Pocket 8086 Boot Error
Reply 40 of 42, by RetroPCCupboard
asdf53 wrote on 2026-02-06, 20:51:
If all connections are good, I would remove both chips and then solder one of the new chips in place of the old working chip to see if they work at all.
OK. Well, after much thought, I tried that, and it did work. Only recognising 512kb still though.
So I removed the first chip that I soldered and put another one. And, I am I shocked! It works!
That's the first time I have managed to fix a computer by replacing a component. I am chuffed!
Thanks All!! I really appreciate your help and guidance.
The attachment 20260211_071235.jpg is no longer available
The attachment 20260211_072720.jpg is no longer available
Reply 41 of 42, by DaveDDS
RetroPCCupboard wrote on 2026-02-11, 07:29:
... That's the first time I have managed to fix a computer by replacing a component. I am chuffed! ...
Awesome! - good to hear! (it really does "feel good" when you get things to work)
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 42 of 42, by RetroPCCupboard
DaveDDS wrote on 2026-02-11, 11:54:
It sure does! Happy to have my little pocket XT rocket back to life again!
