Reply 300 of 492, by ruthan
appiah4 wrote:
I installed and tested an FM801 card on an i815EP motherboard yesterday and it worked 100% flawlessly both in Win98 and pure DOS.
Its regarding of our chart..
Sound Blaster PCM won't work on anything newer than the i8xx series of Intel chipsets.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 301 of 492, by appiah4
I didn't disagree with that, I was just sharing my experience.
Reply 302 of 492, by LSS10999
Some i815 motherboards can be very compatible... I once had one and SBLive! worked with it.
However, as i815 is accompanied with ICH, it's uncertain whether DDMA-dependent cards (like YMF7xx) would continue to function there. The 440BX/PIIX4 appeared to be the last chipset to incorporate both PCI legacy DMA technologies (PC-PCI and DDMA, with the former usually requiring a physical signal connection). Most southbridges after that incorporate only either one of the two (Intel incorporated PC-PCI up to ICH5, while VIA incorporated DDMA, the last recognized one is VT82C686B, not sure about future VT823x ones but some sound cards continued to work).
Reply 303 of 492, by appiah4
DDMA is an issue, AZF3328 did not work on the same i815EP board due to DDMA issues. FM801 uses a different method and it works.
Reply 304 of 492, by ruthan
SB live is working even with i865.
Reply 305 of 492, by appiah4
Yeah but it sounds like shit 🤣
Reply 306 of 492, by MKT_Gundam
How is the compatibility of PCi soundcards on Via VIA P4M800 Pro chipset?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 307 of 492, by ruthan
We dont have entry for it, but it would be silimar to P4M900+VT8237S LGA775 entry.
Reply 308 of 492, by LSS10999
It's mainly the southbridge that matters. The VT823x southbridges are good for PCI sound cards.
P4M800/Pro mainly uses VT8237R so you shouldn't have any problem with ESS PCI audio cards.
Reply 309 of 492, by MKT_Gundam
Zeliard on ESS Maestro-3 ES1980S dpont sound that bad:
https://www.youtube.com/watch?v=t7r6oaT82a4
Reply 310 of 492, by ruthan
I got ES1373 card, in compatibility list is not too much about it. Anything special about this card? I see at least that its supporting SB 16.
Reply 311 of 492, by Kamerat
ES1371/ES1373 are the AC97 certified version of the ES1370. Should do SB16 with Creatives driver, don't think they relased a DOS driver for the ES1370 so only SBP and Soundscape support for that one.
YouTube channel
Reply 312 of 492, by canthearu
FM synthesis on the ES1371 is pretty broken though. (and that is putting it mildly)
Reply 313 of 492, by appiah4
I believe 1371/1373 are 48KHz instead of 44KHz and that messes up with FM Synthesis greatly?
Reply 314 of 492, by LSS10999
I don't think sampling rate has anything to do with FM synth on those cards. The Ensoniq/Creative PCI series don't have FM synthesis at all. It's emulated via wavetable and it sounded rather different from a real OPL3.
These cards appear to be playing FM music as if it was MIDI music, as changing MIDI modes between MPU401 and MT32, as well as loading different ECW files, could change how FM music sounds on those cards. Still, they sound rather different compared to real OPL3, and you'd better off choosing General MIDI instead of Adlib in games that supported such, for better music experience.
SBLive! on the other hand did manage to emulate FM nearly identical to the original, but how exactly that was achieved was unknown as on the surface, the DOS emulation technologies looked similar...
Reply 315 of 492, by appiah4
That is not true, SB Live!'s FM sounds nothing like OPL3.
Reply 316 of 492, by canthearu
The SB Live's FM sound is more like CQM emulation. Still much better then trying to play FM sound through a wavetable, and generally a better result than the strange results I get from vortex based cards.
edit: insert missing word
Reply 317 of 492, by appiah4
Vortex is indeed pretty terrible. 🤣
Reply 318 of 492, by LSS10999
Not sure about CQM (as AWE64 Gold also appeared to be using one)... at least from games that I've played I could hardly pick up any apparent differences between it and a real OPL3. Maybe there are some places where one can actually tell them apart. Besides, I don't remember seeing Creative PCI cards featuring physical FM synth/CQM of any kind, does SBLive! (or EMU10K) really have such integrated in the IC?
As for Vortex series... not sure whether it really contains OPL2/OPL3 logic but it's definitely not accurate. At least on my Vortex sound card, the pitch seemed off (such as a C sounded like a B/C-flat, though this might not be accurate and could differ between cards), but the tone itself is mostly correct. Maybe it's just wrong frequency being put in the FM logic...
On the other hand, the post-Solo ESS audio cards (Maestro, Allegro etc.) seem to also play FM through a wavetable (sounded in a similar way to the ES137x series), as they no longer feature the ESFM synthesizer.
Reply 319 of 492, by yawetaG
They just translate FM instructions to General MIDI PCM or other PCM patch set compatible instructions. Depending on the set of PCM patches used, some instruments will be more accurate than others. I personally cannot hear the difference between some of the instruments used when playing back FM music through my AudioPCI and the OPL of my Vibra 16 sound card, while other instruments are clearly different.
I expect that if a PCM patch set were to contain patches based on the sound of a real FM sound card/synthesizer (which can be identified fairly easy by their characteristic timbre), the emulation would be a bit more accurate.
