Reply 40 of 84, by shamino
- l33t
Through a couple of stupid errors, I managed to cause damage to both of the Model M keyboards that I have. On the first, an earlier model, I broke the escape key when it fell from a high place. Much later, some keys at the lower left stopped working for whatever reason.
The second one, a later model with the drainage channels, I put the casing in the dishwasher and warped it - so that one doesn't have a top anymore. Between those 2 Model Ms I made daily use of one or the other for a few years.
What I like about buckling springs is that the click positively tells you whether the key has registered. No click, no key. To the point that with my broken ESC key mentioned above, the only way to make that key work "coincidentally" also made it click. Click and function seem to be directly intertwined.
The keys on the Model M also slide smoothly without binding up. So I do think the build quality of the Model M keyboards is impressive. However, I didn't have much success learning to type with them. I think I have 2 problems. The lesser problem is that I frequently don't hit the keys square, as if the keycaps are too narrow or something. I don't know why I have that trouble, but it seems like I do.
The big problem I have though is the long throw of the keys. It seems like I'd get used to it, but I never did, I stumble on the Model M a lot, frequently getting keys out of order.
The keyboard I had from childhood through college years is a different mechanical type with Alps switches, so I guess that feel is just burned into me. I finally found one on eBay about a year ago and it definitely needs some refurbishment, but even in it's crummy current condition I felt immediately comfortable. It's like an old pair of shoes I guess. I don't think it's quality is as good as the model M but my mind is wired for it, apparently.
