Volkov Commander and alternatives
Reply 40 of 43, by Grzyb
ntalaec wrote on 2025-12-09, 10:04:
Impressive! I was looking for a commander with minimal space requirements to use in a boot floppy disk. Could SP.HLP be integrated in SP.COM? In FAT12 filesystem (used by floppy disks) cluster size it's 4KB so a lot of space is wasted.
In my opinion, for use in a very disk space constrained setup, it's better *not* to integrate help in the executable.
That's a simple program, easy to learn - and once you thoroughfully learned it, you can delete the help file...
Nie rzucim ziemi, skąd nasz root!
Reply 41 of 43, by marxveix
I have been using doszip long time already at dos and i have been using dos dz at Windows 9x as well. 😀
Doszip Commander - dz is a classic File Manager for DOS and Windows, inspired by Norton Commander
Featuring a two - panel interface and built-in ZIP/UnZIP capabilities, supporting Long File Names (LFN)
https://sourceforge.net/projects/doszip/
https://sourceforge.net/projects/doszip/files/
https://sourceforge.net/projects/doszip/files/DOS/
Latest DOS version is v2.68 and latest for Windows is v3.90/v3.91
https://sourceforge.net/projects/doszip/files … 68.zip/download
https://sourceforge.net/projects/doszip/files … 32.zip/download
https://sourceforge.net/projects/doszip/files … 64.zip/download
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 42 of 43, by igully
Grzyb wrote on 2025-12-09, 10:38:
I have to fully agree with Grzyb's opinion. Just learn how to use it and ditch the help file if it is too much for your storage space. In any case, it follows all the traditional operations in the most standard way. I also use it on several of my own boot floppies.
Reply 43 of 43, by crusher
Grzyb wrote on 2025-12-09, 08:48:
What do you mean by "native DOS"? Real-mode, rather than using a protected-mode DOS extender?
1.51 is the last version from RIT Labs - real-mode DOS only.
Later on, there were various forks: Dos Navigator Open Source Project, Necromancer's Dos Navigator, and others - for various targets: real-mode DOS, DOS extender, OS/2, Win32, etc...
Thanks, that was the answer to my question.
I meant real-mode DOS then.
