Reply 30840 of 32055, by Ydee
Nexxen wrote on 2026-02-22, 19:42:
I had it hard when I was young. I had to go to school shoeless in the scorching heat of the summer and had to go shoeless in th […]
TechieDude wrote on 2026-02-22, 02:52:
I guess today's retro activity was having to deal with older people who just like to shit on younger generations for some absurd reason 😂
I had to go to school shoeless in the scorching heat of the summer and had to go shoeless in the freezing winter, in the snow, for 20 miles, uphill both ways, fighting the wolves!!!
What are you youngsters complaining about? 🤣
I tried to use a PCI card to have USB 2.0 in my test rig, a P-233.
Wouldn't work. NEC chip with lots of issues with compatibility.
I have plenty of VIA that just work, I'm boxing this one for good.
Were you so poor that you didn't have a single pair of shoes worn by the family member who had just gone from village to town like us? Sad...
@NEC USB: My USB NEC doesn't work well on older boards either, VIA does, and for the oldest pieces I have a USB 1.1 OPTI FireLink.
Reply 30841 of 32055, by Nexxen
Ydee wrote on 2026-02-24, 14:41:
What do you think we were throwing at the wolves? And at the vultures? 🤣
(this is really silly 😀)
For the little possible use of USB on 286/386/486, I prefer to have a CF adapter on the front, for easy access.
ISA is limited to 16 bits, 486 have PCI but a pentium is better anyway at that point. IMO
USB and pentium are the right starting combo, sometimes I have to wait for files to be copied as it becomes unresponsive until finished.
Most of us went through this. USB 2.0 cards are super available, USB 2.0 doesn't matter as the transfer rate is limited by the IDE controller or mobo chipset. Better than 1.0 for sure though.
Tradeoffs.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 30842 of 32055, by Shponglefan
Had a pair of Roland SC-55 modules on the bench today. Both modules are failing the MIDI diagnostics in test mode.
I'm assuming they may have identical faults, but have not figured out what the fault(s) may be.
I did remove the glue under the 2200uF capacitors on both boards. It had started to go conductive in one of them, but I don't think it was causing any issues. Removed and tested both capacitors, and they checked out fine.
edited to add:
Turns out I'm dumb. I had the MIDI cables connected incorrectly when I ran the tests.
After reconnecting them properly, one of the modules passed the test on both inputs. However, the other module is still showing errors on both inputs.
At least one of them is working which now gives me a basis for comparison with the non-working module.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 30843 of 32055, by Shponglefan
Continued diagnosing the Roland SC-55 with faulty MIDI inputs.
After tracing circuits and testing various things, I discovered that the resistors on the MIDI 1 input (R2 and R3) appear to be bad. They're supposed to have resistances of 120 Ω (R2) and 100 Ω (R3). But they tested at 150 Ω (R2) and 3.1 kΩ (R3). This explains why the input signal wasn't working.
The attachment Roland SC-55 unit 1 MIDI 1 resistors.jpg is no longer available
The second MIDI input (on the front panel) goes through a completely different path than the rear input. I wasn't sure why both were testing bad, until I realized the test was using the MIDI Thru to feed the MIDI 2 input. Since the MIDI Thru signal branches off after the resistors on the MIDI 1 input, the Thru signal would also be bad.
I switched the cables for the test and connected MIDI Out directly to the MIDI 2 input. The MIDI 2 input now tested fine.
The attachment Roland SC-55 unit 1 Input 2 test ok.jpg is no longer available
Hopefully replacing these two resistors will fix the issue and return this unit to fully working status. Though the real challenge is going to be trying to remove them without melting any plastic.
Reply 30844 of 32055, by nali
Not often we see a fault with SMD resistors changing value ...
Reply 30845 of 32055, by Shponglefan
It wasn't what I was expecting either.
I did take a close look at them. Both faulty resistors had black marks on them, which zooming in under the microscope looked like holes in the resistors themselves.
I wonder if they were overheated and damaged resulting in higher resistances. Which makes me wonder if adjacent components might be damaged as well.
I'm more baffled how this could happen. Either the resistors themselves were just faulty components or was an overloaded signal applied somehow. Not sure how that would happen via MIDI, but who knows.
Reply 30846 of 32055, by nali
I've designed a lot of electronic circuits.
In fact I'm still doing it just now with FreeCAD.
I suppose guys from Roland knew at least as much a I know 😀 Probably more.
So it can't be an "overloaded".
Just bad quality component.
But can we say "bad" if it lasted 40 years ?
Reply 30847 of 32055, by Ozzuneoj
What if someone wired up a "custom" adapter to connect some device to their Sound Canvas and things went awry?
Or maybe the neighbor of some 90s synth musician snuck in and hooked up a MIDI version of one of these to get some peace and quiet:
http://www.fiftythree.org/etherkiller/
Reply 30848 of 32055, by nali
It's been a long time I love BeBox.
Of course I don't have a BeBox .
Don't even get a 4.5 iso to boot.
If anyone has the solution to burn the iso .....
Just to play Quake 1 with a Voodoo 2 on BeOS.
BeBox are BeOS, and BeOS was quite great circa 2000.
In fact I used it as my daily OS for a while. Great with a BP6 😀
I've always love the Led thing meter for cpu usage. So wanted to replicated it for my retro machines.
It's easy on Linux / FreeBSD.
