Reply 380 of 60068, by Old Thrashbarg
Well, pull all the socketed chips, clean the pins/sockets and reseat them, first of all. On that Fahrenheit 1280, this may offer some insights. Specifically, looks like you'll want to play around with the settings of JP2 and SW3.
Reply 381 of 60068, by schlang
thanks man!
SW3 fixed the error beep code.
Now I am stuck with this scrambled image, no combination of JP2 could solve it:
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 382 of 60068, by schlang
ok the next patient in my collection:
diamond stealth vram
but only gives me a black screen...
Reply 383 of 60068, by Tetrium
schlang wrote:
ok the next patient in my collection: […]
You're sure not having much luck there.
Care to give me the name of the seller? That way I'll know where not to buy from 😁
My retro rigs (old topic)
Report spammers here!
Reply 384 of 60068, by schlang
actually these three are from a co-worker of my dad 😒
Reply 385 of 60068, by Old Thrashbarg
Have you checked to make sure it's not something simple like having the ISA bus speed set too high, or some random waitstate setting? One non-working card would be one thing, but three of 'em (and none of which look damaged)... sounds like there might be some other factor at play.
Reply 386 of 60068, by sliderider
There's never any guarantees with 30 year old hardware. You should frame them nicely and sell them on ebay as vintage computer art with the stipulation that they are wall hangers only and not guaranteed to be working. You'd probably get more for them than for a loose working card.
Reply 387 of 60068, by Robin4
I thought you bought those from ebay. 😘
I bought this last month'
Nice Towah
Yes this is an AT compatible tower with an socket 7 in it.
These are the specs of this computer tower:
Chaintech 5AGm2 motherboard
AMD K6 processor @ 450Mhz. 64Kb on chip cache
128MB PC100 SDRAM
Millenium G400 Matrox 16MB
Quantum Fireball EX 3.2A harddisk 6256 cil; 16hds; 63spt +/- 3GB
Pioneer DR-944 0107 CD-ROM
Philips CDD3610 CDRW
Iomega Zip 100 Zip drive
Sound Blaster AWE32
Realtec RTL 8139 10 (100mbps ethernet)
Iam going to rebuild this pc with my own stuff. Some other parts getting behind the glass as collector items..
Aztech sound galaxy 16 II pro OPL3 (for my 386 build) instead of SBPRO 2.0 (now i can use the pc speaker on this card and an wave table daughterboard. CT SBPRO 2.0 cant do that..
TERRATEC SOWT-1 Wavetable board. (maybe collector)
Blood Expansion pack Cryptic passage NEW..
The games winter challenge (good condition)
Summer challenge as well (ill copy it to 3,5inch diskette)
Primax Soundstorm with manual en driver disk.
(going to use in AMD k6 II+ build..
TYAN Trinity 100AT (S1590) (Better REV also, ME LUCKY!)
FOR MY AMD K6 II+ Rig..
SIIG Enhanced IDE Controller card with own bios on it. (Some guys here does this card also have..)(for my 386 build)
Reply 388 of 60068, by GXL750
I have that same Aztech sound card sitting in one of my parts bins. I also have a Panasonic 2x CD-ROM drive and said Aztech card is the only thing I own that has proper interface for it. I really like the appearance of that ATX case BTW.
Reply 389 of 60068, by schlang
actually it is an AT case, notice the serial keyboard port. I also have two of it myself
Reply 390 of 60068, by schlang
cache memory:
competition pro for my c64 usb adapter:
Reply 391 of 60068, by jmrydholm
@Robin4
Is that a motherboard equipped with PCI, ISA, *and* ISA slots?? 😳 wow, I'm stuck using an old PCI NVidia GeForce 2 myself. Not that I need an AGP card on a Dos/98 machine...
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
Reply 392 of 60068, by schlang
got this from a coworker this evening:
Reply 393 of 60068, by Old Thrashbarg
Yep, ISA and ISA. And also more ISA. Oh, and there's an AGP slot too. 🤣
Reply 394 of 60068, by sliderider
jmrydholm wrote:
@Robin4
It would make a great board for vintage video card testing.
Reply 395 of 60068, by SavantStrike
jmrydholm wrote:
@Robin4
That's actually not too uncommon in the PIII/Slot A Athlon era, and there are Socket A athlon mobos as well as socket 478 mobos with said features, although the s478 boards are pricey.
Some of them even have universal AGP slots, so they can work with any AGP card, whether at 3.3v or 1.5v (I'm not aware of any 8x agp only cards that require .8v).
Reply 396 of 60068, by jmrydholm
I have a socket A board in my XP system, although it's only PCI and AGP. Its the deluxe A7N8X Asus board. I had to swap out my Nvidia 7800 GS which died 🙁 sad face here...now it has a cheap old 5200 FX GeForce in it. But at least I can play Klingon Academy on it.
Reply 397 of 60068, by Tetrium
Yup! Though I prefer to not use any of the "high end" AGP+PCI+ISA boards for just testing purposes, but AGP 4x boards work with any AGP card ever made...in theory at least.
I'm using an ASUS A7V board with a Duron for testing graphics cards because of the universal AGP slot. 😉
The most recent AGP+PCI+ISA boards made for consumers were Tualatin and SDRAM Socket A boards. There are newer boards with ISA (seen LGA775 Conroe boards with an ISA slot! 😳 ) but those are scary because of their price, and the ISA slot might have compatibility issues as it's a bridged ISA slot.
Reply 398 of 60068, by Robin4
jmrydholm wrote:
@Robin4
One AGP 2x slot (in the first upperslots)
4 PCI slots
4 ISA slot.
(one pci / isa is an shared slot..) So i can use the total of 8 AT slots... MAX OF ATX WILL BE 7 SLOTS!
I need this because wants to use 2x voodoo 2 in SLI. Then i have enought space for other expension card. Otherwise the 2 slots above in an AT case wouldnt be used wisely.. Mostly there are mounted the serial and printer pararlel brackets. I like to mount those on the case self, so then i can use more expension cards. The motherboard support 3 slots of sd-ram and 2x 2 simm 72 pins memory. Iam going to use the sd-ram because i have enough of it.. I will put it to the max of 384 MB mem on this board.
with unofficial bios it will support of AMD K6 2+ and K6 3+ processor.
Official bios will only support harddrive till 30GB. Unofficial will support up to 128GB.. I will use it with unofficial bios ofcourse.
Reply 399 of 60068, by schlang
colleague of mine had another stuff for me:
oak 1mb gaphics card
2x isa controller:
unknown:
boxed sound blaster 2.0 ct1350:
boxed 3com token ring isa nic:
