Reply 40 of 43, by Shiftyy
King of compatibility, but only for the games you care for?
There is nothing special about this build.
Shiftyy wrote on 37 minutes ago:King of compatibility, but only for the games you care for?
Nemsokára próbálok olyan címet is, amit nem használok, illetve amit fentebb említettek.
Amúgy nagyon király a gép, szerénytelenül a világ egyik legjobbja retróra és modernre is, nem tudod elvenni a kedvemet te sem
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
I did run into some trouble with AIDA under Win3.11. Between the 16-bit/32-bit issues and the fact that the "retro" versions either won't run at all or display incorrect data, it was a struggle.
I saved a screenshot and a log file from the DOS version of HWinfo, then loaded them into Paint and Write within the Win3.11 environment.
DarthSun wrote on 17 minutes ago:Nemsokára próbálok olyan címet is, amit nem használok, illetve amit fentebb említettek. […]
What's special about it?
