Reply 40 of 41, by elianda
- l33t
This is not the issue here.
DScaler supports Overlay for historical reasons and Direct3D9 surfaces. It just defaults to overlay.
When set to DirectX it actually means that it uses the Direct3D9 surface and it should work fine.
With the complete system freeze I suppose it is some issue with the hardware access. Though I also use a Pinnacle pctv and I don't see this issue.
I use as Tuner here 036E.
Youtube Channel
