ShortstopGFX wrote on 2025-03-07, 00:34:
Whoops I meant, should I just spray paint the GD08 beige then?
If so do I have to sand things down or can I just spraypaint it and add a sealing agent?
Asking since I don't want to create black paint particles to inhale in my garage 🤣
I wouldn't like the GD08 case, even beige. It looks modern. The FLP01, on the contrary, with that front bezel is perfect!
Yeah you make a very good point about the particles. These jobs should always be done with an appropriate special mask. Ideally, also in front of an air purifier, so that the fan will suck the air and filter it. But I digress...
I only painted a PC once, a long time ago, circa 2008-2010. It was the opposite actually! We had a dual CPU (Athlon XP) workstation at a recording studio, it was still kicking well! Lots of RAM and stuff... at that time, we also had modern PCs, PowerMac G5 and Mac Pros, but that old workstation was still useful and doing lots of things.
It was in a beige case!!!
Our boss 'decided' that it was 'ugly' and 'ordered' us to dispose of the PC! Just like that! I was very sad.
So, a coworker and I decided to spray paint it black. He happened to have a black spray paint bottle! (he was an ex street graffiti and break dance dude).
So, we get outdoor, there was a ramp. Oddly, the ramp had no asphalt pavement, it had like concrete and it was colored!!! Like, darkish red / light bordeaux, something like that... actually, lemme check on Google Maps... a moment...
There I found it:
It got very dirty now, the pinkish color is barely visible.
Anyway... we take some newspaper sheets, open them wide, cover the ground (downhill, where it gets flat), disassemble the PC, take tha case and start spraying it black, both the metal sides and the plastic front bezel.
We put it in a corner to dry, remove the newspaper sheets and... SURPRISE!!!
The black paint was so thin and aerosolized that it went broader than we could imagine or perceive... by removing the newspaper sheets, we saw the sharp blackish lines of paint along the edges of the sheets, which then blurred away from that sharp line! Imagine selecting something on a picture in photoshop, spraying with the large fuzzy brush, set very large, outside of the selection, and then removing the selection. Something like this:
We screwed up, and we were renting.
My friend said: there's no way we can erase this paint from this concrete floor. We're screwed.
I thought for a moment, and remembered that, long before, I noticed a reddish 1L bottle of 95% Sulfuric acid on the janitor shelf in the cleaning supplies room.
I told him: wait me here.
Grabbed the bottle, got out. He saw me with this thing.
Opened the bottle and started pouring the acid along those sharp black paint edges... VERY DANGEROUS! And we were bare feet, not even socks (it's a sea city).
Instantaneously, the black paint started to melt away, together with the acid expanding on the ground...
In the end, just a very light blackish halo remained, barely visible. Problem solved.
But now there was another problem: that powerful acid pooling all over.
So, I went to grab 2 boxes of sodium bicarbonate (500 g), dissolved it in warm water, hyperconcentrated, and poured it slowly all over using a jug and a plastic disposable water bottle. The reaction started immediately and violently... I threw the plastic jug on the floor and run away...
Imagine a gigantic beer foam growing all over the floor...
when the reaction ended... the plastic water bottle got all deformed, I guess by the heat of the reaction.
Anyway... the PC remained black and the paint didn't fall off for years. Then I moved... I don't know how long it lasted.
Bottomline: it should be fine. Just make sure not to pour concentrated sulfuric acid on it.
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
