Reply 40 of 48, by meljor
wrote:Thank you. What I meant by "isn't easy to get" is pricing and availability : LINK <= This is my card (1GB DDR3 1600MHz). Who spe […]
wrote:@_007 Kudos for sticking to the facts and keep on showing stuff that is relevant for the discussion. Btw i have the cib Club3d hd4670 agp 1gb gddr3 version so i think the 1gb versions aren't that uncommon? Also have the hd3850 agp but mine is the Sapphire. I guess both are normal clocked versions. Best system i can come up with is an Asrock 865PE board with a C2D@3ghz and both cards will be a bit bottlenecked on that.
Thank you.
What I meant by "isn't easy to get" is pricing and availability : LINK <= This is my card (1GB DDR3 1600MHz). Who spends that much $ on a AGP GPU ?
I bought my card few years back locally for ~70$ (that's with with shipping).
Does your Club3D have VRAM clocked at 1333MHz ?
EDIT : Here's ASUS version of 4670 1GB AGP, with DDR2 memory : LINK
Didn't check the specs, just tested the card to see if it was functioning ok. Specs that i find on the web say: 750mhz gpu, 1600mhz gddr3 memory
