ESS AudioDrive (ES1868) - a surprisingly good ISA sound card
Reply 300 of 318, by mockingbird
Kordanor wrote on 2024-04-15, 16:29:
Yeah, thats what I tested. I do get the music, but I dont get the sound (neither the thud, nor the death sound).
I tested it with a Soundblaster Live (emulated as SB16 in DOS). With that card it works. But with my ESS1868 I only get the music. And a totally broken soundeffect on some driver files (which are so loud and broken you immediately want to restart the PC). Can you attach the drv file which you use? Thats likely also different just by using a different version of the game.
Are the drivers (outside of the file) relevant? I tested it with ESS Drivers as well with unisound though, and it doesnt seem to make a difference.
It's in the "SBPRO" directory from the aforementioned thread you linked to (ct-voice_all.7z). The version I downloaded initially had a 'ct-voice.drv' from 1996, and that didn't work (maybe for SB16?). Are you initializing ESSCFG.EXE? Do you have the SET BLASTER paramater defined? Definitely try ESSCFG instead of Unisound.
(Decommissioned:)
Reply 301 of 318, by Kordanor
Which of thhis file did you use? There are 5 files. None of them worked for me, but at least I could start nailing it down to the one which works for you.
Yes, ESSCFG is initialized with A:220 I:7 D:1 B:330 J:D
SETBLASTER had not been defined before on ESS, I did add it, but it didnt change anything. I only used setblaster with UNISOUND before.
Reply 302 of 318, by mockingbird
Kordanor wrote on 2024-04-15, 17:02:
Try setting the card to interrupt 5 instead. In the "SBPRO" directory, I used the one in the '1993' subdirectory.
(Decommissioned:)
Reply 303 of 318, by Kordanor
mockingbird wrote on 2024-04-15, 17:37:
Tested that as well. Didnt change anything.
Here is a video demonstration, also showing the setting and whatnot. Be warned. The end is super loud!
https://youtu.be/-_khSkjuEaA
Reply 304 of 318, by mockingbird
Kordanor wrote on 2024-04-15, 18:02:
Herr Kordanor! You have to move that "rem" statement to the next line in that batch file... Otherwise, burn.exe will not parse the command line parameters correctly. I can't believe you didn't catch that right off the bat.
(Decommissioned:)
Reply 305 of 318, by Kordanor
mockingbird wrote on 2024-04-15, 20:47:
Interesting, wasn't even aware you can't do rem mid-line. The file was written that way by the setup program (I just changed the IRQ for testing in there). That said, I changed it and it doesnt help unfortunately.
Reply 306 of 318, by mockingbird
Kordanor wrote on 2024-04-15, 21:06:
Oh, sorry then, I stand corrected. You are missing "/E:" for the second DMA channel in your ESSCFG.EXE initialization routine in AUTOEXEC.BAT. Try '/E:3'.
(Decommissioned:)
Reply 307 of 318, by Kordanor
Doesnt work either.
However I just installed Burntime from a different source now.
My Original Installation is the Floppy Release (I own that physically). There I got the sound to work only with the SB Live Emulation
I now used an Installation which came with the PC Action Magazine (also a legal copy). There the Copy Protection is cracked. In this instance there is no bat file (you got to start with the burn.exe) and the game asks on every start where the savegame location is. In this installation as well, I had no sound. But there copying the ct-voice from SB Pro 1993 actually worked.
So I still have no idea, what is the root of the cause, as the floppy version works as well (just not with this soundcard). I also tested just running the floppy version with the burn.exe, but that one still doesnt work.
In any case I got it working, and I thank you for your help. Would still be interested in finding the cause, but it's not of "high importance" anymore. ^^
Reply 308 of 318, by Kordanor
Some turn of events unfortunately, despite what I wrote before, it still does not work.
So I got 2 versions of Burntime, both german.
3.5 Disk Version: With copied drivers: Horribly broken sound when attacking dogs. However, the voices of vendors actually work!
PC Action Version: With copied drivers, sound when attackings dogs is fine. However, when going into any shop it first spat out an error: dma buffer is too small and I should set it to 48. So I did that (also tested 64, 128).
When I try it with that bigger DMA buffer, I can enter the building, but either after the vendor had is voiceline or if the voiceline is triggered a second time, the PC will just restart.
So essentially in both versions of Burntime, it still doesnt work.
I also tested my SB Live again (SB 16 emulation), and the results are...weird.
First, the game does run a little bit slower. I used the 10 Driver here (oldest). On the 3.5" version the sounds (attack) and voice (vendor) work fine, and the game doesnt crash. I then tested the PC Action version again, with the same driver. It will lead to the same crash as with the ESS.
