IBM XT 5160
Reply 40 of 95, by bjt
Thanks, I have a V20 in the mail so I guess it's that version I would need.
Looks like the XT-IDE works, at least the BIOS part. What a great piece of hardware! I'm seriously thinking about hardwiring one to the bus expansion port of my 8086 laptop, I reckon the XT-CF and a card would fit in the empty HDD bay.
Well the XT project is coming along nicely, I tried a spare SB16 CT1770 and it worked fine in an 8-bit slot (tested with Prince of Persia). Although this machine is way too slow for digital sound, no harm in having Adlib & a joystick port. I might wire the PC speaker output to the SB16 and connect the internal speaker to one channel, using the diagnostic header. That way it's still a self-contained system without external speakers.
I also have the V20, a black Gotek and an 8-bit EGA on the way for some 16-colour goodness. Will play around with some composite games first though!
I'm going to try using a microdrive instead of normal CF, just for a change. Bought some black spray paint to spray the 5.25->3.5 bezel.
Reply 41 of 95, by carlostex
XT-IDE+ BIOS with HD Floppy support:
(note: only for CPU's that suport 80186 instructions like NEC V20 and up)
The attachment ide_xtp.rar is no longer available
XT-IDE BIOS with HD Floppy support:
(the following version will work with 8088/8086 and up)
The attachment ide_xt.rar is no longer available
Enjoy!!!
Reply 43 of 95, by bjt
Alright, we have a new hard drive! The CF-IDE bracket I bought from eBay doesn't work, I'm not sure why yet. I borrowed the CF-IDE adapter from my Thinkpad to test for now. The microdrive is such a cool piece of (obsolete) tech, can't believe there is a tiny platter in there.
Reply 44 of 95, by bjt
Still not happy with the amount of noise generated by the PSU fan, so I drilled out the rivets and replaced it with this Noctua & rubber fan mounts.
Reply 45 of 95, by bjt
Because the 5160/5153/Model F package is a nice self-contained system, I didn't want to introduce non-matchibg speakers into the mix. The stock PC speaker is quite loud so a volume control would be nice too.
I ran the PC speaker to the SB16 and the internal speaker to the SB16 diagnostic header for mono output. This provides volume-controlled PC speaker, FM and digital sound via the internal speaker. The PC speaker input is prone to audio RFI but it can be minimised by setting the PC speaker input level to minimum. The 5160's speaker output is extremely loud so I used a ~1k resistor to match levels with FM/digital.
Reply 46 of 95, by oerk
Nice!
I've also noticed the RFI on the speaker input. I've read somewhere that one can only connect the + side of the cable, and insert a capacitor (I think 1µF) between the speaker + and - on the mainboard. Can't remember where I found it though, and haven't tried it yet. Maybe I'm misremembering.
How's the noise level with the new fan?
Reply 47 of 95, by Scali
I think that's only if you want to do a raw tap of your PC speaker:
http://www.oldskool.org/guides/speakerrecording/#Alternate
But the SB has a PC Speaker input for its mixer, and afaik all the required circuitry is already on there (the manual doesn't mention that you need to do anything other than just connect the wire from motherboard to card).
On my SB Pro 2.0 it's very quiet in my 5160, used it to capture the party version of 8088 MPH: https://youtu.be/yHXx3orN35Y.
The final version was done with a direct tap using a capacitor: https://youtu.be/hNRO7lno_DM.
The SB sounds different, as if it runs through a low-pass filter, to remove some of the noise, and make it sound more pleasant/speaker-like.
Reply 48 of 95, by bjt
It's nice and quiet now, just an air moving sound. I think fan bearing tech has come a long way since the 80s.
Next up - flash my new Gotek with the HxC firmware and install it with the black bezel.
Reply 49 of 95, by badmojo
Loving this thread! Keep up the good work 😎
Reply 50 of 95, by Scali
I don't think these systems run all that hot anyway, under normal conditions... Perhaps a temperature-controlled fan would be even more silent 😀
Reply 51 of 95, by oerk
I think you're right. Still can't remember where I found it. I just noticed that my AWE 64 (I know, wayyy too modern for this thread 😵 ) adds noticeable bus noise with the PC speaker input connected. It's practically silent when it's disconnected. I don't mind it, it's just something I noticed.
EDIT: Found the solution I was talking about:
http://www.deinmeister.de/e_sbpcqlnk.htm
Yep... I have a few AC8025TC, these work great, for instance in AT PSUs with unregulated fans.
Apparently there's a new model out - still dirt cheap:
http://www.arctic.ac/de_en/arctic-f8-tc.html
Reply 52 of 95, by Scali
Well, the PC speaker output on an IBM PC is very crude and unfiltered (basically just toggling a 5v line on and off), so if you have eg a bad PSU or some bad capacitors on your motherboard somewhere, delivering lots of noise in the power, you will hear that through the PC speaker.
Apparently my IBM 5160 is in reasonably good shape, and isn't very noisy at all.
Reply 53 of 95, by keropi
I have only one comment for this thread: it makes me freaking jealous 🤣 🤣 🤣
Reply 54 of 95, by bjt
Keropi: Your turbo XT is a lot nicer than this machine 😀
Some more progress, swapped the 8088 for a V20. Still feels glacially slow 🤣
Tested the Gotek with HxC firmware, works great. Here's the HxC file manager running on the XT (black and white composite).
After a lot of messing around with the brackets, got the Gotek installed. Spraypainted bezel came out OK I think. Half height drives on an XT are a pain.
Reply 55 of 95, by keropi
heh, if you were close I'd swap with you in an instant 😁
I am looking to get a 515x here, they do pop up from time to time....
Reply 56 of 95, by carlostex
Nice work bjt!
With the Gotek installed and the NEC V20 you can use the XT-IDE BIOS with the high density floppy extensions. 😎
Reply 57 of 95, by bjt
Yep, just need to get another floppy controller. I'm on the lookout for a suitable multi I/O card.
Reply 58 of 95, by carlostex
A standard 16bit one will work fine in an 8bit slot. If i remember correctly only IDE won't be available.
Reply 59 of 95, by bjt
Waiting for a few more bits to come in - standoffs to mount the CF adaptor and an activity LED, and the multi IO.
Started installing software in the meantime, loving the Gotek - download images, convert to HFE using the HxC software, assign multiple discs to slots and away you go.
