Reply 40 of 44, by cdoublejj
- Oldbie
wrote:You'd need a fairly high resistance potentiometer, and very well insulated to boot. G2 voltage isn't super high like 2nd anode or focus, but still high enough to make your life difficult (up to a thousand volts or so). If you could get an old focus/screen divider network from an old large screen TV (back when they were a separate unit and not a part of the flyback transformer) you might be able to use it for such a purpose.
Is it impossible to find such large/massive POT? how many watts would it need to handel? what does this divider looks like? IS there a way to figure out where the leads need to be soldered to? i saw reference to it several times in the ironctic forums a few members did the resistor mod the to the P992. it just seems firmware may not / is not viable.
EDIT: would i want something like this?
http://www.ebay.com/itm/Vintage-Zenith-Replac … =item20f6f06da0
