Parallel port passthrough (Windows only)
Reply 41 of 44, by easyw3
I'm having problems in running portalk.sys on win7 32bit...
when I test porttalk I get this error
'Unknown Error While Starting Service. Service was NOT Started'
and Megabuild doesn't get the parallel port...
(UAC is disabled)
Any suggestion?
Reply 43 of 44, by easyw3
my problem is on running porttalk.sys as service...
in Vista I get no error, but in win7 32bit I cannot start correctly the service...
here I found some suggestions,
http://psychtoolbox.org/FaqTTLTrigger
but without a solution ...
still the service porttalk is not running...
Reply 44 of 44, by easyw3
I solved with some coding, porting InpOut32 64bit driver to the dosbox megabuild, substituting porttalk to access lpt under 64bit systems.
thanks to the help I got in the forum 😀
dosbox megabuild setup.cpp error
directlpt_win32.cpp
to anyone that could be interested in, the source is here
download.php?id=10054
