Reply 40 of 54, by Ozzuneoj
- l33t
Rubix wrote on 2026-02-02, 20:45:Ozzuneoj wrote on 2026-02-02, 20:22:I'm not saying that I recommend doing this, but I have actually seen the "freezer trick" work with dying hard drives. There are also half a dozens reasons why you shouldn't do this though, so... yeah. 😅
Yes, I've heard of it. But I thought it was only for drives that suffer from stiction. Let's first see what ddrescue manages to save. In my experience, it's often able to get quite a bit of data off of bad hard drives. Although this one is really bad, and especially executable files/drivers/etc. can't have errors in them.
Ddrescueview shows a nice visual of how bad the situation is 😅
Oof! Wow, that looks bad. But hey, the drivers for the sound card came on two floppy disks and we really only need probably a handful of files from one or the other. If 1MB is readable and it happens to contain what we're looking for then that would be okay for now. 😅
Regarding the freezer trick, I will make no on-record statement as to whether I was involved in the decision or not, nor will I take the credit for recovering that customer's files ~20 years ago (🤩), but at least in that situation it wasn't used to revive a drive suffering from stiction. It was a click of death of some sort as I recall.
(Again, this is not an endorsement... but if you use ddrescue and it doesn't find enough to be useful, and swapping the PCBs doesn't help, then... well...)
