Reply 40 of 571, by PcBytes
- l33t
FWIW KG7 / AMD 761 was a tough animal to tame.
- CPU limit - apparently a 1333's limit is a rather unimpressing (at least to me) 1.5GHz. The one thing that helped a lot on my T-Bird is the multi being "Free Bird".
- stability - seems to take a nuclear reactor type voltage to stay stable. Mind you - I was having the CPU at 1.85V (the utmost high the BIOS allows me to run on it), RAM at 3V (yes, DDR at a whoopin' 3v!!!!!!) and the I/O voltage at 3.65v. Despite all this, it took me several tries until I could get a stable 3DM01 run.
- GPU - not really sure what was going on here because everything I knew with the ST6 overclocking went totally OUT THE WINDOWWWW - with i815 I at least knew that nVidia doesn't care about AGP overclock while Radeons are highly fussy about it. The COMPLETE OPPOSITE has happened here - I could not get a single nVidia card, from as old as Ti4200 to as new as 7800GS (G70), to even run stable. Dropped a 9800XT, a 9800 Pro and even a X850XT, and the further I went in generations the stable it'd get (with X850 being THE most stable out there.), which can be seen above with the X850 scoring about 10k @ 1.5GHz.
I spent at least 4 hours total on that (including figuring whether I was doing something wrong or not!) and figured the 761 is just that quirky. But hey, at least I can brag about having a less common chipset among a sea of nForces 🤣
