PCI Soundblaster card for DOS 6.22?
Reply 40 of 45, by alexanrs
MSCDEX comes with DOS, VIDE-CDD doesn't, you can get it easily, though. Like here (its all the way down).
Put VIDE-CDD.SYS in C:\DOS, then add to CONFIG.SYS:
DEVICE=C:\DOS\VIDE-CDD.SYS /d:MSCD001
And add to AUTOEXEC.BAT:
C:\DOS\MSCDEX.EXE /D:MSCD001
If you have UMBs, change "DEVICE" to "DEVICEHIGH", and if you have EMS add the "/E" parameter to the end of the MSCDEX line.
Reply 41 of 45, by gerwin
DECtape wrote:
Also, the tyrian setup drops to just the cursor in the corner of the screen and hangs there whenever I exit it, is that normal?
Glad the sound works, that is the main thing.
That Tyrian Setup package was just crudely cut out of the full game to fit one floppy. It was just a quick hack, and possibly that has the side effect you noticed.
Reply 42 of 45, by DECtape
Yeah, I hastily copied Jazz Jackrabbit Xmas 95 to the system by breaking it up across several floppies, evidently something went wrong as it throws an error when I try and run jazz but the setup works. If I run and exit the setup Tyrian is fine. But either way the sound works. I also tried the Doom sound test but no luck.
May your frames be high and your temps be low.
Reply 43 of 45, by gerwin
Just checked it myself:
Vortex 2 Soundblaster Pro emulation:
-causes the hang when exitting Tyrian setup.
-does not work with Allegro / Doom MBF (only FM music works). Edit 2017: it is because of the cwsdpmi dos extender used, replace it with dos32a.
-does work with Quake, for example.
Reply 44 of 45, by DECtape
gerwin wrote:
Just checked it myself: Vortex 2 Soundblaster Pro emulation: -causes the hang when exitting Tyrian setup. -does not work with A […]
Thanks, I found that if you run the Jazz Jackrabbit setup before Tyrian setup it works for whatever reason. Also I can't run the full game tyrian as it was evidently written in turbo pascal and doesn't like processors faster than ~200mhz, and gives me the runtime error 200. I'll have to try setting up a TSR program or something. I popped down to WalMart and got some blank CD's and the drive reads it great. Now I just gotta find some decent games.
Reply 45 of 45, by Tertz
DECtape wrote:
What PCI soundblaster or soundblaster compatable or similar card should I get for the p3?
For DOS sound you'd better used a MB with ISA slots and ISA SB card. Or you get less compatibility and probably less correct sound somewhere.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
