Reply 41 of 47, by NJRoadfan
Another card with new bus popped up in an ebay auction. Don't know the name of it, but the FCC ID indicates this board was made by Acer. It uses a 2nd ISA slot similar to the Gigabyte local bus, but the slot is offset further back on the motherboard.
    328.47 KiB
    301.51 KiB
    1.35 MiB
    264.74 KiB
Reply 42 of 47, by NJRoadfan
Some more photos of the Acer card. This time the rear. Looking around, this may slot into the Acer J1 motherboard: https://theretroweb.com/motherboards/s/acer-j1
PC World January 1993 Page 113 Mentions it: https://vintageapple.org/pcworld/pdf/PC_World … anuary_1993.pdf
Needless to say, the Model 5657 took first place in every test. Aside from its high-speed CPU, it boasts all the right performance features, including 8MB of RAM , a 256K external memory cache, an EISA bus, and a video accelerator described by Acer's strategic planning manager L. Pablo Grodnitzky as "a proprietary local-bus graphics adapter using ATI's high-performance video chip and our own proprietary ASICs."
So this was firmly an OEM special bus.
    289.49 KiB
    218.29 KiB
    1.29 MiB
Reply 43 of 47, by rasz_pl
NJRoadfan wrote on 2023-09-20, 02:16:
unsurprisingly nothing on that card is proprietary 😀 ATI TI Lattice National Excel IDT/Renesas OKI ST, everything off the shelf :] That was the beauty of VLB, you could build it from parts bin with no investment in new chip designs.
Reply 44 of 47, by mpe
I ended up buying it. I kind of collect this sort of stuff and at first thought it might be a gigabyte local bus card. It is nice to have Mach32 card in all its bus variants (got ISA, PCI, VLB, EISA and this one, only missing MCA or more?). I think none of the other chipsets had so many bus options (maybe perhaps ET4000AX)
Blog|NexGen 586|S4
Reply 47 of 47, by DerBaum
mpe wrote on 2023-10-06, 08:39:
I doubt it. That one is a 386 with memory expansion slot.
Year... 1992 (based on the date on the chips of the card) seemed a little bit too new for a 386.
Would you say its probably from a 486? That would make more sense as a 386.
FCKGW-RHQQ2
