Reply 40 of 44, by momaka
- Oldbie
Meanwhile, I finally got my unit washed, cleaned, and dried. Actually, that was like 2 weeks ago, but I've just been slow as usual and trying to finish a few other projects. Anyways, I'll see if I can do the recap this weekend and then (eventually) do a load test on the PSU to see how it behaves. You were completely right when you said earlier above that these FSP units are just a slight step-up from the gutless wonder PSUs... and even that's a maybe. In particular, I really don't like the low capacity of the input electrolytic caps in my unit (330 uF) - this is what I'm used to seeing in sub-200 Watt PSUs. And there were more stuff, but I'll just leave that for another post here.
analog_programmer wrote on 2025-02-07, 14:49:Finally I got those chinese TS (Taiwan Semiconductor??) SF1608G double diodes (I ordered 3 pcs just in case... and of course the chinese ali-baba-gipsy-seller sent only 2 pcs instead of 3). At least they look brand new. I measured their Vf with my trusty multimeter in diode mode and it is only 0.435 V for each diode in both pieces. I don't know if this Vf will rise to about 1.7 V under load at high temperatures. This weekend I'll desolder the original SF1603G diodes from the PSU's PCB, so I'll be able to compare their Vf values and change those with these SF1608G.
Yes, it's normal to see a low voltage drop on the diodes with no / low load. The voltage will indeed rise as the current does. Temperature does the inverse, though: lower semiconductor temperature = higher voltage drop and higher temperature = lower drop.
Let's hope the rectifiers are legit too and not just some re-labeled part with lower rating. It's already enough that they didn't send you the correct count. FWIW, the cheap Chinese BJTs on AE, Amazon, Ebay, and etc. are almost always either re-labeled parts or new parts with smaller dies, thus not able to withstand their ratings.
A few years ago, I bought 10x "13009" NPN BJTs in TO-220 case - they type that's often used in half-bridge ATX PSUs. Of course I tested them before installing, looking at the datasheet carefully to make sure I don't exceed the SOA in my tests. What I found is that they couldn't even do half of their rated current. They appeared to *almost* be as good as 13005's, but not quite (more like 13003's, but the fact that they are in TO-220 case probably helped them pull higher current than they would otherwise.)
analog_programmer wrote on 2025-01-29, 14:30:Well, now you have the opportunity to personally see the problem of these PSU models (PNR = PNF minus PFC reactor) and investigate it 😀
Yup, I see that now.
Two weeks ago, there were two more FSP units at the flea market - one the same ATX-350PNF and the other the one with almost same model, but with active APFC. Unfortunately, I forgot about them by the end of the sale, so didn't buy them... and the reason I didn't buy them right away is because I didn't know the seller and wasn't sure she'd give me a good price. Should have asked, I suppose, but oh well. These are probably gone to scrap heaven now.
analog_programmer wrote on 2025-01-29, 14:30:IR thermal camera is a costly purchase, but such a tool will be very handy in electronics repairs workshop.
Yeah, that's why I haven't got one yet... but sometimes you buy expensive tools only once and then never look back with regret. 😀
For the time being, I have a type-K meter, so I use that. It's just a nuisance to move the probe around when I want to test different parts, and airflow over the sensor
also affects the temperature readings.
analog_programmer wrote on 2025-01-29, 14:30:I don't know if it would be appropriate to ask you for diagrams/schematics of two mostly disassembled old cr*ppy PSUs, for which I can't find anything matching their actual PCBs and components (fortunately I have kept their main parts like transformers, inductors, MOSFETs, power diodes, heatsinks etc.). I also have one problematic laptop power supply to repair, but I can't find any circuit diagram for it and the root of its problem.
Sure, not a problem.
I don't actually have too many schematic diagrams (barely any, really). But with good pictures or the device in front of me, I usually make my own. When it comes to older (and especially gutless) ATX PSUs, a lot of them are a copy of each other or nearly so. With laptop adapters, it's not so much the case. But still, even these aren't that different.
