Reply 31280 of 31281, by appiah4
Lopo wrote on Today, 06:37:
Just sent my first PCB revision to fabrication - a reverse-engineered duplicate of the DataExpert 367C motherboard with UniChip […]
Just sent my first PCB revision to fabrication - a reverse-engineered duplicate of the DataExpert 367C motherboard with UniChip U4800-VLX chipset.
The challenge: there's no datasheet for the U4800-VLX anywhere. All 160 pins had to be mapped from scratch using PCB scans, photos, multimeter tracing, and cross-referencing with other designs (Groza's OPTi 495XLC SBC, Skiselev's SARC RC2016 386SX board).
This v0.1 is essentially a 1:1 copy to verify the reverse engineering is correct. If it works, future revisions will diverge with improvements (ATX power, VLB slots, expanded cache, etc.)
The attachment L386.jpg is no longer available
Fingers crossed! 🤞
This is simply amazing, I commend you for your hard work and look forward to an ATX version.
Reply 31281 of 31281, by zuldan
Worked on my video card Memory Tester Launcher. Boots from a USB stick. It’s just a simple BAT file but consolidates all the memory testing tools in one place and makes sure logs are easy to access.
The attachment CAF8F329-900D-4DFA-BB8D-F071D473F701.jpeg is no longer available
