Reply 340 of 575, by myne
Played 1 mission of mw2 titanium. Seems fine.
No errors. No leaks. Memory under 200mb.
Disc=
TITAN_MW2-TITW95-Titanium Trilogy
I built:
Reply 341 of 575, by AweDeus
myne wrote on 2024-11-04, 06:14:
Its a bit of a mess. Some people are reporting memory leaks. So I backtracked a year. That one seems to work with mercs. You say […]
You say it doesn't work with mw2. Ok.
Does the main one?
Well, actualy nothing is works for me so far, i even tryed to do it for ourself, with all stage, with sdb and other stuff, but its wont help.
DOS wersion on MechVM works fine, i even can Launch titanium to menu stage on it (its just crash when launching mission).
Reply 342 of 575, by myne
I used this.
See PM
I built:
Reply 343 of 575, by AweDeus
Ok, i try.
Reply 344 of 575, by ChronoReaperX
BEEN_Nath_58 wrote on 2024-11-03, 13:28:
Alright then, download MechVM from here: https://mechvm.org/downloads/MechVM-win32-2022-05-03.7z […]
ChronoReaperX wrote on 2024-11-03, 11:03:
BEEN_Nath_58 wrote on 2024-11-03, 08:14:
The game doesn't run on MechVM, I am asking if you would be able to test the game when I provide the instructions
Yes sure... I can try
Install your Titanium Mercenaries, but run MechVM.exe as administrator.
After installation, go to the games folder of MechVM, then to the mw2-mercs-tt folder, and rename mercswin.exe to something else.
Copy all the files from "Install/data" folder of your CD to your installed game, but don't overwrite.
Copy all the files from "Install/16bit" folder of your CD to your installed game, again don't overwrite.
Use the attached profile in the latest DxWnd version downloaded from SourceForge. Let me know what changes (if any) you face.
Still the same problem. HUD disappeared during the later part of some mission. Mechs also disappeared including the in game menu (when pressing esc).
Reply 345 of 575, by myne
Weird. Got through the first few missions and then it started glitching.
Not sure why these issues weren't apparent a year ago. I literally finished the whole game without issue.
I built:
Reply 347 of 575, by BEEN_Nath_58
AweDeus wrote on 2024-11-04, 07:25:
Go to the game folder and run the main executable (mercswin.exe?) directly. It should output an error, what's that?
ChronoReaperX wrote on 2024-11-04, 07:05:
So basically the MechVM game didn't change anything. That's sad, the MechVM fixes were also from https://gitlab.com/retropc/mw2hook
I probably have one thing left: put the main game executable back to Windows 98 compat mode, and run DxWnd as admin, and try. This is the only thing I removed from the previous test.
Also if it is easy to get to the bug, glitch, you may share the savegame or explain how to reach the part of the game.
Reply 348 of 575, by ChronoReaperX
myne wrote on 2024-11-04, 05:22:
Why...? It's working. Why fix it? […]
Why...?
This is worth testing. It's the OLD files sdbs etc and the new install script.
Not sure why people weren't reporting issues earlier.
Still experiencing memory leaks
Reply 349 of 575, by AweDeus
BEEN_Nath_58 wrote on 2024-11-04, 07:33:
Well, i try to launch MW2 31 titanium, error with code 0xc0000142
UPD - ok, i figure out whats the problem with injection - Windows Data Execution Prevention (DEP) Service in windows performance tab - if add DxWND and Mw2Tit.exe to exception then all goind well, BUT - i got another error https://i.imgur.com/CLdZU4W.png
also, ive got an error in PS when installing a game:
copy-item : Cannot find path 'L:\setup\' because it does not exist.
At D:\GAMES\mw2Installer\mw2Installer.ps1:455 char:10
+ copy-item -path "$CDDRIVE\$folder\" -destination "$InstallPa ...
+ CategoryInfo : ObjectNotFound: (L:\setup\:String) [Copy-Item], Ite
mNotFoundException
+ FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.CopyItem
Command
Reply 350 of 575, by BEEN_Nath_58
AweDeus wrote on 2024-11-04, 08:40:
Well, i try to launch MW2 31 titanium, error with code 0xc0000142 […]
Same result - Error with GetThreadContext error = 5
mNotFoundException
Command
The PS error should be irrelevant. Now I need to find how to emulate the error you got.
To note, the mw2installer package was made checking how the InstallShield would install the game.
I don't know if it's an installation issue, but you can install the game with the CD to make sure it isn't. Put Windows 95 compat mode on the Autorun of the game, and proceed, it should run the InstallShield setup correctly (you need OTVDM installed for 16bit apps to execute).
At least you aren't alone, the only thing that comes to mind is testing the game on another language of Windows: https://sourceforge.net/p/dxwnd/discussion/ge … /310b/b7ba/3487
Reply 351 of 575, by AweDeus
ZOMG - im successfully launch it and enter the mission, for this i install Titanium version from scratch and copying all files from autoinstall folder. At first ive got game crash with 3dfx video option, but seems that DirectX is working fine.
