Reply 40 of 41, by Feliksas
red-ray wrote on 2026-02-05, 10:41:
Feliksas wrote on 2026-02-05, 09:24:
Well, I've also found a couple posts here and there claiming it's PReP, but that isn't easily verifiable
Mine has the 332MHz 604e
the Matrox 220 GPU might be the culprit.
Yes it is, see https://www.youtube.com/watch?v=fjXZh-a9WZE
Actually, I'm not so sure it is pure PReP anymore 😀
0 > dev /  ok
0 > .properties
name IBM,7043-140
model IBM,7043-140
compatible IBM,7043-140
clock-frequency 03f64598
device_type chrp
pc-emulation
exception-relocation-size
00100000
processor-hole
system-id 0002035macadd
#address-cells 00000001
#size-cells 00000001
platform-open-pic f96c0000
ok
0 >
Reply 41 of 41, by atar
Feliksas wrote on 2026-02-06, 15:17:
I've actually ordered an S3 Trio64V+ 86C765, planning to replace the BIOS on it and try
I'm not 100% sure, but it comes to my mind that IBM PPC has gone a different road than Sun and Apple, and they don't need specific FCode VGA BIOSes. Instead they have built a small 8086 emulator in a firmware, and execute the usual VGA BIOS using CPU emulation. Don't know if it applies to all IBM firmware though. Can you please try your Matrox in a 80x86 machine to check whether it has a usual VGA BIOS?
