Seagate Tools for DOS not loading
Reply 40 of 69, by DustyShinigami
Okay, my suspicions were confirmed correct. Because HDD D and E were messed up, particularly D as it was showing up twice in Windows, that's why the SeaGate Tools disc wasn't loading properly. However, I've since rescued the contents of the drives, reformatted them, put the files back, and everything is recognised correctly. The SeaGate Tools disc now loads up properly. 😁
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 41 of 69, by Harry Potter
That's good! 😁 How's your memory config?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 42 of 69, by DustyShinigami
Harry Potter wrote on 2025-10-26, 14:06:
Thanks for the help, by the way. 😀
This is how it's looking. Still not much added yet, but hopefully I can put a bit more focus on configuring things and installing some games. 😀
The attachment IMG_5034.JPG is no longer available
OS: Windows 98 SE
Reply 43 of 69, by Harry Potter
I ask you to try EMM386 and the tweaks I think I gave you. 😀
Reply 44 of 69, by DustyShinigami
Harry Potter wrote on 2025-10-26, 14:50:
Is EMM386 not enabled...? I was under the impression it was. I have C:\WINDOWS\COMMAND\EMM386.EXE ON and DEVICE=C:\WINDOW\HIMEM.SYS in my config.sys file. I still need to investigate why CuteMouse isn't working, too.
OS: Windows 98 SE
Reply 45 of 69, by Harry Potter
I think you need to specify "RAM" on EMM386's command line. 😀
Reply 46 of 69, by DustyShinigami
Harry Potter wrote on 2025-10-26, 15:02:
I've never been quite sure what switch to add there. I've had it set to 4096 before.
OS: Windows 98 SE
Reply 47 of 69, by Harry Potter
If that doesn't work, try adding "DOS=HIGH,UMB" to your config.sys.
Reply 48 of 69, by DustyShinigami
Yeah, that's there, too. 😀
OS: Windows 98 SE
Reply 49 of 69, by Harry Potter
When you type "MEM," does it show anything under Upper memory?
Reply 50 of 69, by DustyShinigami
Harry Potter wrote on 2025-10-26, 23:41:
For some weird it's 0. I have DOS=High, UMB first, then HIMEM followed by EMM386.
The attachment IMG_5035.JPG is no longer available
OS: Windows 98 SE
Reply 51 of 69, by Harry Potter
Try typing MSD at the DOS prompt: it should show you the layout of your system's memory. To make sure it's not your or EMM386's error, try "I=B000-B7FF" on EMM386's command line. Also, I had a similar problem among others on a Win98SE tower before. I used QEMM's MANIFEST utility to help see why I wasn't getting any UMB memory and found 64k that was supposed to be free, and adding an include of the lower 32k into EMM386's command line got it to work. Using UMBPCI instead of EMM386 helped a lot more. It is a memory manager that uses the hardware to gain UMBs. You can find a link to it at https://dosprograms.info.tt/indexall.htm. Try it out, and see if it works on your system.
Reply 52 of 69, by DustyShinigami
Harry Potter wrote on 2025-10-27, 23:27:
Unfortunately ‘MSD’ doesn’t appear to be recognised in the command prompt. I tried adding I=B000-B7FF at the end, but it doesn’t appear to have done much. It’s still saying Upper is 0.
I’ll have to check out that memory manager
OS: Windows 98 SE
Reply 53 of 69, by Harry Potter
Did you try the memory manager yet? I'm wondering because you haven't responded yet.
Reply 54 of 69, by DustyShinigami
Harry Potter wrote on 2025-11-04, 00:19:
Ahh, sorry. I totally forgot. I've been distracted with investigating and fixing other issues with the rig and I wound up reformatting the system again. ^^; I thought I'd downloaded it, but it doesn't look as though I have. And when I try to, it won't let me. It seems to think the VPN is on when it isn't.
EDIT: Okay, managed to download it via a different web browser.
OS: Windows 98 SE
Reply 55 of 69, by Harry Potter
Understood. If you're having problems downloading it, I can look for it on my hard drive and attach it here. Do you want me to?
Reply 56 of 69, by DustyShinigami
Harry Potter wrote on 2025-11-04, 00:46:
No, you're okay. I managed to get it in the end. Thanks though. 😀 I've popped it on my pen drive, but I'll give it a try sometime tomorrow.
OS: Windows 98 SE
Reply 57 of 69, by DustyShinigami
Okay, I've installed UMBPCI and this is the result:
The attachment IMG_5070.JPG is no longer available
The attachment IMG_5068.JPG is no longer available
The attachment IMG_5067.JPG is no longer available
OS: Windows 98 SE
Reply 58 of 69, by Harry Potter
So it worked! 😀 I think there's a SHELLHIGH command in CONFIG.SYS to load COMMAND.COM high. Try it. Also, try the CUTEMOUSE driver. You can find it online at https://dosprograms.info.tt/indexall.htm under Utilities.
Reply 59 of 69, by DustyShinigami
Okay, I'll give those a go tomorrow. 😁 What's the benefit of command.com high, exactly?
OS: Windows 98 SE