Also this was all without that DMA Buffer change.
However I would rather not use the SB Live because the MIDI Music doesnt exactly sound nice.
This all lets me believe that something is wrong regarding the resources the ESS card uses with that driver, possibly in combination with some issues in the game.
Reply 309 of 318, by mockingbird
Kordanor wrote on 2024-04-16, 15:46:
I will test further and report back.
(Decommissioned:)
Reply 310 of 318, by Kordanor
I might have found a solution again.
I took the floppy version of the game. Then I copied over all the ANI and VOC files from the CD Version, and this seems to work without crashes (note that the unmodified files work with the SB Live card). So it might be that the crash is inherent to the CD Version. I hope that this will work now, but ofc there is still something wrong somewhere. I will also send you a PM.
Reply 311 of 318, by mockingbird
Kordanor wrote on 2024-04-16, 16:22:
Thanks. I tested with the CD version - it works fine. I tested it and I do hear the voices at the vendor after a trade is enacted. The cd "installer" makes a very sparsely populated "burn" directory on C:\. The CT-VOICE.DRV (SB Pro 2 version) must be manually copied in there as well.
If you're getting crashing - this in my opinion could mean instability with your system. Are you using a 486?
BTW, I also tested with my Opti 82C930 - that worked fine too.
(Decommissioned:)
Reply 312 of 318, by Kordanor
I am using a K2+ @200 MHz, I had no stability issues with any other game so far. And as mentioned it does work with the Floppy version. So I can't really nail it down to a single thing.
CD version crashes on both cards, so it can't be the card.
But because it works with the "floppy" version, it would mean it should be the game. But apparently on your machine it works, so it must be some weird combination.
Reply 313 of 318, by mockingbird
Ok, as long as it's working... I recommend something like playing through Doom for a while to test stability.
(Decommissioned:)
Reply 314 of 318, by Kordanor
mockingbird wrote on 2024-04-16, 20:05:
There are no stability issues otherwise. Already played through lands of Lore for Example (16h), Jagged Alliance (50h+) and Jagged Alliance Deadly Games (50h+)
Reply 315 of 318, by lsz010
Hi,
I do not know if it is the right place but I'm looking for some help. I recently received an SC1868-3D Rev 1.10. Many caps are missing, guess this is why I do not have sound. Unisound detects the card, on this level everything seems fine. By any chance, can somebody tell me capacity/voltage of missing caps? C75, C76, C57, C58, C17
Br,
L.
Reply 316 of 318, by e8root
I recently acquired ES1688F non-PnP card
It is the same BTC model as can be seen and heard in this video https://www.youtube.com/watch?v=FJJVdoMvVbU
It has PnP/non-PnP jumper but has no jumpers for changing IRQ or DMA so whatever manufacturer decided will be the only available option in non-PnP mode. Thankfully its IRQ7 so the card is pretty much plug and play sounds in non-PnP mode. I tested it in DOS in bunch of games, Windows 98SE and even works just fine in Windows XP.
ESS are my favorite sound cards for DOS due to superior ESFM quality compared to anything else. And I am not even talking about OPL-clones but OPL2/3 itself sounds like cheap clone of itself due to how Yamaha deliberately made these chips don't sound too good to prevent them to compete with their more expensive offerings. ESS took the tech, improved it and based on that made OPL2/3 emulation - it just sounds better than OPL. Calculations are obviously done at much higher precision than genuine OPL chips.
Reply 317 of 318, by Grzyb
e8root wrote on 2024-07-06, 21:37:
UNISOUND should be able to configure it in both PNP and non-PNP modes - see the "/NOPNP" parameter.
ESSCFG may work as well - https://web.archive.org/web/20000229161511/ht … vers/driver.htm
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 318 of 318, by Kordanor
Stumbled over another game which got sound issues.
I mentioned before that Jagged Alliance Deadly games had issues, where the Soundblaster Sound had a heavy white noise, while the Soundblaster Pro noise was buggy. However this was sold by loading a custom sound driver into the game.
But it looks like Toonstruck has a similar issue.
The game has sound if you select the Sound Blaster and ESS Audio drive. However there is an insane level of white noise. Similar to what you had in Deadly Games with the SB setting.
The SB Pro setting does not work in Toonstruck.
I also tested via Unisound drivers but no difference.
As Toonstruck doesnt use midis I think it's a good game to be played with just a newer PCI card or with more modern windows PCs. But this game seems to have issues with the ESS card.
Just wanted to drop this here. If you have ideas what I could test, I can try it out, but in this case it's no issue for me to just use a different soundcard.
