Reply 40 of 85, by Horun
I have a few other 486 VLB boards with cache and the caps for the cache are 100nF (or 0.1uF) radial multi-layer ceramic (or Tanatalum appearing types) on both of them. They both are stamped 104 MEE from what my magnify lens shows me. So any 100nF (o.1uF) SMT cap should work.
As for cache the board excepts 32kx8, 64kx8 or 128kx8 density main cache chips. If you decide to fix it and just go for 256k total cache you are better to use 9 x 32kx8, if you use 4x 64kx8 plus one 32kx8 for TAG (still 256k) OR 4x 128kx8 plus one 32kx8 TAG (for 512k) then you have to disable the "auto" setting in BIOS cache because the AUTO defaults to interleaved using both cache banks but you will only fill one bank, also you must set Cache Read Speed to 3-2-2-2. ---> from the Archived Amptron website, the DX-6900 v1.7 is the M912 v1.7.
Best to fill both bank0 and Bank1 with cache chips just in case you loose CMOS settings and did not make a note/remember the cache setting. It will boot but hang near end of POST if cache is not set right in BIOS using just one bank.
added: attached the archived webpage zipped.
Reply 41 of 85, by Nexxen
ykot wrote on 2020-08-12, 22:01:
By the way, you may also want to unsolder JP10-JP36 direct jumpers and put 2x6 headers there so you would be able to configure the cache.
Absolutely, already ordered some.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 42 of 85, by Nexxen
Horun wrote on 2020-08-12, 23:13:
I have a few other 486 VLB boards with cache and the caps for the cache are 100nF (or 0.1uF) radial multi-layer ceramic (or Tana […]
Thank you man!!
Someone suggested 10-16V, is that the correct range?
Reply 43 of 85, by Nexxen
I've been looking around and it looks like those are 0.1µF 50VDC (in fact they are 0805 smd), and keeping in mind Horun's radial 0.1 and type 104.
I can try that unless anyone has something to say.
@Horun, as I don't know much on capacitance I think that anything above 5 volts will do, being the voltage of the ram chips.
For the price I can give it a go (0.70€ for 100).
Reply 44 of 85, by Nexxen
Can't really tell, but there is a chance the board and cache will work without these capacitors. It would still be a good idea to populate them to reduce the noise and improve system stability.
I unsoldered the jumpers and put some headers (pic coming). Job done but not a pro job 😀
Waiting for the capacitors to get delivered (it took forever!) and give it a go (probably in a week).
I'm going to use 5 cache chips as I have them from a socket 4 mobo.
I'll have to go with some wires as I lifted some pads and cut a couple of traces (talking steady hand...).
To do list:
1. test the board without cache: (i)- if it still works at all (ii)- benchmarks
2. test with everything soldered "no cache": benchmarks
3. test with everything soldered "with cache": benchmarks
Fake chips are needed for "bios continuity" (sounds good to me 😀) to allow boot even if none is actually installed?
Or even without any installed and more than 0 is selected will work??
Reply 45 of 85, by ykot
Nexxen wrote on 2020-09-24, 10:27:
I wouldn't be surprised if "fake chips" are just dummies, so if they are missing, no one will notice. 😀
But if you are still running modded BIOS for the fake chips, it would be a good idea to flash it with a proper image to be able to support real cache. I can't say for sure, but at least on some of my 486 motherboards (don't remember which ones), when I removed cache chips without changing any jumpers or BIOS settings, they would still boot and run, but obviously without cache.
Reply 46 of 85, by Nexxen
ykot wrote on 2020-09-24, 17:46:
Absolutely!
RAM traces to Cache are good; VCC is good; GND good.
I think it's definitely going to work. If not, nice ride.
I am led to believe that 28 and 32 pin chips are just different options for cache, the 4 extra pins are redundant VCC and gnd, the data is on other pins.
At least, that's why some have 32 pins with 28 chips, maybe need extra juice. I'm ignorant on the subject, so if wrong no offence if corrected.