Also - the error
MW2 BATTLE.EXE - fatal error #41: Edition\mw2t.BWN ID -1
may appear if you use compability mode, because i was launching it with compability mode and its crashed. So i hope someone who, like me, has spent a lot of time trying to find the right combination will read this, check the compatibility and finally get it running.
UPD
BEEN_Nath_58 wrote on 2024-11-04, 08:48:
The PS error should be irrelevant. Now I need to find how to emulate the error you got. […]
mNotFoundException
Command
I think error with code 0xc0000142 may appear because of "Windows Data Execution Prevention (DEP)" Settings. Hope its also helps someone.
Also - you dont need to install OTVDM all that you need it set compatability mode with win95 on setup.exe and setup.exe in "install" folder and analyze wait chain for setup process in task manager after launching it - you have to kill all process that shows in analyze wait chain tab and after that installing will be start.
Reply 352 of 575, by BEEN_Nath_58
AweDeus wrote on 2024-11-04, 09:00:
ZOMG - im successfully launch it and enter the mission, for this i install Titanium version from scratch and copying all files f […]
Also - the error
Right, the crash comes from the compatibility modes, I don't remember well but maybe it is the GetCommandLine shim.
And how did you get the game, you installed using the setup executable then, right?
For the 3Dfx modes, you need dgVoodoo2
UPD
Yes the error is related to DEP. I have only had one issue with DEP ever, in Diablo, so I have little knowledge on what to do actually.
On Windows 10, the 16-bit stub of IS is somewhat present so it will work nonetheless. On Win11 it was completely removed.
Reply 353 of 575, by BEEN_Nath_58
ChronoReaperX wrote on 2024-11-04, 07:35:
Why...?
Hi can you provide saves of the place where you get the memory leak and if not, the fastest way to get there, or as to how long to play to get there.
Reply 354 of 575, by ChronoReaperX
BEEN_Nath_58 wrote on 2024-11-04, 13:06:
Why...?
The fastest way I think is the mission 2 of Ghost Bear's Legacy campaign. Named Defend on Mannedorf. You play it until you've repelled the third wave (two Mechs heading to your base after you finished off a team of Ravens descending from above your base). While your are waiting for the fourth wave (two Mechs from afar), then then problem will happen.
Reply 355 of 575, by AweDeus
BEEN_Nath_58 wrote on 2024-11-04, 10:37:
Right, the crash comes from the compatibility modes, I don't remember well but maybe it is the GetCommandLine shim. […]
Also - the error
UPD
at first im used the installing script, then i installed the game from ISO, after that i just copying files from first folder to second with replace.
But i think that the problem was in DEP and anti hook behevor. Im also got this error in Diablo long time ago, and it is why i remembered this way to fix that.
So you just need to find windows Performance Options utility ((You may find it in windows searching), it is the place where you also could set you virtual memory limit), and in that window you could add to exclusion you .exe files on "Data Execute Prevension" tab
Yes, actualy on the second try 3dfx mode start working well (I already had glide files idk why its happens at first)
Reply 356 of 575, by Khoidoan1@hotmail.co
BEEN_Nath_58 wrote on 2024-11-02, 12:25:
@ChronoReaperX @Khoidoan1@ hotmail.co […]
One way the game can create a memory error, or at least the HUD going away, is if you are running the game from the Desktop shortcut. The Desktop shortcut will make the game hook its "fixed elements" on window creation, which leads to things like memory structure and heap structure not being "changed" as the game wants to see, from DxWnd.
Can you confirm that the same issue occurs if the game is run from DxWnd.exe and double clicking the game?
Also is ChronoReaperX playing "MERCS3DFX-Mercs3DFX-Mercenaries 3DFX"
Sorry I've been dealing with something deeply personal so I've not been able to really test Mercs 2 all that much. It does still have the memory leak if played directly from DXwnd. For some reason at least for me, the game will run for hours without issues if an instant action is started and then aborted. Max mem usage is 2600 or so.
Reply 357 of 575, by BEEN_Nath_58
Khoidoan1@hotmail.co wrote on 2024-11-06, 18:09:
I haven't got the time to test GBL for ChromeReaperX either. Anyways...
The game working fine after aborting a mission could be a sign of where to look. If you read some of the previous discussions on this thread, you will get comments on the game flickering unless the game is Aborted and re-run.
What I assume is, DxWnd isn't correctly hooking the game interface on the first run in mission. The mission window is a separate DirectDraw hWnd, forced to skip the DDSCL_EXCLUSIVE flag but keeping the game contactless from other apps through a modal window (which fails on the first run). On the Abort -> Replay Mission the Modal window was drawn correctly, and simultaneously your game doesn't get a memory leak.
You can continue to run the game in this fashion, and if the leak no longer happens, I think we found the issue
Reply 358 of 575, by ChronoReaperX
BEEN_Nath_58 wrote on 2024-11-06, 18:18:
I haven't got the time to test GBL for ChromeReaperX either. Anyways... […]
Ok I will try and test what you said. Start a mission then abort, after that, restart it back, right?
Reply 359 of 575, by BEEN_Nath_58
ChronoReaperX wrote on 2024-11-07, 06:54:
yes
