millobo2016 wrote on 2025-03-07, 16:51:
1. Slightly poor compatibility, P3B-F Mod bios can operate, P2L97 1.02 bios lacks microcode and cannot install XP, Tekram P6F40K-A5 cannot boot
Heyo, glad you've managed to build it and it works!
The BIOS compatibility will be the same with any Socket 8 adapter. With P2L97 I don't think the microcode is an issue. Did you try installing XP with P2 and then booting it with PPro on this same board?
2. No overclocking performance, FSB I can only use 66Mhz or 75Mhz, CPU operating speed is 233Mhz or 225Mhz
I reached 83 MHz without issues, but 100MHz is a no go.
the design is fully compatible with the bracket used by Socket 370, even if the bulky original pentium pro cooler is installed
Ah yes, this was actually one of the main goals. I wish someone 3D-printed those plastic holders and sold them for cheap in bulk...
Mentat-vvo wrote on 2025-03-09, 06:49:
The slot 1 connector is easy to be killed with П-shaped edge.
This. My first batch wasn't bevelled because the factory screwed up, I had to do it manually. And then they sent me 25 fixed boards for free which I don't even need anymore ¯\_(ツ)_/¯
I'm in the process of making another revision, but it's going slow because i've been overloaded with repairs.
