Source DirectX9 grey fog bug
Reply 40 of 52, by a0divided
This bug basically only happens while using DX9 with games that run on pre-Orangebox versions of Source, like Sin as mentioned above or HL2 & EP1 before the 2010 engine update.
But what's interesting is that this bug was fixed at some point by Nvidia, at least on their newer cards with the latest drivers. I currently have an RTX 3060 Laptop GPU with driver 516.5 and the fog actually works properly on DX9. Unfortunately, I think it's still bugged with AMD or Intel GPUs...
I'm not an expert by any means but I think the problem might be related to differences in how older (DX9) cards handle blending in comparison to modern DX10+ cards. There actually was a presentation at GDC about this for the Source Engine: https://cdn.akamai.steamstatic.com/apps/valve … heOrangeBox.pdf
Reply 41 of 52, by Dege
Thanks for that document! It's very interesting, I didn't know about the different SRGB read/write behavior of "old" and new (standardized DX10+) hardware.
So, it seems that early hw's might have done the SRGB linearization (reading) and gamma correction (writing) at wrong phases in the pipeline:
- for reading: after filtering at texture sampling
- for writing: before doing the actual blending operation
Both of them is incorrent in mathematical terms, and the new DX10 way is the correct one:
- for reading: right before the filtering when sampling a texture
- for writing: right before writing back the RGB value into the frame buffer
I found an NV documentation stating this:
On NVIDIA GeForce 8-class (and future) hardware, all samples used in a texture filtering operation are linearized before filtering to ensure the proper filtering is performed (older GPUs apply the gamma post-filtering). The correction applied is an IEC standard (IEC 61966-2-1) that corresponds to a gamma of roughly 2.2 and is a safe choice for nonlinear color data where the exact gamma curve is not known. Alpha values, if present, are not corrected.
Any value returned in the shader is gamma-corrected before storage in the frame buffer (or render-to-texture buffer). Furthermore, on GeForce 8-class and later hardware, if blending is enabled, the previously stored value is converted back to linear before blending and the result of the blend is gamma-corrected
In D3D9Ex, there is a cap bit (D3DPMISCCAPS_POSTBLENDSRGBCONVERT) indicating the correct DX10 type behavior which isn't yet exposed by dgVoodoo but it's all for the same, it won't help.
I looked again at Sin Episodes and ran it with disabled mipmapping with forced point filtering. This makes the old and new sampling process equivalent.
Also, when the "wrong" textures are drawn then blending is disabled meaning the old and new SRGB writing method are also equivalent.
Nothing changed in the game visuals so I think not this difference is our problem here. Unfortunately, for blended cases it could be a problem. Alex Vlachos proposes 2 solutions to handle the difference, one of them is:
Detect DX10 behavior and simulate the sRGB write in shader code forcing gamma blending
TBH I don't know what he thought of here. The blending operation cannot be emulated from shader so dgVoodoo cannot emulate the old sRGB behavior for blending. I don't know if it's a problem in practice, but anyway, HL2 is mentioned in the docs.
For all this problem, I have only one idea remaining. There is a difference between D3D8 and 9 DDI in the aspect of handling the fog coordinate. The early D3D9 NV drivers might have done it in the old D3D8-way and might have also had a bug for handling the fog state. And later when those bugs were fixed, the game visuals went wrong (like the thing with shadow buffers on the GF4 and Splinter Cell1) and this old driver behavior is "emulated" by nowadays on NV hw based on a game profile or sg like that. But what about other vendors? How these games worked on AMD cards?
Anyway, unfortunately I cannot check it out ATM if I'm right, it'd need some code development. And even if my theory proves to be true, I don't know how to solve it through dgVoodoo. I'm not happy about introducing a new option for that.
Reply 42 of 52, by Bubblesix
Dege wrote on 2022-07-26, 17:17:
I can't really comprehend the issue, but I want to confirm whether you noticed that the GeForce profile in dgvoodoo already does something to lessen the effect of the bug, as I've shown in the SiN screenshots above. Maybe that will provide a lead?
Reply 43 of 52, by Dege
Ah, thanks. I still didn't yet get to look into it. I wanted to verify my guess first, but I should change some code for that. Hopefully I can handle it together with other reported fog issues.
Reply 44 of 52, by Bubblesix
Any updates on this? Only asking because dgvoodoo is the only way I can play old source games bug-free, except for the fog. And like I've mentioned, setting an nvidia profile already does something to lessen it.
