continue and then declined the stuff they ask you about? I haven't seen one of those on my main PC running Windows 10 Pro in several years and I have never given Microsoft any payment or personal info at one of those popups. Most likely this started with the last major update for 22H2 and it is just asking if you want to use some of their other features\products. If you say no, it goes away.
For what it's worth, I don't use One Drive, Windows Backup, CoPilot, Microsoft 365 or the online "free" versions of Office apps.
I do use Winaero Tweaker to disable telemetry, ads and assorted other things, but that is unrelated to these full screen messages.
Reply 317 of 335, by lti
You can decline everything, but the same thing comes back later. There was a setting to disable that full-screen prompt, but I don't remember where it was now. I don't have any Windows 10 machines anymore.
Reply 318 of 335, by dr_st
They don't care if you use it or not. Neither should you, really. I only have a couple of Win11 systems, one of them being my work laptop. Like you, I'm perfectly happy with Win10, and even Win7, where appropriate (retro PC).
Munx wrote on 2026-06-28, 14:09:
So just decline everything, and it should not bother you again. At least until you install the next Feature Update, of which there aren't any and will never be any after 22H2.
Reply 319 of 335, by gerry
Ozzuneoj wrote on 2026-06-26, 18:17:
me too, i'm sure MS just checked numbers and realised migration to win 11 wasn't happening as originally thought (economy, mad ram prices etc) and decided to extend to avert poor outcomes for MS (users getting compromised - supported or not it tarnishes MS, keep customers on windows means keeping them on other MS things etc) where some of the cost of security updates is already committed (corp support)
likewise win 11 is ok it seems, might improve - just in no rush to move really. Such a different feel to back in dos/win3.1win95/98/me/2000/xp days
