Online account craze
Reply 40 of 48, by Trashbytes
UCyborg wrote on 2025-06-23, 19:06:
Everything's just out of control.
Data farming with a side of data farming before you can use that dishwasher !
We really need to know when you wash your dishes, how long you wash them for, how many you wash, what time of day you wash at, how many rise cycles, how hot, how much washing detergent, and what your favourite cycles are.
why ..actually im not sure why they want these details but I cant really see any good reason for farming that data.
oh we also want your location.
Reply 41 of 48, by momaka
Trashbytes wrote on 2025-06-23, 16:04:
I refuse to buy products that lock basic features behind an online account, it seems a lot of things are doing this now including Dishwashers where half the wash cycles are locked behind an online account.
Same here.
On the plus side, this has forced me to only look at buying used older stuff now, which is better for the environment anyways.
I've also repaired and "dumbified" appliances down, sometimes at the cost of great efforts... but just to stick it to the face of the manufacturer. And it's satisfying to rip out some complex garbage MCU solution and replace it with oldschool mechanical equivalents.
Reply 42 of 48, by UCyborg
Seems the basics on that Bryton work offline. At least my brother isn't missing anything so far. Presumably the only pressing need for that sort of device to go online would be to update maps or download missing maps if you use GPS.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 43 of 48, by Trashbytes
UCyborg wrote on 2025-07-08, 20:57:
I can actually understand a GPS type device needing an online hookup, getting new maps and updates along with GPS tracking would be useful.
Im not against online connection/account where it makes sense to have it.
Reply 44 of 48, by SScorpio
Trashbytes wrote on 2025-07-08, 23:49:
Realtime traffic and road closures to automatically route you around issues is also great to have. Thankfully phones handle this just fine, and can integrate into cars now.
Reply 45 of 48, by Grzyb
momaka wrote on 2025-07-08, 20:07:
If you can remove that "eCall" spyware from a car, then some day I may be your customer.
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 46 of 48, by Grzyb
NO.
There's huge difference between an *option* to update stuff online, and *needing* to be online.
A GPS receiver only needs to passively listen to the signals from satellites.
There's no justification for it needing to be connected to the internet, especially considering that GPS is most useful away from civilization, where internet connection is difficult and expensive.
Reply 47 of 48, by Trashbytes
Grzyb wrote on 2025-07-09, 05:26:
NO. […]
NO.
I don't think I ever said internet, since pretty much every GPS I have seen uses the same system as the mobile networks unless its a stupidly expensive satellite model .. online is an appropriate term. Also if you want live updates via the GPS then it'll need to be connected 24/7 and that will be via the mobile networks. Also GPS is useful even in the city when linked to a map service, said map service would require some form of connection.
As for an account, well most if not all GPS devices want that just to connect to their service, even the satellite ones require that.
So I'm perfectly ok with such a device requiring it.
Reply 48 of 48, by Grzyb
Trashbytes wrote on 2025-07-09, 06:15:
What do you mean?
GPS is satellite-based, so *all* GPS receivers are satellite models.
Some receivers are additionally assisted via GSM/3G/LTE/5G/whatever mobile networks, but should also work using satellites only.
I'm used to GPS receivers that keep maps locally, and don't need any external map services, connections, or accounts.
