Reply 40 of 47, by Joseph_Joestar
Joseph_Joestar wrote on 2026-06-30, 04:26:
Heh, as mentioned before, I mostly did it for fun, but Creative was apparently highlighting this feature when marketing their Audigy cards.
I managed to find this page where Creative was advertising the use of FireWire for network gaming.
Interesting stuff, it made me wonder how connecting 10+ computers via FireWire would work in practice. I don't currently have the means to test that myself, but maybe someone else has actually experienced it back in the day.
My retro stuff
Reply 41 of 47, by myne
I can't imagine anyone would have.
Firewire was released in the era of ~$15 RTL8139s, and even crappy 10mbit hubs were good enough for 10 PCs.
100mbit 8port switches were well within the range of affordable for one of 10 people - and worst case you could do some hilarious looking but functional things with multiple routers daisychained.
Maybe someone, somewhere did it for a laugh.
I built:
Reply 42 of 47, by BaronSFel001
I came across this idea late yesterday so didn't dig more into it until today, but apparently back through the heyday of Windows XP (pre-Gigabit ethernet) IEEE 1394 connection was ranked as the best for file transfers: comparable in speed to USB 2.0 (a moot point for System 20 because it only has 1.1) with none of the connection compatibility hassles. On the other hand, it was underutilized: typically included as standard only on Macs and geared (like my Radeon) towards multimedia rather than general networking use. I still need to run some tests and get my system back together, including fixing my IDE connections to install Windows Me so I can transfer drivers via USB stick, but then I look forward to seeing if the FireWire that happened to come with my GPU may be the answer to the online gaming connection question I have been crunching on for years.
EDIT: Initial research indicates there is no direct way to connect from a 1394 port to the internet, despite TCP/IP being supported on the software side, because of cable transmission incompatibilities. A probable solution is a FireWire/CAT5 extender: a kit designed to overcome the tight (15 feet) range limit of a 1394 connection by using twisted-pair ethernet as an extension. A kit comes with paired units because it is meant to connect two FireWire devices, but that means a single one ought to effectively function as a 1394->RJ45 converter to other hardware.
System 20: PIII 600, LAPC-I, MK1869 Xtreme, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
Reply 43 of 47, by Jo22
Joseph_Joestar wrote on 2026-06-30, 06:46:
This is interesting, I love such strange concepts! 😄
I wonder how they managed to connect up to 63 PCs..
The Audigy has one FireWire port, it seems, so chaining isn't possible.
But there are FireWire hubs, as I've found out by reading this blog: https://oldvcr.blogspot.com/2021/06/the-paral … e-hubs.html?m=1
myne wrote on 2026-06-30, 07:44:
I can't imagine anyone would have. Firewire was released in the era of ~$15 RTL8139s, and even crappy 10mbit hubs were good enou […]
I remember that Windows XP was (is) notable to have support for FireWire networking (IP over 1394)
It can use a FireWire cable like a cross-over network cable.
Which used to be kinda cool, because back in the day not all NICs had cable auto detection.
Users needed to posses a special cross-over ethernet cable (equivalent to a null-modem cable on serial/parallel ports) to connect two 10BaseT NICs.
Fun fact: According to this old 2002 Chip Online article, Windows Me has this feature, as well! 😁
https://www.chip.de/artikel/Workshop-FireWire … _140028001.html
English Translation
Edit: There's some truth within the Creative advertisement, I think.
I think that FireWire 400 networking between two PCs/Macs made sense to users without Gigabit ethernet NICs.
With an Audigy card, the FireWire port came "for free", after all.
While to be honest it likely wasn't intended for that purpose in first place.
The real reason was that FireWire was an multimiedia port.
It was popular among high-end camcorders and high-quality webcams.
The networking feature was something Creative could use as another feature argument to gamers.
Reply 44 of 47, by Joseph_Joestar
Jo22 wrote on 2026-06-30, 19:52:
If the Audigy was hooked up to the corresponding front panel or external drive (e.g. SB0090 + SB0110) you could have two FireWire ports on the same PC.
But yeah, a hub would be more practical.
My retro stuff
Reply 45 of 47, by DaveDDS
Continues to be an interesting thread...
I did some tests a while back with my own DDLINK file transfer tool running on DOS systems, using 10m NE2000 compatible cards connected through an ethernet HUB.
And got pretty close to the theoretical max of 10 mbits / second (1.25m bytes/sec).
But this was with nothing else running on the systems (no multitasking or other interrupting hardware) and an effective direct connection between the two.
I can see some "trouble" with trying to get absolute max hardware speed on most newer stuff.
Any newer OS will be multi-tasking (and have various hardware/software interrupts going on in background as well) which means you really can't guarantee "instant" CPU response/throughput.
Also, faster network connections will be through a "switch" which since it has to figure out which physical port to send a packet to, will have to introduce some delay/buffering - as it has to receive at least part of the packet in order to determine how to route it.
And with even a small delay "in transit", how the higher-level protocol/drivers deals with that delay can greatly affect effective throughput.
If you really want to measure actual hardware throughput of the network transceiver in the NIC, you would want to use a back-to-back connection (no switch, only two directly connected nodes) which will means you have to stick to basic low-level packet (a higher level protocol will most certainly require more than simple negotiation between the two endpoints)
You would also have to set up an OS with minimal background activity for max. response and throughput.
Could be fun ... but I would expect that with the right setup you could achieve network throughput noticeably higher than you would see in "real world" conditions.
But... just guessing, could be "fun" to set it up and see how close you can get to the theoretical max. and how close a "normal" system could come!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 46 of 47, by Grzyb
DaveDDS wrote on 2026-07-01, 04:02:
I did some tests a while back with my own DDLINK file transfer tool running on DOS systems, using 10m NE2000 compatible cards co […]
Yes, theoretical maximum for 10/100/1000 Mbps Ethernet is 1.25/12.5/125 MB/s.
In real-world conditions, using normal FTP, they can score 1.1+/11+/110+ MB/s - but only with Full Duplex!
NE2000 lacks FD, so if you managed to get it close to 1.25 MB/s, then it's quite an accomplishment, indeed.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 47 of 47, by DaveDDS
Grzyb wrote on 2026-07-01, 05:07:
... NE2000 lacks FD, so if you managed to get it close to 1.25 MB/s, then it's quite an accomplishment, indeed.
I don't recall the exact numbers, and at that time I hadn't yet added the options to automate DDLINK, so I was starting the transfer manually and timine it with a stopwatch. I was mainly interested in transfers over Com and Lpt (which are much slower).
IIRC my test was a binary file exactly 1mb = 1024*1024 bytes = 1,048,576 bytes.
DDLINK defaults t0 1024 byte "packets" and has 5 byte of overhead (start1,length2,...data...1024,crc2), but CRC is omitted in network (which already has crc) and packet adds tomac6,frommac6,type2 & CRC (i don't recallif this is 2 or 4) - so assume +16 = 1024+3+16 = minimum 1043/packet + whatever the NIC uses to identify start/size/end etc. = so at least 1024*1043 = 1,068,032 bytes = 8,544,256 bits.
I do recall it was about a second to transfer ... which at the time was WAY less than the other methods.
Now that I can automate DDLINK keys (ie: make the transfer happen automatically), I could do the test again with a program timing with the DOS 55ms "tick" and get a much more accurate number (and use a bigger file as well).
I didn't do this because DDLINK is a Q&D tool I wrote to move IMD images on/off of DOS booted from floppy with a RamDisk for main storage. And at the time I was characterizing how long it takes to move a 1+ mb image over Com or Lpt --- Lan was so much faster I really didn't worry about investigating further.
