"Demanding" MS-DOS games for a 1.4 GHz Pentium 3
Reply 40 of 68, by jwt27
Mau1wurf1977 wrote:
I get good scores for VGA:
3DBENCH2: 665.7
That sounds pretty slow to me, for a 1400. I've just been trying out some graphics cards on the Katmai system in my sig (at stock speed, 550MHz). I got 783.0 on a TNT2 AGP. (the Voodoo3 does 797.3)
Reply 41 of 68, by vetz
Specs:
Asus P3B-F 1.03 1.4 GHZ Pentium 3 Tualatin (440BX chipset)
1024 CL2 SDRAM
Nvidia Geforce 5950 256MB Ultra
Results with FASTVID
3DBENCH2: Weird result of 467,8 with FASTVID and 511 without. The benchmark itself is running at 2x the speed with FASTVID compared to without, so I guess the speed broke the score. The benchmark program can't show more than 4 digits, so I believe the correct score to be 1467,8.
PCPBENCH: 180,7
quake 1.06 timedemo demo 1 (nosound):
320 x 240: 268,8 FPS
640 x 480: 95,6 FPS
800 x 600: 67,1 FPS
1024 x 768: 44,2 FPS
Reply 42 of 68, by jwt27
I don't think 3DBench2 is very accurate anymore at these speeds. Even the latest version (1.0c) was designed with 486/P1 speeds in mind. It probably shouldn't be used as benchmark tool at all on P2 and above.
Reply 43 of 68, by sliderider
What would be funny is if you used something like Go Slow and the results went up instead of down.
Reply 44 of 68, by Mau1wurf1977
vetz wrote:
Specs: Asus P3B-F 1.03 1.4 GHZ Pentium 3 Tualatin (440BX chipset) 1024 CL2 SDRAM Nvidia Geforce 5950 256MB Ultra […]
Specs:
1024 CL2 SDRAM
PCPBENCH: 180,7
640 x 480: 95,6 FPS
800 x 600: 67,1 FPS
Thank you so much for testing this 😀
Looks like there is something that's holding back SVGA performance on the VIA chipset board. Just shows how good the BX440 is.
My YouTube channel
Reply 45 of 68, by vetz
No problem. Quite surprised of the results myself. Maybe someone else could test with newer Intel chipsets and see how they perform. I do agree that your VIA chipset do seem a tad slow.
Reply 46 of 68, by Mau1wurf1977
Yea it's weird. The VGA performance is definitely there. But go to SVGA and performance plummets.
I tried some BIOS settings, AGP settings, but made no difference.
Maybe there is a tool like FASTVID but for VIA chipsets rather than Intel which unlocks even more performance?
My YouTube channel
Reply 47 of 68, by schlang
leileilol wrote:
Jane's ATF or Jane's US Navy Fighters with the textures enabled at 1024x768. Quite the demanding games coming from 1994-96 😀
the engine of these two games doesn't scale, I was never possible to come over 20fps with all details on, even on a i7 CPU 😀
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 48 of 68, by mr_bigmouth_502
Wait, so you actually booted DOS on an i7 and ran those games? 🤣 Somehow, I never thought that would be possible.
Reply 49 of 68, by dirkmirk
Ive got the Via chipset in my Tualatin 1.4 system and im also curious about the chipset speed, for reference I get 9,600 points in 3DMARK 2001SE at stock settings with a X800 PRO, obviously CPU limited but is anyone else able to run a beast graphics card that will be CPU starved for comparison on a different chipset for this CPU? A Geforce 4TI/ATI 9800 PRO will be good enough
Reply 51 of 68, by leileilol
also modern video hardware strips more VESA functions (not just the Windows XP NTVDM restrictions imposed on them) so it's not even recommended.
Reply 52 of 68, by schlang
y not? some people even try to run win311 on an i7 😁
http://www.youtube.com/watch?v=EM6q5iuy1oM
Reply 53 of 68, by mr_bigmouth_502
Does it actually run, or does it just crash on that glitched startup screen? 🤣
Reply 54 of 68, by dirkmirk
Mau1wurf1977 wrote:
Hi!
This thread is really for high resolution DOS games 😀
I thought it would be relevant to test whether the VIA chipset is complete shite or not, my system is packed away atm so cant test it for dos games, Lellehol stated that poor performance is probably due to too new a video card or too old like your s3, so sounds like we need a sweet spot for high end dos gaming.
Reply 55 of 68, by vetz
I got about the same last time I ran 3Dmark 2001SE on my 440BX rig. Graphics card is Geforce 5950FX Ultra. This was under Windows98. Haven't tested in WinXp.
Reply 56 of 68, by Tertz
Mau1wurf1977 wrote:
A S370 board that can't take the 1.4, but does take a regular 1.0GHz / 133 FSB Pentium III <...> Quake timdemo demo1: 640 x 480: […]
640 x 480: 60
800 x 640: 43.4
1024 x 768: 28.9
As fastvid was made for Intel 440FX and 440BX chipsets, so MB with other chipsets will give less results. Maybe it's this case.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 57 of 68, by kithylin
I have my "Super MS-DOS" Machine I could test if you guys wanted.
EpoX motherboard with KT-133A Via chipset (For that one ISA slot so I can use an AWE64 with it), AthlonXP mobile Barton chip in it with a slight overclock to 1.8 ghz and PC-155 ram, and a Geforce2 Ultra. It's the fastest SVGA gaming machine I've ever played with or built. It does Descent II @ 1024x768 SVGA at above 60 FPS (gives tearing when turning.. which is a sign of going past 60 FPS usually).
The only game it does poorly in is Quake I though, I've always thought it was just because it's an AMD system and Quake I was optimized with pentium instructions and thus leaned towards Intel CPU's only.
But yeah, I could boot it up and run tests for you if you liked.
Reply 58 of 68, by Tertz
vetz wrote:
Asus P3B-F 1.03 1.4 GHZ Pentium 3 Tualatin (440BX chipset), 1024 CL2 SDRAM, Nvidia Geforce 5950 256MB Ultra quake 1.06 timedemo […]
640 x 480: 95,6 FPS
800 x 600: 67,1 FPS
If to make an approximation, taking into account other video mode 320x240->320x200 and viewsize 100->120, then in Quake section of Phil's testing this machine would get ~257 fps. Vetz took part in that testing, but not with his P3 1400(S?).
Yamaha YMF7x4 Guide
Reply 59 of 68, by MrEWhite
Blood is pretty demanding at some parts of the game on any computer at the resolution 640x480 and above.