Probably also BeOS 5.0, I think the source code is available for MiniPulse.
I even think I did it decades ago.
But BeOS is just an Unix, it's easy.
My main problem was to get cpu usage on Win98.
And I finally found ...
At least I think. A thing in registry.
Probably wrong and not accurate, but the goal is to have a needle moving or a few leds.
Win XP is easy too.
I got Visual C++ 6 and 2005, it sound promising.
Didn't try Borland yet.
No idea if it can be done with ming or any free compiler.
I'm bad for coding.
My background is electronic, VHDL and audio, not Win code 😀
And in the reality more carpentenr and mechanical ..
So I plan a CPU meter with a real analog Vu-meter.
Working as well on Win98, WinXp, Linux, FreeBSD (NetBSD should be the same) and BeOS (Haiku should work).
The goal is having fun, and others have fun too.
So it should be easy to replicate.
I still don't know if I use an Arduino or just basic electronic with a R-2R ladder.
R-2R is easier, but not all paralell ports use the same voltage ...
Some 5 volts, others 3.3.
I suppose most here can use an Arduino and load a code in a Nano.
So high or low levels are not a problem, then we can map cpu usage to a basic pwm.
But for sure there will be a potentiometer to ajust to YOUR analog meter.
I have to think about it .
Reply 30849 of 32055, by Ice Cream Jonsey
Muckrake wrote on 2025-10-12, 01:51:
Successfully patched Wasteland to run in 16 colors on an IBM PCjr.
Whoa! Any chance I could get that patch from you? I came on here tonight as I was going to give Wasteland another run and did a search, and imagine my surprise. I have a PCjr right next to me. I didn't even know the game would work on a PCjr!
Reply 30850 of 32055, by Shponglefan
nali wrote on 2026-02-26, 04:43:
If it was just one resistor that had failed I might chalk it up to just a bad component.
The fact that both resistors on the input line are testing out of spec and show signs of physical damage makes me suspicious that something caused this.
Reply 30851 of 32055, by tehsiggi
Finally made some progress on my 9800 BOM project.. got the PCB all cleaned up.
If anyone ever needs a high res picture of any part of the 9800 Pro PCB for repairs, we got some now..
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 30852 of 32055, by Alesia
Got my Gateway slot 1 PC hooked up to my Extron switch (was short a VGA cable previously.) Finally have my Pentium, Pentium III, Powermac G4 Digital Audio, and AM2/3 Phenom builds all hooked up to the same LCD monitor. Wish it was a CRT but those have been elusive in my area so far. Also set up a silver reed daisy wheel printer I had laying around, seems to work perfectly fine.
Also imaged all 360k EGA/Tandy and 1.2mb VGA/MCGA disks on a basically NOS (opened but never used?) copy of Spirit of Excalibur I picked up at my local tech recycler.
Reply 30853 of 32055, by giantenemycat
I was just going through some old stuff, and decided to check up on this sound card I got in a half working PIII machine. I can only see one seller in Japan listing it for silly money. Looking up other cards with the same YMF724F-V, they are more reasonable, but still priced quite highly. I guess this is a desirable chip?
The attachment xwav.jpg is no longer available
The attachment ymf.jpg is no longer available
Reply 30854 of 32055, by Alesia
giantenemycat wrote on 2026-02-26, 16:04:
Off the top of my head you get special midi music in Final Fantasy VII (for sure) and VIII (I remember vaguely reading.) I'm not sure around other titles though. It can also(?) hook up to an external midi box that Yamaha made.
Reply 30855 of 32055, by ChrisK
tehsiggi wrote on 2026-02-26, 15:30:
Nice!
Just out of curiosity: what's your specific intention with this project?
Still had this board around so I thought why not give it a shot with my new self-made(TM) preheating station (which for itself was a long planned project but only got realized within the last weeks):
The attachment P6BAT-ME_1.jpg is no longer available
The attachment P6BAT-ME_2.jpg is no longer available
The attachment P6BAT-ME_3.jpg is no longer available
Removing the northbridge worked like a charm!
Now I'm thinking about replacing the NB with a replacement.
It's not worth the cost and effort by any means, but wouldn't it be fun if it really worked in the end? 😉
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 30856 of 32055, by Shponglefan
ChrisK wrote on 2026-02-26, 16:56:
Can you share more about how you set this up?
I've long considered getting a board heater and also trying to rig something up for BGA chip rework. I'm really curious what your set up is like.
Reply 30857 of 32055, by Nexxen
Nice! Just out of curiosity: what's your specific intention with this project? […]
Nice!
Like above, some more info? 😀
Btw, what diameter are the pads and the solder balls you are going to use?
Reply 30858 of 32055, by andrea
You know in cartoons where a little devil pops up on the character's shoulder to give him bad ideas?
693/596 are pin-compatible with 440bx/zx and piix4, only the bios is different.
A lot of 440bx-based laptops suffered from crumbling plastic but are otherwise working
And most importantly a variant of your board with a 440ZX exists https://theretroweb.com/motherboards/s/ecs-p6zxt-me
Reply 30859 of 32055, by Shponglefan
I wouldn't go by list prices, as a lot of those cards don't seem to sell. If you check the sold prices, most YMF724 and YFM744 cards go for about $50 to $100 USD.
There was even an untested one that sold recently for only $15 USD.
