Cyrix MediaGXM performance fix?
Reply 40 of 40, by k-Tracker
feipoa wrote on 2026-02-03, 22:03:
That process feels somewhat familiar. It is really round about and difficult to remember those steps unless they get documented. Thank you!
Did you first try these steps with the separate National drivers, found it didn't work, then tried with the all-in-one driver pack?
Separate drivers failed same way as all-in-one package. I haven't checked if the trick will work on them. That's not really needed, as all-in-one does job well for other drivers as well.
