Which USB 2.0 cards for old motherboards
Reply 360 of 399, by Duffman
rasz_pl wrote on 2024-06-23, 05:37:
all of them, from all vendors?
The USB 2.0 drivers are all just microsoft generic drivers, there aren't any vendor specific drivers for USB 2.0 as far as I know, USB 3.0 had vendor specific drivers until windows 8.0 came out.
The source code for the USB 2.0 drivers came out with the XP source leak a few years back, as far as I know no one has looked closely at the code though.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 361 of 399, by rasz_pl
Duffman wrote on 2024-06-23, 07:30:
aaah, that indeed explains same behavior. I keep wondering what is hammering the CPU if not SOF/uSOFs - it was such a nice theory 😁
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 362 of 399, by Myloch
there aren't really many dos drivers for ehci
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 363 of 399, by Duffman
Sweetlow has a modified server 2003 usb 2.0 driver for win9x, no idea if it'll take a difference in slowdowns though.
http://sweetlow.orgfree.com/download/
CPU: Ryzen 9 5950X
Reply 364 of 399, by RavenDan44
Well I've used 2 lots of usb 2.0 pci cards both of which stop the pc from booting thr second card wouldn't even post bios, the first would get stuck on wait on the bios boot up page. VIA chipset seems to be the norm with these cards.
Yet another flaw with the gigabyte ga 5aa rev2.2 board the usb header is specific to the motherboard the pin layout is completely different and it's 8pin stead of 10 not that the last 2 do anything both being nc or ground pins.
Reply 365 of 399, by Kahenraz
I had a similar issue with a smaller 8-pin onboard USB header. It was extremely awkward trying to find the right pinpoint, but I finally managed to do it by referring to the manual and a little bit of trial and error. I had to repin a similar connector, since it was actually smaller in size than a standard DuPont header.
Reply 366 of 399, by RavenDan44
Turns out the second card I bought although appearing to be a genuine branded older card it has the same chipset as the modern chinnese knockoff card 🙁
The attachment 20240625_152707.jpg is no longer available
The attachment 20240625_152703.jpg is no longer available
The attachment 20240625_152657.jpg is no longer available
The attachment 20240625_152651.jpg is no longer available
Reply 367 of 399, by schlang
Duffman wrote on 2024-06-24, 01:18:
site unavailable
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 369 of 399, by ux-3
crusher wrote on 2024-06-26, 06:09:
Did you discuss "Native USB" (NUSB) drivers by Maximus Decim here before? Works like a charm in my Win98 build. […]
https://msfn.org/board/topic/43605-maximus-de … ve-usb-drivers/
https://www.creopard.de/projekte/windows-98-s … er-fuer-usb.htm (german)
I think so. But they don't revive the dead horses either. 🙁 At least not here.
Retro PC warning: The things you own end up owning you.
Reply 370 of 399, by Duffman
@schlang
odd, still works fine for me.
CPU: Ryzen 9 5950X
Reply 371 of 399, by jmarsh
It's a http only site (no support for https), probably won't work with browsers with strict security turned on.
Reply 372 of 399, by schlang
jmarsh wrote on 2024-06-26, 18:10:
thank you that explains it
Reply 373 of 399, by giantenemycat
Unearthing this deal I came upon a while ago. For those in the UK, SCAN are selling a PCI USB 2.0 + FireWire card with a 3.5" front bay for £0.49. I bought 5 to get the most out of it cause why not, considering the shipping is almost ten times more than the item itself...
https://www.scan.co.uk/products/scan-2x ... ternal-hub
Even though the pictures show x2 USB, x1 FW and whatever that other little port is on the front bay, mine has x3 USB and x2 FW. Compatible in my GA-BX2000 and SE440BX-2, and Windows 98SE somehow has drivers for them on the disc - not sure how since the OS obviously predates USB2.0.
The attachment ali_xpress.jpg is no longer available
1999 Family PC: AST Bravo LC(?) 5166(?)/430TX(✔)/Pentium 166(?)/32MB(?) SDRAM/Virge DX\GX(✔)/ALS120(✔) - [OSR2 -> ME]
2006 Family PC: Generic Shuttle HOT-675/450MHz PIII/256MB SDRAM/Radeon 9200\9250/ST310240A 10.24GB - [XP SP2]
Reply 374 of 399, by rasz_pl
giantenemycat wrote on 2024-07-04, 07:31:
£0.49
good price even for a 3.5 bay blanking plate 😁
4 pin firewire for stuff that didnt require power, like in cameras
Reply 375 of 399, by badmojo
digger wrote on 2024-06-22, 14:12:
It looks like there is a small but acceptable slowdown when you install a USB 2.0 PCI card in an older machine, but there will be considerable slowdown once you plug in any high-speed devices, even if you don't actually use to them.
This has been my experience with an NEC based USB 2.0 card in my GA-586T2 (socket 7) machine. More than once I've copied over a new driver or something with a USB stick, installed the driver, run a 3D benchmark to see how I'm looking, and am shocked to find that I've lost 100's of points off my score. Then realise I left the USB stick in 😁
But with the stick out there is no real difference between card installed / no card, and fast USB is so handy on a machine of that era.
Reply 376 of 399, by Kahenraz
I wonder if the decrease in the USB polling penalty is mitigated on NT-class operating systems due to the nature of preemptive multitasking, rather than concurrent multitasking. There is probably some unoptimized code somewhere that's taking up too many CPU cycles where it's not multithreaded.
Reply 377 of 399, by CHA0SHACKER
I had plenty issues personally with VIA based USB cards on older systems (pre-Slot 1). I switched to an ALi based one and that ran without issues.
AMD K6-III+ 400 ATZ @ 550 MHz 1.8V | Gigabyte GA-5AX Rev 5.2 | 256MB 100MHz SDRAM CL2 | 32GB SSD (SSD370S) | 3DFX Voodoo 4 4500 32MB @ 183MHz | Orpheus II LT with X2GS-SE Wavetable | Gravis UltraSound PnP (clone) with 16MB SIMM
Reply 378 of 399, by kolmio
badmojo wrote on 2024-07-22, 01:07:
That's good. But what operating system do you use?
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium III 900, slotket | 512MB PC100 | Radeon 9250 | SoundForte SF16-FMI-03 | 64GB MicroSD
Reply 379 of 399, by Studiostriver
GeorgeMan wrote on 2014-04-27, 10:10:
swaaye wrote:
What cards have you guys used that work reliably on old boards? I have a card with a VIA controller and it isn't even detected by 440BX or AMD 750. It does work on newer chipsets like KT266 though.
You need a card with NEC chip, not VIA. Some old computers refused to boot with the card installed and some others didn't recognise the card at all. 😊
I bought 3 different VIA based pci cards from ebay before finding out...
Thanks for let me know, i have one at my home with old 2000 motherboard 307 socket, and it worked for 4 days, and know it malfunction. 🙁 I`ll guess i`ll have to get one with NEC chip then.
