Reply 40 of 58, by jefklak
- Newbie
ozzmosis wrote on 2018-12-06, 09:10:Responding to an old message here, but: […]
wrote:-They change the partition type of the drive to prevent any other machines from accessing the contents of the drive. This used to not be a problem in the Windows 9x days as you could kick start a machine with an EZDrive or Ontrack equipped floppy, but its not possible with Windows NT based OSes. This eliminates the convenience of popping a CF card into a reader on a modern machine. Also in many cases, one might inadvertently format a drive with data on it thinking its blank.
I'll probably start a separate thread on this, but if my experience with Ontrack Disk Manager is any guide, it's not difficult to mount a CF card that has a drive overlay installed using any Linux PC and a CF card reader. (The same applies if using a modern large IDE drive and a USB adapter.)
The "mount" command for VFAT in Linux supports an offset, which in my case was 0xFC00 (64512), where the MS-DOS 5.0 boot sector is located.
So in Ubuntu, the full command to mount the CF card of my Compaq Portable II is:
sudo mount -t vfat -o offset=64512,noexec,rw,umask=0000 /dev/sdx /mnt
Where /dev/sdx is my card reader (/dev/sdd in my case).
Sorry for bumping this, but I had a lot of trouble trying to read an SD card that I formatted using Ontrack (with an SD to IDE adapter on a 486 with an old motherboard).
Thank you very much, this mount command finally did the trick!
However, my main OS is OSX, and mount in OSX does not seem to support the offset.
(mount -t should be "msdos" in OSX, and options offset and umask are unsupported)
Also, I have no idea how to achieve this in Win.
Does anyone have experience trying to read an SD/CF flash card with dynamic drive overlay stuff on it?
Thanks a lot!
