HIDman - USB to PS/2 converter (Open Source)
Reply 300 of 583, by rasteri
Eivind wrote on 2024-05-25, 17:46:
About the button - if you decide to move it to 3.4, you'd still need to keep some kind of way to short 4.6 to ground for bootloader mode, right...?
I'll make sure my firmware checks for 3.4 before it does anything else. So 4.6 will only be needed if the firmware gets corrupted somehow.
As a last resort to de-brick the device you could short C5 using a pair of tweezers.
Reply 301 of 583, by Eivind
rasteri wrote on 2024-05-25, 18:09:
Ah, so you're able to enter bootloader mode from a running firmware as well as by shorting 4.6 to ground at startup? That should do the trick then! 😀
Edit: oh, and nice work on placing the crystal, looks like it fits perfectly!
TinyLlama 3
ITX-Llama motherboard
TinyLlama SBC
Reply 302 of 583, by snipe3687
Eivind wrote on 2024-05-25, 18:14:
This has been a very interesting thread to watch! I love seeing the different troubleshooting steps taking place.
Reply 303 of 583, by rasteri
snipe3687 wrote on 2024-05-25, 21:12:
glad you're enjoying it 😀
Reply 304 of 583, by rasteri
Port 3.4 seems to work great for the switch. I think hidman is just about ready for a 1.0 release!
Reply 305 of 583, by Eivind
rasteri wrote on 2024-05-28, 17:15:
That's awesome! Will you be selling any of these pre-assembled?
Also - for connecting the box to a computer using PS/2, is there anywhere one can buy male-to-male PS/2 cables...?
TinyLlama 3
TinyLlama SBC
Reply 306 of 583, by rasteri
Eivind wrote on 2024-05-28, 17:27:
Yeah I'll probably get a small batch made up. And I found my cables on ebay. male-male ps/2 cables were often used on old KVM switches so they're not too hard to find spares of
Reply 307 of 583, by Eivind
rasteri wrote on 2024-05-28, 17:34:
Heh, yeah I probably should have done an ebay search first - found plenty! 😀
Are you having JLC or someone else do the board assembly or do you order bare boards (with stencils)?
TinyLlama 3
TinyLlama SBC
Reply 308 of 583, by rasteri
Eivind wrote on 2024-05-28, 17:51:
PCBway, Your Trustable PCB Prototype Partner!
(they're my channel sponsor so I kinda have to use them, but they do great work and I get a discount)
Reply 309 of 583, by Eivind
rasteri wrote on 2024-05-29, 10:48:
😁 How does assembly work with them? I've been using JLC exclusively because of their enormous inventory of parts (LCSC) and low prices. Is there a self-service solution with PCBway where you pick your parts from different sources yourself, or do you just upload a BOM and they get back to you with component prices and sources...?
TinyLlama 3
TinyLlama SBC
Reply 310 of 583, by rasteri
Eivind wrote on 2024-05-29, 10:56:
You just upload a BOM, they figure everything else out. Although I generally pick chinese components anyway (or tell them to pick chinese equivalents) because they can get hold of them quicker/cheaper.
I did get JLC to price up a project a couple years back, but their extra charge for certain components made it more expensive than PCBway. Maybe that's changed now though.
Reply 311 of 583, by ubiq
I built one of these a couple months ago. It didn't work with the USB hub in my VGA KVM, but I wasn't expecting it to, based on where the codebase was at, at the time. I was just thrilled it worked as well as it did - very slick!
I saw there's been some activity since then - I built the latest firmware, but still no go with my KVM. Reading the previous page, it looks like I should try the external crystal mod, huh?
Reply 312 of 583, by ubiq
Could I get a part number for the crystal you're using? (Or an updated BOM.csv? 😉) Other than package/freq, not sure what exactly I'm looking for on Digi-key and have only narrowed it down to a possible 200 different ones. 😅
Reply 313 of 583, by rasteri
ubiq wrote on 2024-06-02, 01:06:
Latest commit has a BOM 😀
(although tbh if you're going to bodge it it doesn't really matter, as long as the frequency is correct)
Reply 314 of 583, by ubiq
rasteri wrote on 2024-06-02, 20:05:
Sweet, thanks!
Actually, if I'm putting in a parts order, may as well get some new PCBs at the same time.. 😁
Reply 315 of 583, by rasteri
ubiq wrote on 2024-06-03, 03:39:
Sweet, thanks!
I should add, I haven't actually tested this revision yet. Order at your own risk!
(I have some on the way soon, though. couple of weeks and we'll have the answer, then if it works this will be v1.0 I guess)
Reply 316 of 583, by rasteri
Just so everyone is aware, the "rev c" gerbers currently in github (as well as the BOM and centroid) are now tested and fully working.
I will prepare a "1.0" release shortly once I've tweaked the firmware a bit (USB detection has too many safety delays that now aren't required)
Reply 317 of 583, by doogie
Awesome!! Looking forward to building/buying one or two of these. Super useful.
Reply 318 of 583, by ubiq
rasteri wrote on 2024-06-18, 11:56:
Well, I had a crack a doing the bodge on the board I already had, but getting a wire onto pin 17 exceeded the limits of my abilities/equipment.
I'd ordered some "rev c" pcbs a few weeks back, and they recently showed up. I soldered one up, and did zero testing on it before plugging it into my laptop and successfully flashing it.
The attachment IMG_1333.jpeg is no longer available
Pretty happy/surprised that it mostly works..
  • It powers up
  • Both USB KB and mouse appear to be recognized and activate the blinkenled
  • Serial mouse works perfectly
However, the PS2 KB output doesn't work. I tried it initially with a DIN adapter and then a native PS/2 computer. The computers don't see a KB attached. I confirmed continuity between the Mini-DIN connector and the relevant pins on the IC. Might hook a scope up to see if there's any activity, but I expect not. I'm thinking either I cooked the chip a bit too much getting it soldered, or there's an issue with my firmware build.
I've got the stuff to make another board, so I may just do that.
Reply 319 of 583, by rasteri
ubiq wrote on 2024-06-22, 17:40:
Is it in PS/2 mode?
