Building an XP gaming computer
Reply 40 of 49, by tayyare
SpaceCowboy87 wrote:
Thanks a lot for the advice. I really like you're XP build videos, they inspired me to put something together. I know the FX is the best upgrade for that socket, they're just hard to find even used. Im even considering building an AMD FM2+ based modern platform with DDR3 to run XP for the best results. There are some modern motherboards from AsRock that still have XP 32 and 64 bit drivers available for download but it also raises another question. Would 64 bit be better due to no RAM limitation like 32 bit? granted I can find the right drivers for everything.
You can also look for Opterons. They are easier to find and cheaper (relatively), while equivalent to AMD X2 / FX processors. And I personally don't recommend XP 64. Had problems like driver unavailability and some software refusing to run. It will not give you anything but more than 4GB RAM, but who cares about more than 4GB when using XP era software (games and otherwise)? 🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 41 of 49, by candle_86
if needing more than 3gb of ram that XP lets you use, go with XP SP1 and enable LBA
Reply 42 of 49, by PhilsComputerLab
AFAIK a 32 bit application (like a game) can only use / reserve up to 2 GB. Seeing that all the games are 32 bit games, RAM is really not an issue 😀
3 GB available RAM is all you need.
YouTube, Facebook, Website
Reply 43 of 49, by SpaceCowboy87
I'm thinking of getting an all new board and CPU for this project, considering an Intel Core 2 Duo E8600 Wolfdale Dual-Core 3.33 paired with a GIGABYTE GA-G41MT and 4GB of Ram. Using a dual-core chip should run high frame rates if paired with the right card. Any thoughts?
Reply 44 of 49, by clueless1
I think a fast C2D is a perfect chip for XP. 😀 I've got a Xeon 3070 (identical to an E6700) paired with a GF 8800GTX and it runs everything I throw at it easily: My 3DMark01 Mega Thread
Reply 45 of 49, by SpaceCowboy87
Its the sweet spot, I considered a socket AM3+ since most of those motherboards still offer drivers for XP but I had a feeling an Intel setup would run cooler and more efficient. Nothing against AMD processors I love them but Intel takes the win in this case. Now its just a matter of getting the best frame rate with an appropriate card
Reply 46 of 49, by PhilsComputerLab
What's great about AM3+ is the wide range of processors.
With intel there are too many sockets. 775, 1156, 1155, 1150...
The CPUs are cheap, but then you got to hunt down boards. Whereas with AMD you just need one decent AM3 board and you can use a huge range of processors. All of them are plenty fast for a XP retro gamer.
Reply 47 of 49, by nforce4max
I agree, if one wants to do Intel one is forced to "pick one" and stick with it. As for AMD I will never bother with Bulldozer.
Reply 48 of 49, by clueless1
That's a great point. I never considered it because I had a good 775 board to begin with.
Reply 49 of 49, by y2k se
The other reason to avoid 64-bit XP is that it cannot run 16-bit code. That can bite you if you are trying to run some older software.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
