Reply 40 of 54, by Anonymous Coward
Anyone have any idea what jumper locations J11 and J9 might do? They are unsoldered on my board, and not mentioned in the manual. If I had to guess, I'd say J9 probably controls DRAM wait state 0/1, and J11 might be duty cycle 33%/50%.
Reply 41 of 54, by Robin4
Anonymous Coward wrote on 2021-09-25, 09:33:
Maybe set the processor type?
Intel 8086 or V30?
Reply 42 of 54, by Anonymous Coward
That would basically be setting the duty cycle. 8086 is always 33%, and V30 can be either 33% or 50%.
I soldered in the two jumpers. J11 doesn't seem to do anything as far as I can tell. J9, when open (the default is closed) causes the system to not boot up.
Memory wait states can be adjusted using chipset registers according to the manual.
Reply 44 of 54, by Anonymous Coward
I won't be able to pick mine up for quite a long time. When you get yours, let me know how it goes in terms of performance, heat production, and ability to overclock.
Reply 45 of 54, by Jed118
Anonymous Coward wrote on 2021-09-30, 00:10:
OK - not sure I'll get to it right away (still don't have the package) as I am busy with my PS/1000 and hah, life, but yeah, will do, I have a thermal scanner. Did you have any specific benchmarks or tests you'd be interested in?
What's for sale? my eBay!
Reply 46 of 54, by Anonymous Coward
8087 is usually stressed for stability using Autocad. I suppose you might also be able to use FRACTINT. I'm not too concerned about benchmark results (Though that might be interesting), but I would like to know if the FPU is stable at speeds exceeding 1oMHz.
I think I read these D9008D FPUs are also 387 compatible, so it would be interesting to see if it would be possible to test that.
Reply 47 of 54, by Jed118
And, no luck initially - 87test.exe failed to load with the native DOS 3.3, and on a 6.22 boot diskette it at least ran, but with divide overflow errors (can CTRL-C out of it).
I moved the jumper J10 1-2 and the system didn't POST. Syschk tells me there's no FPU - I'll try a few more things just now.
Reply 49 of 54, by Jed118
General apologies for the poor image quality, I bought a $60 smartphone to do three things - call from, text from, and use for 2FA. I did not consider the camera at all. Welcome to 2004.
BEHOLD!
So I ran sysinfo off an old boot diskette and I got this:
Followed by this:
Checkit tells me this:
But sometimes it'll also call it a V20.
Beginnings of Alzheimers?
87TEST run from native DOS 3.3
When run off a 6.20 DOS it does this:
The second line keeps populating with zeros and beeping wildly. CTRL-C exits and returns to DOS.
Some weird stuff happened to the system at some point - I tried to edit my autoexec.bat and config.sys files using DR DOS 7.03 (because I forgot how to EDLIN) to install an SCSI CDROM run off a Future Domain card(yeah, that didn't work) and the files vanished. Kind of. DIR didn't list them, but TYPE did. I got them back by running EDLIN and the file name, then issuing the END command. They then appeared in the DIR listing. Also, A:\ drive won't update the DIR listing when a new disk is inserted - you gotta take it out, DIR again, wait for it to fail, then put a new diskette in - with or without co-pro. This a DOS bug, or something with the floppy controller (which has its own BIOS)?
Messing around with the FPU on YouTube - https://youtu.be/8A_dCCx7XLk?t=1255
https://youtu.be/8A_dCCx7XLk?t=1683 87Test results.
(the sound card does work, there's a Sierra card game on the hard disk 😉 )
Reply 50 of 54, by Anonymous Coward
Your video is kind of a mess and pretty hard to follow.
From what I take, your system does boot up with the D9008D installed, so that's good I guess.
I've never tried 87TEST so I can comment on what normal behaviour should be. Maybe it's supposed to beep like that? In any case the tests that it ran were all passed. Not sure what test 5 and 6 are all about. Maybe they're for 387s. Do you have any documentation for 87test?
The other weirdness that you've been experiencing, is that FPU related, or something else?
I remember there is an extra jumper for the FPU in addition to the one on the main DIP switch bank. For whatever reason J10 has settings for "Normal Mode" and "Coprocessor 8087 mode". I remember with a real 8087-1 my machine acted funky in "Coprocessor 8087 mode", but worked fine in "Normal Mode".
Reply 51 of 54, by Jed118
Anonymous Coward wrote on 2021-10-06, 10:54:
Your video is kind of a mess and pretty hard to follow. From what I take, your system does boot up with the D9008D installed, s […]
Yeah, it's an unrehearsed live stream, just "do". I don't have time to make proper vids anymore 🙁
87TEST is what VWestlife used here:
https://www.youtube.com/watch?v=jiPEg2_EZ10
The PC's weirdness is, AFAIK, not related to the FPU. Could just be buggy copy of DOS (I seem to remember my 286 doing something similar with diskettes, running 3.3 as well), but the system does work well after it has "warmed up", like an old carburetted car. I'll have to investigate it (lol when I have time).
Yup, J10 is set to 2-3 (for "normal mode") works just fine with a real 8087 as well as the D9008D, and will not post in "coprocessor mode" (1-2, J10) with the D9008D, so your results match mine.
The extent of the 87TEST documentation is:
87TEST.EXE tests your 8087 (or 80287) numeric co-processor for accuracy, ability to handle "stress", and integrity. Fluctuation […]
ability to handle "stress", and integrity. Fluctuations in temperature
and other factors can affect the numeric co-processor's operations.
Therefore, in order to have confidence in the reliability of your program
results, we suggest that you run 87TEST during boot-up and both before
and after critical applications.
87TEST prints the results of its tests to the screen. When a failure occurs
it also sounds the beeper, to alert you to the problem. If the numeric
co-processor is not installed or is improperly installed, the program will
print a message to the screen saying so.
The program can run in two modes, either single-shot or continuous.
To run it for one pass, type 87TEST <enter>
To run it continuously, type 87TEST C <enter>
To break out of the 87TEST, hit any key or Ctrl-C.
Now I'm going to find some diagnostic tools and run some more tests 😉
Reply 52 of 54, by Anonymous Coward
I remember there was an FPU test that checked for the IEEE-754 compliance. It may have been the one that came with i387 and 287XL FPUs. That would be an interesting one to run on the D9008D.
Reply 53 of 54, by jorgenuviola
Jed118 wrote on 2021-01-22, 00:17:
Unbelievably, I obtained the SAME TYPE OF BOARD AGAIN (Hi/Lo, ver 2.01), in a complete computer, with a bootable hard disk and h […]
Jager wrote on 2018-11-13, 15:09:
Greetings.
Can you please share ROMs contents of this board? Mine is basically the same (minus half 44256 slots), but with a strange BIOS (same sticker, but with v1.07 written by hand). Both halves that should be even/odd are almost identical, and I think that's why my board appears to be dead (no video, no beeps).
I've attached my ROM dumps, just in case, in raw and intel hex formats.
Unbelievably, I obtained the SAME TYPE OF BOARD AGAIN (Hi/Lo, ver 2.01), in a complete computer, with a bootable hard disk and high density floppies, which both work.
I'll be dumping the ROM at some point.
PM me if interested 😉
Hi, i want the bios!!
Reply 54 of 54, by Jed118
jorgenuviola wrote on 2023-04-08, 04:05:
Greetings.
Ask jasa1063 - he has the PC now 😉
