SB Pro compatible vs SB Pro/16 compatible
Reply 40 of 51, by James-F
gdjacobs wrote:
http://68.media.tumblr.com/ab1359915464a19c26562cba195adaa4/tumblr_inline_ns6j6r4v1Y1t56ltq_400.gif […]
pie jesu domine dona eis requiem.... plus, it doesn't have lowpass filtering, so it must be a witch.. or a duck?
Reply 41 of 51, by Cloudschatze
bristlehog wrote:
...for the rare titles (I can't even think of one) that really output 16-bit PCM sound in DOS...
Samples aside, by 1994, several of the larger sound libraries (Apogee Sound System, Asylum Sound System, HMI Sound Operating System, Miles Sound System, etc.) provided/supported 16-bit stereo mixing and playback routines.
Perhaps it's time to document the titles that include 16-bit samples and/or leverage the aforementioned 16-bit mixing/playback routines. The resulting list will likely be larger than most people realize.
Reply 42 of 51, by cyclone3d
I am guessing you could find a card with everything wanted except intelligent mode MPU-401.
Not including that, finding a perfect one-card solution for everything is pretty much going to be impossible though. There were never any made that would cover everything.
At the very minimum, you are going to need a 2-3 card solution.
1. Older Aztech card that supports Covox, Disney, etc. - only problem with this is that they are speed sensitive. If you have a system you can easily configure to slow down enough for really old games that you need to use it for, then sure.
2. Awe32 or Awe64 for games that specifically support those.
3. Maybe something like a Turtle Beach Tropez, or something else that supports Stereo SB-PRO, has OPL3, and has either wavetable header or has good onboard wavetable if you aren't going to use external modules.
4. GUS
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 43 of 51, by dr.zeissler
I used MOD4WIN years ago. I think at that time I had a p1-75 or P1-200, but I can't remember that.
Today I never use MOD4WIN because I never had a full version of it, beside the fact, that I like the old winamp with mod-plugins/visulizers better.
At the moment I prefer screamtracker, which is a dos-programm and is very good in my eyes.
Btw. I never use WSS which the audician32 has, I simply don't seem to need it and beside that I don't know how to install WSS in Win9x.
I really think that SBpro is much more important than sb16, because there are LOTS of SBpro kompatible games, that a sb16 can only
play as mono beside stereo of the original.
Reply 44 of 51, by firage
What games do you know that in fact use the SB Pro in stereo and lack separate support for the SB16?
My big-red-switch 486
Reply 46 of 51, by James-F
It all comes down to SBPro doesn't crackle/pop with single-cycle DMA games, supports SBPro interleaved stereo, and always has original OPL3, BUT lacks MPU-401.
The SB16 on the other hand is huge mess with tons of bugs spreading across all revision, and if you do find the 'less messy' ones like ct2230/2290 they are only good for non single-cycle DMA (auto-initialize DMA) games.
Personally for pure DOS system I would go for a SBPro2 + MPU-401 card, or find a all-in-one card like Audician 32, Aztech AZT2316 cards.
A SBPro2 + SB16 (or other with MPU-401) is also a great solution but requires some effort and knowledge to set up properly
dr.zeissler wrote:
because there are LOTS of SBpro kompatible games, that a sb16 can only play as mono beside stereo of the original.
Quite the opposite, there's almost no stereo games that support only the SBPro for stereo but not the SB16.
But if a game supports the SB16, it most surely supports the SBPro stereo too.
Reply 47 of 51, by firage
dr.zeissler wrote:
http://www.mobygames.com/game/dos/dune/techinfo http://www.mobygames.com/game/dos/dune-ii-the … ynasty/techinfo http://www.mobyg […]
http://www.mobygames.com/game/dos/eye-of-the- … holder/techinfo
http://www.mobygames.com/game/dos/eye-of-the- … rkmoon/techinfo
Besides lists of box specs, you've found that these games use the stereo mode unique to SB Pro?
Reply 48 of 51, by gdjacobs
James-F wrote:
It all comes down to SBPro doesn't crackle/pop with single-cycle DMA games, supports SBPro interleaved stereo, and always has or […]
Did you find any problems with the CS4232 controller and codec? I use one for it's MPU-401 interface, but generally don't use it's SB Pro compatibility as my card has the Crystal FM clone (which I hate). The line in and mixer seems magnificently noise free. Were I to have an Acer S23 or TB CS4232 card I might investigate it further.
Reply 49 of 51, by badmojo
Have you tried a CS4237 based Crystal card? They have all the awesome of the 4232 cards and a nicer OPL3 clone - there is still some difference to the real thing, but not in an offensive way. I use my Acer S23 because I can, but if it died then I'd be quite happy to replace it with 4237.
Reply 50 of 51, by gdjacobs
No, not a CS4237. My card has a combination CS OPL clone and 3D effects chip. It sounds so bad, I'm kind of afraid of all the Crystal Semi OPL clones.
Reply 51 of 51, by NJRoadfan
Aztech made a few cards with the Crystal CS4231 for 16-bit WSS playback/recording, SB Pro emulation, and included a real OPL3 chip. They also supported UART MPU-401 from the game port and sometimes even had a waveblaster header. ESS cards are a close second due to the ESFM emulation not being 100% OPL3 sounding, but they do feature more operators then the Yamaha chips do.
