Reply 40 of 44, by prismra
- Newbie
Opens programming book; cries.
Rocking the following:
Roland MT-32
Roland SC-55 Sound Canvas
Roland MT-32
Could you explain why the ripping/mounting work-around isn't pratical? I mean imgmount will mount raw bin/cue images with multiple tracks correctly. It will also allow you to mount multiple images and "switch" disks using CTRL-F4.
So unless you have a harddrive space issue - but then I would suggest burning the CD bin/cue images onto a single DVD and running everything off of that.
So what is the problem with this work-around?
I don't mean to come across like an ingrate (despite my previous apparently ire-inducing post) but it would be great if it worked like the windows version.
I can have my Windows DOSbox.conf file automount any CD that is in my drive and simply pop in any other disk as needed by the game in question with no issues.
With the OSX version, you have to manually mount the disk each time since the OS will mount it under /Volumes using the disk label. Unless I'm mistaken, you can't have it just mount whatever is in your cd drive automatically; that is a pain.
On top of that, ripping disks is time consuming and a waste of HD space when you could simply pop in the disk.
Roland MT-32
Just use a separate dosbox.conf file for each game and mount the disc in the autoexec section or just use DBGL.
wrote:With the OSX version, you have to manually mount the disk each time since the OS will mount it under /Volumes using the disk label. Unless I'm mistaken, you can't have it just mount whatever is in your cd drive automatically; that is a pain.
True, that's a disadvantage of the MacOS operating system. A workaround is maybe to know the disk number of the CD drive, as written in this thread of OSXFAQ:
Mount both the iso9660 _and_ HFS partitions of a hybrid CD
This is what I see for the CD in /dev […]
/dev/disk1
/dev/disk1s1
/dev/disk1s1s1
/dev/disk1s1s2
It depends on the number of Volumes mounted, which disk number the CD currently is.
Maybe mounting /Volumes/disk1 (for example) will do but:
1) The user have to know which disk number the CD currently is
2) I still have to check, if it would work with different CD mediums.
Klimawandel.
