Battle of the platforms: socket 754!
Reply 380 of 927, by shevalier
AlexZ wrote on 2025-11-12, 15:32:
It happened to me on nForce 3 and Intel SSD. Windows XP froze on boot screen very early and after manual reboot offered safe mode. I selected standard boot and it booted normally. Everything worked fine in Windows once it booted. But after turning the PC off and on it repeated. There may be SSDs that will work fine with nForce 3, but one should be prepared for such issues.
I use Samsung 860 EVO on nForce 4 and it works in SATA-1 mode, not SATA-2 the chipset supports. So this is also an issue but at least it is reliable. This SSD failed to work reliably on AMD SATA controller.
Sorry, I can't help you with that.
My VIA K8T800 (VT8237) always rebooted during the first boot from SSD.
I think I solved the problem today — I installed (on another motherboard it would be ‘moved’, but this is Jetway) a strap resistor on ‘disable autoreboot’.
I don't know how it works — the schematic diagrams say ‘if the BIOS supports this option’.
Half of the motherboards have the resistor set to ‘disable’, while the other half have it set to the opposite position.
But it seems to have worked.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 381 of 927, by nd22
Cand you post pictures ot schematics? This is good news. I could never installed a SSD in KV8 PRO/K8T800 board.
Reply 382 of 927, by nd22
1. We go straight to the benchmarks and, as usual, Code creatures is first
1024*768 no AA, no sound:
1. NF8
2. KU8
3. KV8
Reply 383 of 927, by nd22
VIA is off to a good start with a 3% advantage over the competition; however that 3 % is still well within the 5% which is the limit of error!
2. 1024*768 no AA sound ON:
1. NF8
2. KU8
3. KV8
Reply 384 of 927, by nd22
Please note again the very low impact the sound has on the results! Back on socket A only nforce2 managed such good results in tests with sound while all boards with realtek codecs suffered greatly!
3. 1024*768 AA 4X no sound
1. NF8
2. KU8
3. KV8
Reply 385 of 927, by nd22
4. 1024*768 AA 4X sound ON
1. NF8
2. KU8
3. KV8
Reply 386 of 927, by nd22
VIA is in front however the distance between all 3 platforms is really small!
5. 1280*1024 no sound
A. NF8
B. KU8
C. KV8
Reply 387 of 927, by shevalier
nd22 wrote on 2025-11-13, 04:51:
It's not what you think.
Without switching the SATA mode in the drive itself, the VT8237 A/R will still not see SATA2/3 devices.
Only the “R+” chipset does not have this drawback.
This is a solution to a very strange glitch where, once the SSD has been detected, Windows starts to load. It gets halfway through and then reboots.
Re: How to connect SSD to SATA1 (SandForce based SSD). And a small dirty test.
Reply 388 of 927, by nd22
6. 1280*1024 SOUND ON:
A. NF8
B. KU8
C. KV8
Reply 389 of 927, by nd22
7. and the grand daddy of retro resolutions: 1600*1200
A. NF8
B. KU8
C. KV8
Reply 390 of 927, by nd22
8. final and most demanding settings: 1600*1200 AA 4X sound on:
A. NF8
B. KU8
C. KV8
Reply 391 of 927, by nd22
Despite being the first every single time VIA does not have any decisive advantage in Code creature pro! Also ULI keeps up with the rest of the competition pretty well! Nforce3 is last but 3% slower is nothing extraordinary!
Reply 392 of 927, by nd22
shevalier wrote on 2025-11-13, 07:40:
It's not what you think. Without switching the SATA mode in the drive itself, the VT8237 A/R will still not see SATA2/3 devices. […]
I remember now that I read that; the problem is that the solution requires SSD's wih specific controller which I do not have.
Reply 393 of 927, by shevalier
Regarding F.E.A.R. testing.
It's with a NVIDIA's undisable PhysX.
For which you need a PCI-e graphics card no weaker than 8600.
Either a significantly different processor or a resolution of 1024*768
Reply 394 of 927, by Joseph_Joestar
shevalier wrote on 2025-11-13, 10:32:
It's a NVIDIA's undisable PhysX.
F.E.A.R. uses Havok physics, which is GPU agnostic.
Nvidia's PhysX is a different thing entirely.
My retro stuff
Reply 395 of 927, by shevalier
Joseph_Joestar wrote on 2025-11-13, 10:37:
Exactly, I was wrong.
I watched it very late last night.
Sorry.
The most recent version of the engine uses a DirectX 9 renderer and includes support for the Havok physics model, including the additional "Havok vehicle ...
Reply 396 of 927, by nd22
9. We switch to Aquamark3 one of the very first DirectX9 benchmarks! We start with the default AM3 test with no sound ,no AA and AF only 4X. I put up the detailed results so everyone can check them; MSI afterburner and fraps are always running and logging the framerate:
A. NF8
B. KU8
Reply 397 of 927, by nd22
C. KV8
Reply 398 of 927, by nd22
VIA again starts with a 3% lead!
Reply 399 of 927, by nd22
10. Same 1024*768 resolution but at maximum settings including sound this time:
A. NF8
B. KU8
