Reply 40 of 43, by rmay635703
- l33t
TechieDude wrote on 2020-04-22, 20:08:NUSB works just fine with USB 1.0 as well. Just tried it on another 430TX board (QDI P5I430TX Titanium IB+). The other board I had was a DFI 586ITBD Rev.A1.
People forget there were USB win printers and usb win scanners available in 1997 (I vaguely remember a usb scanner in 96)
I bought several for quite cheap near the end of year because I didn’t want to pay the extra for an actual “good” standard printer or scanner.
Getting usb devices installed into windows 95c was a god aweful experience (and honestly it could be god awful in 98)
I remember that there was a whole long procedure that had to be followed exactly to get the usb motherboard /os driver working followed by a pre installation driver before you rebooted and attached the scanner once in windows, you then had to reboot again with everything powered for it to properly detect and link up.
I remember having to clean install windows, usb support and the multi part scanner environment multiple times before I could get it to actually scan anything other than a blank screen.
If you just attached the scanner and installed the driver it trashed things and you couldn’t uninstall requiring a fresh installation of windows.
Wonderful times.
Oh and the only difference I could find between USB 1.0 and USB 1.1 was that passive usb hubs (remember those) had warnings that 1.0 wouldn’t work reliably , things that drew power directly from the port would sometimes also have a warning about damage on 1.0 but were fine on 1.1.
Basically usb 1.1 had better power delivery, “charging support”, support of multiple devices and hubs, in other words mostly bug fixes so 1.1 wasn’t a monolithic single device at a time port.
