Reply 32140 of 32141, by fosterwj03
I’ve spent the last few days working on a side-grade of my Gateway 2000 low-profile 486 platform. I had a generic OPTi 82C930 sound card for 16-bit audio and a secondary IDE interface for my optical drive in this computer. While I think it sounded pretty good for 16-bit audio, it had two issues I struggled to accept. First, it was a purely plug and play card in a non-plug and play system (i.e. the BIOS couldn’t initialize the card’s resources). So, it needed software/drivers to initialize the digital FX and on-board wavetable as well as the IDE interface on a cold boot (the resources stayed initialized after a soft reboot, though). I didn’t consider this a serious issue in supported operating systems (DOS, NT 3.51/4.0, and OS2), but I had to modify the installation boot disks with the IDE initialization driver and/or soft reboot after initializing the IDE interface to install those operating systems from an optical disc. More annoying, I had to set up a dual boot configuration on non-supported operating systems (such as NT 3.1) to initialize the card in DOS (audio and IDE) before a soft reboot into the desired OS. I actually could live with that, though.
The second issue was far more annoying. The on-board wavetable, frankly, sucks. The wave samples didn’t sound bad, per se, but they didn’t sound great either. Worse, the wave table would stutter during playback when too many voices tried to play back at the same time. That made the wave table nearly useless in my opinion. I couldn’t stand it.
Finally, I just kind of wanted a Sound Blaster 16 for this computer. You could call me a little biased, but I was a bit of a Creative fan boy back in the day (a nostalgia trip since I had a SB16 back then). A SB16 just seemed right for this computer. To that end, I bought a Vibra16 (CT2810) off eBay last week and installed it in the Gateway system. This Vibra16 has a special feature (at least to me); it has jumpers to set all the addresses, DMAs, and IRQs the card needs for digital FX and the IDE interface. This is ideal for this computer and some of the operating systems I use on it since the card’s resources doesn’t need to get initialized in software (with one minor exception that I’ll mention more below). The card also has real OPL3 and a wave table header just begging for my E-Wave module. It sounds pretty good to my ears in software that runs well on a fast 486 / slow Pentium.
I spent the last few days updating my various Operation System SD cards to remove the OPTi drivers and tools and install the SB16 drivers and tools. DOS was tricky because the card mutes the CD interface and Line-in port by default. I had to find a Creative driver set with a DOS mixer that didn’t need the PnP DOS drivers installed first (that saved me 12k of lower memory) to un-mute those inputs during the boot sequence. The SB16 mixer for Windows 3.1 in the same driver set throws up an error about not locating the card, but the mixer does work after ignoring the error message. NT 3.1, NT 3.51, and NT 4.0 all worked once I removed the OPTi drivers and installed the SB16 drivers (although, again, the NT 3.51 mixer had an error message about locating the card). Windows 95 Gold, OSR2, and Windows 98 gave me the least trouble. I just removed the OPTi device in device manager, rebooted, and then ran a scan for new hardware. After another reboot, Win9x gave me 16-bit audio, a fully functional mixer, and the IDE port without issue.
OS/2 gave me a bit more trouble last night. So far, I’ve only done version 2.1, but it has been a struggle. I couldn’t just modify the CONFIG.SYS file and MMPM2.INI files to remove the OPTi driver references and install the SB16 drivers because the MMPM installer just failed every time I tried it. In the end, I had to delete the multimedia extensions folder entirely (that’s actually OK since it’s a bit of a bolt-on feature of OS/2) and re-install multimedia support from scratch. That’s worked so far, but I’ll still have to modify the CONFIG.SYS file to un-mute the Line-in and CD audio ports (not hard to do at all) as well as install the SB16 drivers in WINOS2 (the current SB 1.5 drivers work fine for now). On the other hand, the card’s IDE port just worked with OS/2’s generic IDE driver from the start.
Anyway, it’s been a bit of a project so far. Still fun, though. I know Vibra16’s aren’t the best cards in the series, but this particular one just feels right in this computer.