Reply 45 of 52, by Dege
Sadly, no. My current theory about the problem is the "point of linearization" for sRGB rendertargets, namely, when pixel shader output gets linearized: before or after alpha blending?
I guess NV can choose any of them internally based on the game profile but it cannot be controlled through DX11/12. (It was not defined in DX9, a cap bit told which one of the case is.)
Reply 46 of 52, by Bubblesix
Dege wrote on 2023-02-21, 17:44:
But what would be the mechanics of Nvidia vendor ID greatly reducing the severity of pixel bleaching? That would mean that the game is doing something different based on the vendor ID, correct?
Reply 47 of 52, by Silver-Ticket1808
I believe it was always like that in retail release of HL2 (IDK about Sin Episodes) because there are reports of this issues that date back to november of 2004 the flashlight and fog issue, there could be a possibility that sin episodes uses the 2004 old source, I will maybe check the 2006 rerelease of hl2 and the goty 2005 version of HL2 and report if it was just an initial issue, most people don't remember this bug because at those times most gpu used 8.1 directx and dx9 had really poor performance, like for example I exactly had Geforce FX 5700 Ultra while it had dx9 support the game is defaulting to a lower level, exactly like in dgvoodoo
here is one of reports that is 19 years old https://www.nvidia.com/en-us/geforce/forums/g … all-driver-set/
specifically about the flashlight issue so it is the games bug not the hardware's
Reply 48 of 52, by Silver-Ticket1808
Dege wrote on 2020-05-26, 17:23:
What I don't understand however, how does this game looks perfectly for me natively (nVidia card)? They added a built-in patch in the driver?
Or, the engine selects the intensity value depending on hw vendor value and various driver cap bits?
(My HL2 version is probably a fixed version and that's why I don't get the issue with that.)
I know it's old but you are using the last updated version of half-life 2 looking by the achievemts button the issue only exist on 2004-2005 old source, the issue is fixed on 2006 old source
Reply 49 of 52, by Squall Leonhart
It turns out that what we believed to be fog, that's not fog... It just looks like fog. […]
I checked out Sin with DX8 and DX9 level renderer (through dgVoodoo) and debugged the shaders for a problematic part. The calculated fog values were the same with both DX8/9 levels…
Also, in both cases the sampled texture is multiplied by an intensity factor (coming from the game) in the shader.
The difference between the two cases:
- DX9 level: the game renders parts of the scene with SRGB textures and SRGB rendertarget. SRGB scales the texture input/shader output from/to the linear space, so the intensity changes (it becomes too bright giving the impression of dense fog)
- DX8 level: SRGB is unsupported
For DX9 the SRGB part seems to be broken. Either it shouldn't be enabled or the intensity factor used in the shader should be slightly different. I had a look into what if SRGB is completely disabled but then it's too dark.
DX9 With SRGB:
DX9 Without SRGB
So, nVidia seems to be right, it's an issue with the application. 😖
floating point math difference between NV30 and NV40+?
NV30 is 32 or 16 only, with nvidia cheating in the driver where they cared to, to gain fps in places where it made some sense to, but gaining a higher level of precision for SRGB scaling
NV40 is 32, 24 and 16, so the pixel shader will operate within its limited buggy implementation.
Reply 50 of 52, by Squall Leonhart
DX9 With SRGB:
DX9 Without SRGB
This was covered in the annivesary info
https://www.pcgamer.com/games/fps/a-valve-eng … was-i-hate-you/
It was an industry wide issue, both in hardware and engines.
Reply 51 of 52, by Pufferfish9billion
Silver-Ticket1808 wrote on 2024-05-15, 01:08:
If it's fixed on 2006 Source, does that mean EP1 shouldn't have the fog problem? I read on the Valve Developer wiki it's possible to upgrade the last old engine version of base HL2 from Source 2004 to 2006 by using EP1 dlls.
https://developer.valvesoftware.com/wiki/Half … Technical_notes
Reply 52 of 52, by Pufferfish9billion
Pufferfish9billion wrote on 2026-02-11, 14:27:
Idk how to edit posts here so I'm replying to myself:
Yup, this seems to do the trick (although sadly the combine apc is sunk to the ground in this build). I'm using the Orange Box "Jump" Russian build.
Ignore the broken UI, it's caused by running in Sandboxie ("Jump" build seems to be malware-free once extracted with Innoextract).
