Reply 40 of 40, by Samir
computergeek92 wrote:
I just read on a website regarding "Out of Hunk" errors: […]
"actually with the files and buffers settings, you should actually only have about files=30 UNLESS you are running Windows (3.1 or 9x), in which case you should have files=50 at least
Freeing up files frees up extra xms which should solve some problems
Also, games that were after KQ4 will probably need at least a Pentium to run properly anyway, as all Sierra games seem to have gotten lots better after kq4."
So setting Files to 50 should cause no problems when I use my retro PC for equally playing games inside Dos and Win 3.11?
EDIT::: I just tried setting Files to 50 (instead of 30) and I got 1k less free ram...
Next question: How do I make DOS run in upper memory, instead of being in the high memory which it now rests?
I want to free even more conventional memory.
I wouldn't set files as high as 50 unless you have problems without it, which I doubt as most games (even under windows) shouldn't have that many simultaneous files open.
To get dos into upper memory, put this after himem and emm in your config.sys:
DOS=HIGH,UMB