Reply 47 of 85, by ykot
At least in my collection I only have 28-pin cache chips in 32-pin sockets, but I believe the extra 4 pins are needed to enable additional addresses for larger cache sizes.
Reply 48 of 85, by bjwil1991
And cache between 512KB and 1MB uses either all 32 pins (Bank 0, Bank 1, and TAG) or mostly 32 pins (Bank 0 and Bank 1) and only 1 uses 28 pins (TAG).
Reply 49 of 85, by Nexxen
Interesting info!!
I bought 28 pin sockets. Can cut another 4 pin and solder it...
Do I need more than 256kb of cache?
Reply 51 of 85, by Nexxen
Back on the board.
I soldered the 100nF 50V smd caps and the cache sockets.
Now the board won't boot. Diagnostic card reads "d3 d4" "d4 d3"; cache caps are shorted when power is on.
There is one smd cap that shorts when red lead of the multimeter is put on one side but not the other, when checking continuity.
Cap C45 at the bottom righ corner of the chipset.
Any ideas? 🙁
Edit: C48 also behaves strangely. Ground and +5V do not short at power connection. PSU is OK.
Edit 2: I use tag chip 1x 32k x8 + 4 x 32kx8 (tag + 4 chips) all same size Bank 0 is populated Bank 1 is empty . It doesn't output video.
Reply 52 of 85, by cyclone3d
Looked at one of my M912 v1.7 boards. The caps are supposed to be there though I am not sure it matters or not since you are only using 28-pin cache chips.
What happens if you remove those cache chips you have installed? You could have a bad one. You also only have 128KB cache installed right now.
What do you have the cache jumpers set to?
What does the back look like? Are you 100% sure you don't have any solder connections that are jumpered to each other that aren't supposed to be?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 53 of 85, by Nexxen
cyclone3d wrote on 2020-10-09, 15:47:
Looked at one of my M912 v1.7 boards. The caps are supposed to be there though I am not sure it matters or not since you are onl […]
I'm going to desolder the smd caps, it could be that the valure is too low. ATM they are 100nF.
Cache chips are connected to 5V. As caps are @50V my guess is that it should be ok.
I have only 8 chips, so yes, 128KB. Jumpers accordingly. Cache chips are fine, taken from another board where they work perfectly.
Back pic is on the way. It all looks ok, the damaged pins have been connected and all works as expected. Even wasted 2 hours checking all connections for continuity.
One more thing, I have a tag chips that is 32x8 but the manual says it should be 8x8 in single bank setup. Is that an issue?
The error displayed is memory size, so I don't know what's going on. (blowing brains all over the place emoticon)
Reply 54 of 85, by cyclone3d
Larger TAG chip isn't a problem.
I didn't see a reply about it. Are you still running the BIOS that was meant for boards with fake cache or did you update it to the regular BIOS?
YMF7x4 Guide
Reply 55 of 85, by Nexxen
cyclone3d wrote on 2020-10-09, 16:19:
Fake cache (facepalm hard as Krupp chaps)
Without cache and same setup (256kb) shouldn't it be working?
Reply 56 of 85, by cyclone3d
yes, probably. All the M912 boards I have came stock with real cache so I don't know for sure. If you can post a copy of your fake cache BIOS I can try it on one of my boards and see what happens.
YMF7x4 Guide
Reply 57 of 85, by Nexxen
cyclone3d wrote on 2020-10-09, 16:39:
I don't have a copy of it, unfortunately.
Reply 58 of 85, by Nexxen
Problem solved, one pin actually broke between the socket and the hole of the socket on the motherboard (fractured).
It was probably making contact when tested and broke when inserting the cache chip.
Tiredness doesn't help when checking things.
Board boots without cache and 256KB selected via jumpers. Tomorrow I'll do the test to see if I need a bios upgrade.
Reply 59 of 85, by Nexxen
I installed 256kb of cache in 9 chips.
If disabled message at post doesn't appear, if set to enable it does.
Chkcpu states there's no cache when enabled.
Tomorrow I'll check how to test if there's cache with another program. Hope it's not a bios limit because of fake cache.
