Reply 40 of 42, by Horun
- l33t++
Daniel4200 wrote on 2025-04-03, 20:25:Thanks […]
Horun wrote on 2025-04-03, 01:13:The Contender motherboard is listed on the old Viglen website, unfortunately the links go dead from there. See bottom of this: h […]
http://web.archive.org/web/20000306001253/htt … otherboards.htm
Also there were video drivers which are mirrored here: https://download.xma.co.uk/Motherboards/Archive/Contender_1/
Based on the 9155-01 cpu/bus clock generator and your current jumpers for 25Mhz (comparing to other boards with same), E7 should be like this:
CPU Mhz Jumpers
20 MHz 1-2 Closed
25 MHz 3-4 5-6 Closed * current setting
33 MHz 3-4 Closed
40 MHz 5-6 ClosedYou can test this by changing to 20Mhz and see if it boots and what the BIOS says....
added: figuring out the cache jumpers and cpu jumpers will be a diff story !. If you upgrade to a sx33 you should not need change any jumpers but the cpu clock....which we can easily figure out...Thanks
This will be really helpful it i do upgrade the cpu.
For now I'm just waiting for the extra cache and disks to be delivered. Then maybe play a little Frontier Elite.
It looks like E9 is the Cache size jumpers. One other similar board/chipset with same number jumpers and all off are 0 cache, like yours.
For that board it shows:
0K All Open
64K 3-5 4-6 Closed
256K 1-3 2-4 7-8 9-10 11-12 Closed
That would be the starting point IMHO....
E10 may be for single bank/dual bank or cache interleave, would have to experiment....
