Reply 31740 of 31745, by MrFiveThumbs
I thought I'd quickly today make a new feature to my personal QuickBASIC 4.5 based retro cave manager program, which I've been doing in collusion with generative ai models for a few months now. It was getting there, and after a few back and forth rounds, the 486 I was compiling and testing this on finally gave up and crashed really good - like properly messed itself up. I think the CF card is broken. Data is all kinds of mangled up, dir listings show weird artefacts with parts of the QB45 code where C:\DOS filenames used to be, and all in all the filesystem is all kinds of messed up. Scandisk tried and gave up, said it's out of memory but I know it was really out of hope of fixing anything. It had acted up a few times before, but this is full catastrophic failure of the whole CF. Nothing works, can't read files, I can only boot with floppy, and all attempts to save anything end up in errors reading sectors.
Well, luckily the only important thing there - the retro cave manager's database - is backed up to another retro PC, plus a couple floppies, and the binaries can always be recompiled. But now I'm scratching my head about what am I going to do with regards to the failed CF card - I guess I don't want to pay 100 euros plus shipping for new industrial grade CF card, and I don't want to try my luck with another consumer grade used card, which that one was. Any recommendations, what's the most reliable IDE replacement, should I not try to save money and just go for a new expensive industrial CF card? I'm sure this topic is been discussed to death but I'm too beat up to find it now.
Reply 31741 of 31745, by DaveDDS
RetroLizard wrote on Today, 14:54:
Valid. I wouldn't really consider it "bypassing" DRM when you're ignoring read errors to make backups for personal use, though. It's still there.
Agreed, but the whole reason DRM even exists is that far too many would "make backups" to give to friends or sell (by various methods).
My approach was always to take good care of my discs - kept them in sleaves or jewel cases. Almost never needed a replacement, and on the very rare case when you do, it's like any other "unrepairable" product .. you decide if it's worth buying another one.
Don't get me wrong - I'd have loved it if it were possible/easy to make backups - but over the years, having lost quite a number of sales to "pirates"- (It's "interesting" when you get support calls from "customers" who actually "bought" your product - but from somewhere that's not one of you distributors, doesn't have a valid produce ID serial number, and sometimes has a "slightly modified" edition of your product) - I completely "get" why DRM exists and have never openly supported invalidating it!
Software has always been a grey area where development costs tend to be unusually high and unit production costs are very low.
A lot of people tend to thing "it's just a copy of digital data - easy/cheap to produce" and don't really understand what that "data" represents.
- But this is getting into a wholly different topic.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 31742 of 31745, by RetroLizard
DaveDDS wrote on Today, 18:04:
Agreed, but the whole reason DRM even exists is that far too many would "make backups" to give to friends or sell (by various […]
On the other hand, there's a lot of software out there that's both hard to find and no longer made. The registered copy of Heretic (pre-SOTSR) is one such example.
Reply 31743 of 31745, by Thermalwrong
MrFiveThumbs wrote on Today, 15:02:
Ouch, I've experienced the same and it's a huge spanner in the works when a CF card goes in that way. It does seem that resets, power cycling or powering off at the wrong time can cause as many problems for CF cards as you'd see with hard drives before their heads could auto park. What kind of card was it?
Mine was a consumer grade 256MB CF card meant for digital cameras. These days I tend to use ex-Cisco labelled CF cards since I've got them in bulk for cheap multiple times now. I've had good luck with Transcend and Sandisk cards along with Swissbit. The ones with datasheets tend to do far better than the no-name ones for digital cameras of the era.
The last day or so, I've been messing around with my two Acer Aspire One netbooks, the A150 hard drive model and A110 SSD model. The hard drive one with XP on it turned out to be perfect for an application I need a small portable computer for. But having a spinning hard drive bashing about, in something I need to move around a lot makes me nervous.
The Acer Aspire One A110 with its 8GB 'SSD' should be great but it's an awful IDE based 1st generation thinger with terrible caching and performance, it was always too slow to run XP or Win 7 on it so I decided to look into it more. But it's the one I want to use because the case is a little nicer without the HDD bump and I've always wanted to do this mod.
The attachment IMG_7021 (Custom).jpg is no longer available
There are the pads for the SATA port on the A110 motherboard but the casing won't fit a regular hard drive. I pulled the SATA connector off of some optical bay IDE > SATA adapter I'm never gonna use and started trying to clear the holes to install the SATA connector. Which was *not* easy, it took:
  • low melt solder
  • solder braid
  • two vacuum desoldering tools
  • 0.4mm carbide drill bit
The attachment IMG_7024 (Custom).jpg is no longer available
The ground plane sucked enough heat away that the vacuum tools were only good for the data lines, low melt and solder braid cleared a couple of the SATA voltage rails though they messed up the solder mask a bit. Getting the ground plane cleared though eventually required removing enough solder that there was a 'cup' to drill into by hand and physically cut away the solder. The 0.5mm got too close to the edges for comfort and somehow I didn't break the carbide bit this time, hooray!
Once all the holes were cleared, the SATA port's pins need grinding down to be little pins to fit into those tiny holes. And there were pads for a 0-ohm resistor and capacitors that weren't installed from the factory because they're for the SATA port's power. Soldered a bit of wire where the 0-ohm resistor went and the port is now powered.
Magically, the port worked first try so the sacrifice of the adapter was not in vain and the board wasn't damaged. Then I started fitting an M-PCIe SATA adapter PCB that's been sitting un-used for a long time. Lots of posts in the plastic case needed to be cut off and one screw standoff was hot-glued into place to screw the adapter PCB into the casing to stop it shaking loose:
The attachment IMG_7033 (Custom).jpg is no longer available
Taking the motherboard out now is not fun and the SATA port connector keeps getting pulled up at the wrong angle if things aren't removed in the right order, those pins won't hold up against that too many times.
Now it's all back together:
The attachment IMG_E7032 (Custom).jpg is no longer available
The SSD in it already had Win98 on it which wouldn't load because this little netbook has 1.5GB of RAM, I know that can be fixed with some DLL change but I haven't done that yet. Instead I loaded Windows 7 on it and it's so nice to see Windows 7 again, the last OS I can turn off ClearType in I think and has the audio features I need for my software.
I was hoping to dual boot Windows 7 and Windows 98 but they won't play nicely and I think I need some extra bootloader software for it so that can wait, I have many far better options for playing DOS games on. Now my Acer One A110 has the SATA SSD upgrade I always wished it could have. Still in IDE mode rather than AHCI but that's fine for now 😀
Reply 31744 of 31745, by DaveDDS
RetroLizard wrote on Today, 18:11:
It would be ideal if the makers of such discontinued software would release it without DRM when they stop offering it.
Otherwise we get into even grayer areas about the legality of "abandonware" and what rights the original producers still hold.
Personally, when I came back after dying (story on my site: "2019") - I wasn't going to be working anymore, and after I had recovered enough to "do stuff" again, I've been working away at making everything I ever created (that I hold rights to - which is most of it) freely available , including source code (incl, stuff I never published).
I feel that to do anything else is just diminishing the industry as things "disappear".
Reply 31745 of 31745, by RetroLizard
DaveDDS wrote on 16 minutes ago:
It would be ideal if the makers of such discontinued software would release it without DRM when they stop offering it. Otherwise […]
I feel like Spore is a great example of this. I have the original discs, and the cd-keys to go with them, but I can't play them on XP or older Macs without having a connection. It really sucks.
